Author Topic: [IC] Universal 87/104/108 Plate (In Stock!)  (Read 89074 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« on: Wed, 13 July 2016, 11:57:22 »
Update as of June 13th, 2017: We have these in stock!
Below is a link to original IC here on GeekHack:
https://geekhack.org/index.php?topic=56007.0
We now have these available, so get one before they are gone.
Thanks.
« Last Edit: Tue, 13 June 2017, 12:29:25 by 00zeRO »
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline WNovizar
Re: [IC] Universal 104/108 Plate
« Reply #1 on: Wed, 13 July 2016, 23:26:01 »
I want at least one, but does the plate supports plate-mounted cherry stabilizers?
I like mechanical keyboards
Offline 00zeRO
  • * Moderator
« Reply #2 on: Wed, 13 July 2016, 23:34:41 »
Yes, both Cherry and Costar
Offline WNovizar
« Reply #3 on: Thu, 14 July 2016, 03:31:30 »
Another question, Can I cut the additional 4 keys for 104 keyboards?
Offline 00zeRO
  • * Moderator
« Reply #4 on: Thu, 14 July 2016, 07:27:01 »
If you look at the plate pictured above, it does allow for you to cut the top row additional keys off if you don't need the for your build.
This design is rather ingenious, I'd say.
« Reply #5 on: Wed, 24 August 2016, 11:21:47 »
Bumping because these types of threads are easy to miss. :thumb:
Offline 00zeRO
  • * Moderator
« Reply #6 on: Wed, 24 August 2016, 11:49:00 »
Thanks, RaY. We just received some samples of these...so as long as there is interest, we will carry them.
Offline 00zeRO
  • * Moderator
« Reply #7 on: Sat, 03 September 2016, 11:40:23 »
Is there interest?
Offline Dreamre
    • kbdlife
« Reply #8 on: Thu, 08 September 2016, 12:47:37 »
Still patiently waiting for a TKL Filco plate :)...
Re: [IC] Universal 87/104/108 Plate
« Reply #9 on: Thu, 08 September 2016, 12:49:12 »
This plate will work for Filco TKL! :D
FYI, this plate has been prototyped, and tested to work on most common 87/104/108-key keyboards.
« Last Edit: Thu, 08 September 2016, 12:57:59 by jdcarpe »
Offline Dreamre
    • kbdlife
« Reply #10 on: Sun, 11 September 2016, 14:04:51 »
Yes! I need to get my hands on one!
Offline K.Mak
« Reply #11 on: Tue, 27 September 2016, 16:19:33 »
I'm definitely interested, everything I've seen lately has been non Costar friendly or marketed as Costar friendly but the measurements are slightly off so I ended up having to use Cherry stabilizers. I'd probably need a case for it as well though and I'm not super fond of the current iteration of the TEX cases. I get the daughter board issues but detachable cables are a must for my needs.
Offline RELLIK
  • WTB Bro Power Core WASD Set...Still...
« Reply #12 on: Fri, 14 October 2016, 05:49:56 »
Interested if the plate allows switch opening.
     KUL-87        FC660M       Filco MJ2
Offline 00zeRO
  • * Moderator
« Reply #13 on: Fri, 14 October 2016, 07:13:57 »
Of course it does
Offline WNovizar
« Reply #14 on: Fri, 14 October 2016, 09:10:26 »
still interested for my filco
Offline wodan
« Reply #15 on: Fri, 14 October 2016, 09:12:20 »
Will they support G80 PCB?
Offline Dreamre
    • kbdlife
« Reply #16 on: Fri, 14 October 2016, 12:39:12 »
Still interested!
Offline RELLIK
« Reply #17 on: Sat, 15 October 2016, 17:38:29 »
Of course it does
Cheers, thought switch opening feature required 2 indents on left/right edges of plate cutouts  :-\
Offline 00zeRO
  • * Moderator
« Reply #18 on: Sun, 16 October 2016, 09:45:29 »
Of course it does
Well, if you look carefully, the whole sides are cutout. Only the top and bottom fit snugly on the switches
Offline Arokai
« Reply #19 on: Thu, 03 November 2016, 15:30:29 »
Is this still open? I'm interested in this.
Offline 00zeRO
  • * Moderator
« Reply #20 on: Thu, 03 November 2016, 15:31:48 »
Yes. Sorry.
We are working with the manufacturer to have a batch made. Updating OP.
Offline Dreamre
    • kbdlife
Re: [IC] Universal 87/104/108 Plate (Placing Order)
« Reply #21 on: Fri, 04 November 2016, 23:49:27 »
Yes! What material and colour options will there be?
Offline 00zeRO
  • * Moderator
« Reply #22 on: Sat, 05 November 2016, 07:29:58 »
Brushed, stainless steel. Only option
Offline Dreamre
    • kbdlife
« Reply #23 on: Sun, 06 November 2016, 14:35:42 »
Will there be future options to be in Al with different colours? Thanks!
Offline 00zeRO
  • * Moderator
« Reply #24 on: Sun, 06 November 2016, 17:58:28 »
Not likely since steel plates are more rigid and a person could paint there own to suit individual taste
Offline Dreamre
    • kbdlife
« Reply #25 on: Sun, 06 November 2016, 20:44:23 »
Ok, thanks! I ended up purchasing an Al one and I'm just going to dremel it to fit. Thanks!
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #26 on: Mon, 03 April 2017, 03:33:11 »
If this is still open, pls count me in.
Offline WNovizar
« Reply #27 on: Thu, 20 April 2017, 12:34:23 »
Is this still happening?
Offline 00zeRO
  • * Moderator
« Reply #28 on: Thu, 20 April 2017, 15:24:25 »
Offline 00zeRO
  • * Moderator
Re: [IC] Universal 87/104/108 Plate (In Stock!)
« Reply #29 on: Tue, 13 June 2017, 12:30:02 »
