Author Topic: nvrmnd  (Read 1454 times)
Offline Scivive
nvrmnd
« on: Wed, 20 July 2016, 09:53:10 »
nvrmnd
« Last Edit: Wed, 20 July 2016, 11:24:38 by Scivive »
Offline [Lewynlight]
  • Formerly Dymloslouire
Re: How to troubleshoot broken Novatouch?
« Reply #1 on: Wed, 20 July 2016, 10:20:53 »
too few details..
have you tried to restart your computer with the keyboard plugged in?
some keys or all keys?
have you tried it on other computer/laptop?
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline Scivive
nvrmnd
« Reply #2 on: Wed, 20 July 2016, 10:25:04 »
nvrmnd
« Last Edit: Wed, 20 July 2016, 11:24:51 by Scivive »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Wed, 20 July 2016, 10:57:53 »
Definitely check out that USB connection if you open up the keyboard. I don't see a replaceable breakout board; I hope the problem is a loose USB connection. Has your warranty expired? I'm not 100% sure but it looks like you'll void your warranty if you open the case. Some of the screws (2 of 4) are under stickers.
http://www.weistang.com/article-1423-5.html
Edit - Oh ok, I see you've opened it. Did you check the other side of that USB connection?
Re: nvrmnd
« Reply #4 on: Fri, 22 July 2016, 06:20:32 »
Maybe the thread could be locked to avoid ensnaring any more unsuspecting forum lurkers.
