Author Topic: "Typewriter" keycaps like on Massdrop  (Read 56596 times)
Offline captsis
  • Formerly matt2dlg
Re: "Typewriter" keycaps like on Massdrop
« Reply #50 on: Tue, 27 September 2016, 20:48:32 »
are they these? They look like they'd be a ***** to actually type on. :/
Offline chuckdee
« Reply #51 on: Tue, 27 September 2016, 20:51:59 »
No, they aren't.
Offline captsis
  • Formerly matt2dlg
« Reply #52 on: Tue, 27 September 2016, 20:56:11 »
No, they aren't.
Then what, some cheapo taobao set that massdrop bought?
« Reply #53 on: Fri, 30 September 2016, 05:17:10 »
I'm in two minds about these.
Pad printing - probably wear off sooner rather than later.  It's very disappointing when a keycap set shows wear after not too long, regardless of the cost.
Stems - square and apparently less compatible with Cherry switches, but better with Gateron switches.  All my MX-like keyboards have Cherry switches.
Plastic "chrome" - rubs off after a while?  Most plastic "chrome" I've seen tends to wear in places, and once worn stays that way.  These would look terrible with worn patches on the edges.
Still 4 days left, I might talk myself back in to them, but probably not.
Offline zslane
« Reply #54 on: Fri, 30 September 2016, 12:04:39 »
You have to ask yourself, how much would you type on them if you had them on a board? Would they be on your daily driver if they were more high-end?
I think of these as novelty caps, and I doubt I would use them all the time. It would probably take quite a while for the legends to wear off or the faux chrome to wear off. Maybe by the time that happens, someone will have a GB up and running for a high-quality take on this idea.
I too am on the fence as to whether to pick up a set.
« Reply #55 on: Fri, 30 September 2016, 16:19:30 »
That one has 1x modifiers on the bottom row and a 1x Tab. That kinda irks me a bit, especially the Tab.
If you are going to be correct with how typewriters of the era were then all keys should be circular except for the Space Bar.
More over, typewriters were often very stepped. The keys should be slanted forwards to emulate that and to provide a better typing experience, not be flat like a chiclet keyboard.
Offline zslane
« Reply #56 on: Fri, 30 September 2016, 16:51:10 »
Technically true. However, I think the goal is to have a manual typewriter aesthetic without the (awkward) manual typewriter experience. Conforming to the layout of the keyboard these keys would be mounted on makes the most sense to me.
« Reply #57 on: Sun, 02 October 2016, 04:03:17 »
Daily driver at work is now SSK.
Daily driver at home changes, but is sometimes something with MX switches.
So they would be used occasionally at home.
Given how many keycap sets I have, and given the reservations about these, I will leave them for now.  If they are re-run in a few months, I might reconsider.
The old trick - imagine you have the money in one hand and the keycaps in the other.  Which would you rather keep.  For me it is the money this time.
« Reply #58 on: Sun, 02 October 2016, 14:19:17 »
There are a few keyboards and keycap sets like these on eBay now.  One notes that they are "super rare" - obviously hasn't seen Massdrop.
Also they are available in pink (albeit with a keyboard in this listing), which suggests that they will be more generally available at some stage, and not just a passing thing.
http://www.ebay.com/itm/68keys-SteamPunk-Retro-vintage-typewriter-mechanical-keyboard-blue-switch-/222268597737
149597-0
« Reply #59 on: Sun, 02 October 2016, 15:39:50 »
Any blue ones?
« Reply #60 on: Sun, 02 October 2016, 21:05:28 »
Any blue ones?
I wasn't looking, I just saw that linked from something else I was looking for.
Offline Barndenn
« Reply #61 on: Wed, 05 October 2016, 12:53:32 »
Does anyone know of or have a picture of the typewriter keycaps with backlighting?
Offline SpecTP
« Reply #62 on: Wed, 05 October 2016, 15:29:42 »
I got this with MX cherry black and they are pretty good. Not using them much since the pad printing won't last too long to my abuse.
« Reply #63 on: Wed, 05 October 2016, 20:49:28 »
There's a picture or two in the Massdrop comments showing backlighting.
Offline zslane
« Reply #64 on: Tue, 25 October 2016, 16:03:37 »
For fans of MX Blue switches, it is worth noting that you won't hear the switch click over the noise of bottoming out with these keycaps. Due to their design, there is no way for silencing rings to have any effect on dampening the downstroke. The combination of bottoming out and upstroke noise will drown out the sound of the switch's internal click leaf.
« Reply #65 on: Tue, 25 October 2016, 20:45:39 »
I wonder what this profile would be called.
Offline ideus
  • Björkö.
« Reply #66 on: Wed, 26 October 2016, 07:14:13 »
The "Flat and Ugly Retro"?
« Reply #67 on: Wed, 26 October 2016, 20:49:56 »
Offline jgodinez302
« Reply #68 on: Tue, 08 November 2016, 17:40:36 »
As someone mentioned before Datamancer makes them as well and yes they are quite a bit more.... however the quality is far superior to those on massdrop/ebay. I've visited Datamancer before for the SoCal meet up and got to see how bunch of them are made there. Definitely will last a lot longer and they are much heavier considering they are made out of actual metal and not plastic.
Offline zslane
« Reply #70 on: Wed, 16 November 2016, 12:52:26 »
Yes, that is the same set that was sold through MassDrop.
Offline menuhin
« Reply #71 on: Wed, 16 November 2016, 13:37:41 »
Is 'Datamancer' a factory or a company? Or is that a person?
Didn't some forum member say 'Datamancer' committed suicide a few years ago?
It's becoming more and more mysterious.
I would guess Datamancer's offer would be of much much higher quality. On DT, someone from the UK is offering wooden version with ISO UK layout by the way.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline zslane
« Reply #72 on: Wed, 16 November 2016, 16:31:13 »
Datamancer is a company. It used to be led by its founder, who is no longer with us apparently.
« Reply #73 on: Tue, 29 November 2016, 19:53:12 »
A set that is halfway between Datamancer and Massdrop sets would probably be best.
Offline captsis
  • Formerly matt2dlg
« Reply #74 on: Tue, 29 November 2016, 20:07:16 »
good or cheap. pick one.
« Reply #75 on: Wed, 30 November 2016, 19:59:57 »
Harder to pick than a broken nose!
Offline buckyballs
« Reply #76 on: Sun, 11 December 2016, 21:33:55 »
So there's a drop for a Magicforce 68-Key Mini Mechanical Keyboard with special typewriter keycaps:
https://www.massdrop.com/buy/magicforce-68-key-mini-mechanical-keyboard?mode=guest_open
This is not a full TKL ANSI set of keycaps though, although the bottom row is the standard layout.
Anyone know if these keycaps (preferably a full US ANSI TKL set) are available separately?
Standard layout means they have a apps key is it?
« Reply #77 on: Sun, 11 December 2016, 21:47:06 »
Yeah, the Menu key.
« Reply #78 on: Mon, 12 December 2016, 19:58:50 »
Sort of, although it was more in reference to the keycap size i.e. 1.25 1.25 1.25 6.25 1.25 1.25 1.25 1.25
« Reply #79 on: Mon, 19 December 2016, 13:07:19 »
Square stems seem to be becoming more "popular": https://www.massdrop.com/buy/dot-eh112-bluetooth-mechanical-keyboard?mode=guest_open
Also white ones like the original ones are now available: https://www.massdrop.com/buy/retro-white-typewriter-keycap-set?mode=guest_open
Although both are still ABS and have the square stem.  The first set is customised for that particular keyboard, but based on the stem could very well be made by the same manufacturer, unless others are jumping on the square stem bandwagon.
Offline classiccarguy92
« Reply #80 on: Tue, 27 December 2016, 02:03:20 »
I'm actually working on a build using a cm board with cherry blues on it. The plan is to design it to work and look like an old typewriter so that's why I went with the blues because they have a similar sound to an old typewriter. I can't wait until it's finished.
« Reply #81 on: Tue, 27 December 2016, 04:13:23 »
Blues (and greens) and more a "tick tick tick" sound, whereas typewriters were "clack clack clack".
But they are probably closer than most other MX(-compatible) switches.
If you prefer heavier switches, MX greens are great!
Offline zslane
« Reply #82 on: Tue, 27 December 2016, 11:41:09 »
I did this very same experiment myself and found that MX blues have such a soft "click" sound that it is drowned out by all the bottom-out and upstroke noise. The result is a typing clatter that doesn't resemble the noise of manual typewriters at all, but you probably won't get any closer with any other MX switch, not even a different clicky MX switch.
156220-0
Offline superpiya
« Reply #83 on: Fri, 30 December 2016, 00:22:46 »
These keycaps are beautiful, but are they comfortable to type on?
Offline majstor
« Reply #84 on: Thu, 05 January 2017, 15:59:09 »
Wooden version of typewriters keys .156873-0
« Reply #85 on: Fri, 06 January 2017, 23:07:19 »
Wooden version of typewriters keys . (Attachment Link)
Neato! Got a link?
Offline majstor
« Reply #86 on: Sat, 07 January 2017, 12:36:14 »
No, I do not have a link but it's my work..
This is of cherry
and before is the oak
« Last Edit: Sat, 07 January 2017, 12:40:56 by majstor »
« Reply #87 on: Mon, 23 January 2017, 20:01:16 »
They look really well done!
Does the wood split or wear over time, especially the stem (if removed and reinserted many times)?
« Reply #88 on: Mon, 23 January 2017, 20:13:45 »
This is of cherry
I just saw your response. Very impressive indeed! You should make more.  :p
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #89 on: Tue, 24 January 2017, 01:06:09 »
I would imagine so with seasonal changes in humidity as well. I would want to stabilize the wood before using it.
-Dana
Offline bmmcwhirt
    • KB9YEN
« Reply #90 on: Tue, 24 January 2017, 08:36:24 »
This is an alternative option.
http://www.banggood.com/104-Key-Steampunk-ABS-Retro-Circular-Keycaps-For-Mechanical-Keyboard-p-1112262.html?rmmds=search
Offline majstor
« Reply #91 on: Tue, 24 January 2017, 16:52:56 »
 Wood naturally must be properly processed but is not affected by moisture, water and alcohol. After 2 years of use ( other keys of course and not those from the above images)  i do not have a need for polishing. Cross is made from ABS  .
« Reply #92 on: Tue, 31 January 2017, 20:04:36 »
Still got those rectangular stems though ...
« Reply #93 on: Tue, 07 March 2017, 13:08:50 »
There's these now: https://www.massdrop.com/buy/datamancer-typewriter-keys?mode=guest_open
The real deal, however I'm not too keen on the typeface used on the legends, the stems are not shown, and the modifiers are different sizes and shapes and don't line up and that would really bug me each time I saw the keyboard.
Offline zslane
« Reply #94 on: Tue, 07 March 2017, 13:20:39 »
Datamancer only used to have two sizes of keycaps: 1u and 1.25u. That made keyboards look even weirder than what you're seeing in that new drop. Now it looks like they have a third size, something close to 2u, which certainly helps, but is still not quite perfect for standard keyboards today. I'm pretty confident the stems are cylindrical, not rectangular like the cheapo ones that come with the MagicForce "typewriter" board.
