Author Topic: Looking for a good keycap set with translucent legends for my Pok3r  (Read 4255 times)
Offline dandanflake
Hello, I've had my backlit Pok3r three for awhile now and have been loving it. While the default keycaps don't really bother me I am still looking for something higher quality than the ABS caps it comes with. I've done some browsing around the internet and have yet to find anything that will work for what I want. Ideally I'd like a dark blue PBT set with translucent legends. If I had known it would be this hard to find good sets with translucent  legends I think I would have opted for the non backlit version. Anyway if any of you have any suggestions it would be greatly appreciated, thanks :)
IBM Model M 1989 1391401
Vortex Pok3r w/ Cherry MX Clears
Model F Labs Kishsaver
KBDFans Dusk67 w/ Gateron Oil Kings
Offline 1swt2gs
  • DOGE
Re: Looking for a good keycap set with translucent legends for my Pok3r
« Reply #1 on: Fri, 01 July 2016, 01:18:09 »
Backlit with thick pbt's give off a glow, kind of nice if you don't mind not having trans legends :D
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline 1swt2gs
  • DOGE
« Reply #2 on: Fri, 01 July 2016, 01:18:49 »
Also, if you are brave enough to dye your caps, you can get white vortex doubleshot translucent keycaps and dye them blue!
Offline dandanflake
« Reply #3 on: Fri, 01 July 2016, 02:04:55 »
Hmm that's good to know maybe I'll look into that. I don't mind not having the legends as long as I'm utilizing that back lighting. Also dying the translucent white vortex keycaps sounds like a good idea. How hard do you think that would be?
Offline dandanflake
« Reply #4 on: Fri, 01 July 2016, 02:10:25 »
One set I have been looking at is the midnight keycap set. http://pimpmykeyboard.com/dcs-midnight-keycap-set/ it actually seems to work pretty well with backlit boards
http://i.imgur.com/mSEfYb3.jpg
http://i.imgur.com/aEFIYKJ.jpg
https://app.box.com/s/7e3qhnlnbxe8r69cbrry
Offline 1swt2gs
  • DOGE
« Reply #5 on: Fri, 01 July 2016, 02:40:48 »
Heres a link to someone dyeing the caps. From a quick glance, it's not too hard
 http://imgur.com/a/SiiWM
Here's a DIY (do it yourself) on how to dye keycaps
http://imgur.com/a/P6RHv
Also, the midnight keycap is a great set if you wanna stray away from blue
Offline dandanflake
« Reply #6 on: Fri, 01 July 2016, 12:05:21 »
Thanks for the links! :) and yea the midnight set is pretty nice I may stray away from the blue for that instead. I still want to see about dying a set
