Author Topic: [IC] JD40 Kits  (Read 41611 times)
Offline mr scooty
Re: [IC] JD40 Kits
« Reply #100 on: Mon, 27 February 2017, 12:57:35 »
This kit is awesome. Any word on how reputable this buyparty.io group is? I know they're new
Offline sherryton
  • Kībōdo
    • Originative
Re: [IC] JD40 Kits
« Reply #101 on: Mon, 27 February 2017, 17:58:33 »
I'll be re-distributing the JD40. The web-site belongs to a friend!
Offline mr scooty
Re: [IC] JD40 Kits
« Reply #102 on: Tue, 28 February 2017, 00:34:53 »
Awesome! Really excited about the JD40 case and was hoping for some of the other colors mentioned in the OP. Plus the buyparty site could use some work.. Pretty difficult to navigate, not sure how well the wordpress templates work for this type of site
Offline tacnificent
Re: [IC] JD40 Kits
« Reply #103 on: Tue, 07 March 2017, 12:12:28 »
No case color options? Option for no switches?
Offline Happylomo
Re: [IC] JD40 Kits
« Reply #104 on: Wed, 08 March 2017, 16:50:10 »
So, u'll run ur own GB / Store for the JD40 kits, basically?
Offline sherryton
  • Kībōdo
    • Originative
Re: [IC] JD40 Kits
« Reply #105 on: Wed, 08 March 2017, 16:51:10 »
No, I'll be re-distributing the one from buyparty. We'll have a re-launch next Friday.
Offline mr scooty
Re: [IC] JD40 Kits
« Reply #106 on: Wed, 08 March 2017, 17:52:20 »
If you're planning to rerun through buyparty, may I suggest doing some cleanup or changes to their login/account setup process. It was pretty finicky when I was trying to set up an account
Offline sherryton
  • Kībōdo
    • Originative
Re: [IC] JD40 Kits
« Reply #107 on: Wed, 08 March 2017, 17:53:19 »
Yeah, I've already told them to fix the account/login. We're going to try to bypass that if possible
Offline mr scooty
Re: [IC] JD40 Kits
« Reply #108 on: Wed, 08 March 2017, 21:52:01 »
Awesome! Thanks a bunch. That was really my only issue with them. I definitely understand the benefits that come from template web dev kits like wordpress and wix, but without plugins/extra dev work they just become so darn difficult the second you try to make something a little out of the box...
Offline William_S_Jones
  • Best Prime Ever!!!
Re: [IC] JD40 Kits
« Reply #109 on: Fri, 17 March 2017, 17:15:44 »
I've got the same question. I believe you mentioned case color options of black, grey, pink, and red. Also, I log into the site for it & there was no option to buy w/o switches.  Well, I'm looking forward to the next time around.
Offline sherryton
  • Kībōdo
    • Originative
Re: [IC] JD40 Kits
« Reply #110 on: Fri, 17 March 2017, 17:30:26 »
The JD40 itself only comes with the case, plate, and pcb. The switches are on the side and you can choose to order them.
Re: [IC] JD40 Kits
« Reply #111 on: Fri, 17 March 2017, 17:34:03 »
Thanks & are different case colors an option?
Offline sherryton
  • Kībōdo
    • Originative
Re: [IC] JD40 Kits
« Reply #112 on: Fri, 17 March 2017, 17:35:34 »
Yeah, I'll add that information. We're going to do a new re-launch. This is where the MOD-SH will be sold and limited to only 100 units!
We're also going to drop the price of the JD40 to welcome new buyers. The current buy isn't 'Live' yet.
Re: [IC] JD40 Kits
« Reply #113 on: Fri, 17 March 2017, 17:39:40 »
Great, I'm in for a set of Mod SH switches too. Thanks
Offline mr scooty
Re: [IC] JD40 Kits
« Reply #114 on: Mon, 27 March 2017, 14:50:21 »
Any word on when this might begin?
Re: [IC] JD40 Kits
« Reply #115 on: Tue, 02 May 2017, 11:43:35 »
It's live now: https://originative.co/products/jd40-pcb
I talked to Sherryton yestetday & it hasn't reached MOQ yet. To everyone that said they "wanted one," please join this gb." I joined yesterday (rose gold kit), everyone interested, please join by the last day, this Friday (5/5/2017), I know we can do it!
Offline Photoelectric
Re: [IC] JD40 Kits
« Reply #116 on: Tue, 02 May 2017, 12:22:54 »
Thread locked as the IC phase has been finished.  Please discuss the group buy in a dedicated GB thread or in the absence of one either contact Sherryton directly or discuss it in the Originative section.  Thank you.
