Author Topic: Broken ALPS  (Read 2078 times)
Offline didjamatic
Broken ALPS
« on: Fri, 01 January 2010, 14:36:52 »
I was trying to remove a switch from this awesome Acer PS/2 ALPS board (middle photo) and I removed it alright...  by splitting the outer switch housing into 2 pieces.  The internet told me to.
Since this is one of the cooler ALPS boards I have, another will be sacrificing one of it's switches.
Offline didjamatic
Broken ALPS
« Reply #1 on: Fri, 01 January 2010, 14:47:44 »
Acer
Model No. 6011
Extension No. E91/US (3C)
Serial No. K6011026796
Mfg. Date. 03/06/91
Made in Malaysia
FCC ID G086011A
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Broken ALPS
« Reply #2 on: Fri, 01 January 2010, 16:02:37 »
I haven't seen anything like that happen before. You'll have to find an experienced ALPS-ologist to cure that.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Broken ALPS
« Reply #3 on: Fri, 01 January 2010, 16:15:45 »
Quote from: microsoft windows;147153
i haven't seen anything like that happen before.
Offline InSanCen
Broken ALPS
« Reply #4 on: Fri, 01 January 2010, 17:37:59 »
Since I have decided to do a Switch Swap on the Wang 724, I now have a load of spare switches. If you can't get one elsewhere, would you like one?
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline didjamatic
Broken ALPS
« Reply #5 on: Fri, 01 January 2010, 17:41:41 »
Why are you swapping switches on the Wang?  Aren't they Pink ALPS?
Broken ALPS
« Reply #6 on: Fri, 01 January 2010, 18:08:02 »
So I guess it's the Montereys that have the different body.
Offline InSanCen
Broken ALPS
« Reply #7 on: Fri, 01 January 2010, 18:14:18 »
Yes, but they have led a hard life of servitude, and now need to be put out to pasture. Not sure what I will replace it with, and I may only do the Alpha's and main numbers. Maybe the Numpad. Some of the lesser used keys are great, but the main area is very poorly indeed. If you want some, they are yours. PM me your address, and I'll get the soldering iron and de-soldering braid out.
Offline didjamatic
Broken ALPS
« Reply #8 on: Fri, 01 January 2010, 19:08:56 »
InSanCen, you are the bomb!  Thank you!
Offline sandy55
Broken ALPS
« Reply #9 on: Fri, 01 January 2010, 19:59:38 »
Quote from: didjamatic;147119
Acer
FCC ID G086011A
Just for a record, company code of Acer registered in FCC is GQ8.
Early model of Acer 6011 used different shape of outer case and came with Blue ALPS.  same body as KB-101A.
Offline Mercen_505
Broken ALPS
« Reply #10 on: Fri, 01 January 2010, 20:12:07 »
You know, there's a joke in there somewhere.
Offline InSanCen
Broken ALPS
« Reply #11 on: Sat, 02 January 2010, 19:24:52 »
I am actually disappointed that Ripster didn't get a Pink Wang joke in there.
