Author Topic: Terminal Model F, or slightly altered Unicomp?  (Read 5516 times)
Offline sethstorm
« on: Mon, 04 January 2010, 12:26:33 »
Thinking of which one of these to go for:
    a heavily modified(for a manufacturer) Unicomp that has the black M13 style keys.
    Terminal Model F and modify it with my RJ-45 adapter, and just let the black Unicomp go to someone else.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline ch_123
« Reply #1 on: Mon, 04 January 2010, 12:30:22 »
You're probably never going to find an all-black Unicomp terminal board. And the M13 idea isn't going to be completely successful as it does not have all the right buttons.
That, and Model Fs are so much cooler.
Offline sethstorm
« Reply #2 on: Mon, 04 January 2010, 12:36:49 »
Quote from: ch_123;147843
Already have an M13, don't plan on any mouse button adding at all.
But if you want to see which keyboard I'm referring to, I'll post it up on Ebay Finds.
Current:
Offline sethstorm
« Reply #3 on: Mon, 04 January 2010, 12:42:28 »
Quote from: kishy;147846
Hey, here's a question of marginal relevance...
Do Model F terminal keyboards all use the Model F capacitive buckling springs?
I have yet to see the insides of a Model F terminal board so...yeah. Presumably they do, but it'd be nice to know for certain.
See my sig for the particular Model F I'm wanting to get.  It has the hat keys, old barcode/serial no label, and a 1984 build date.
Current:
Offline ch_123
« Reply #4 on: Mon, 04 January 2010, 12:47:52 »
Yep. After all, they came out before the membrane buckling springs were invented.
Oddly enough, production of some Model F terminal boards continued as late as 1994 with even Lexmark making Model Fs. No drainage channels though =P
Offline sethstorm
« Reply #5 on: Mon, 04 January 2010, 12:53:09 »
Quote from: kishy;147856
Looks like a nice board (found it on RecycledGoods' website)
Everything about the exterior would suggest Model F-style guts, and with Model Ms not being out yet...
Still won't know for absolute, complete certain until someone opens one up and takes photos, I suppose. Unless it's already been done?
Got the Model F.  The unbelievable Unicomp link's going to Ebay Finds.
Forum Post
« Last Edit: Mon, 04 January 2010, 13:51:03 by sethstorm »
Current:
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #6 on: Mon, 04 January 2010, 13:42:31 »
I've been looking for one of those Model F's for a while now! I see there are some available on recycledgoods. Thanks for pointing them out!
Offline Oqsy
« Reply #7 on: Tue, 05 January 2010, 02:23:00 »
I'm confused...  will the Model F terminal boards even work on a PC?  Perhaps I missed something.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline sethstorm
« Reply #8 on: Tue, 05 January 2010, 07:33:59 »
Quote from: microsoft windows;147876
No problem.  It's that it's been there for a while on my sig as well as it has been on the site.
Since I can't find where my XT Model F is, this one will have to do.
Current:
Offline ch_123
« Reply #9 on: Tue, 05 January 2010, 12:29:04 »
Kishy - does the 122-key Model M use a Berg connector for the keyboard cable connection?
Incidentally, if you don't have an AT Model F cable to hand, here's some info that should let you make your own.
Link.
Offline ch_123
« Reply #10 on: Tue, 05 January 2010, 12:40:30 »
As far as I remember, the XT one doesn't use a Berg connector, and instead uses a simple flat 4-5 pin connector not a million miles unlike the ones used in modern keyboards.
EDIT:
« Last Edit: Tue, 05 January 2010, 12:45:50 by ch_123 »
Offline sethstorm
« Reply #11 on: Tue, 05 January 2010, 14:20:44 »
Quote from: ch_123;148157
If it is what I think it is, and the Terminal F uses it, it will make my life a whole lot easier.  I've got no proper Berg strip for the Terminal F that I have, and I'd certainly like to know of a good source of the proper pins.
I want to do it the completely right way, not the "2 sets of 1x3" way.
Quote from: kishy;148149
sethstorm, awesome to see you're getting the F. won't expect anything, but i think a photographic breakdown of the guts would be neat to see :)
That will happen.  I just hope that they've shipped it by now - it should be far enough outside "the holidays" to have that as a problem.
Does that mean you want the RAW's off my camera too?
(just kidding about that, but if you really *do* want the 8MB files, I'll be more than happy to have those linked in as well.)
« Last Edit: Tue, 05 January 2010, 14:27:15 by sethstorm »
Current:
Offline sethstorm
« Reply #12 on: Tue, 05 January 2010, 14:26:13 »
Current:
Offline sethstorm
« Reply #13 on: Tue, 05 January 2010, 14:31:51 »
Quote from: kishy;148204
If you find a source for those berg connectors and need a bulk order (as I suspect you will), I'd be in for some (~10 if the price was reasonable, say under 50 cents a piece)
ch_123 showed the connector style for the Model F XT and I quoted it above; is the image not showing up for you? Maybe photobucket is imposing regional viewing limits
That's not to say that's what a terminal board would use, but there's a good chance it is.
The problem is that I don't know where I can find the uncrimped ones - it would save on me soldering up wires to what I have that does fit.  Should someone else know at the moment, I'll gladly order up 50(or whatever the lowest price break is) of them and split/sell as needed.
Another problem is that I don't exactly know where my Model F XT is at the moment to check.  I've torn into a Monterey rubber membrane, a cheapish IBM rubber membrane, and no dice.  Either they have some 1x4 connector that's strange but has ground, or it's soldered straight into the interface board.
« Last Edit: Tue, 05 January 2010, 14:34:06 by sethstorm »
Current:
Offline JBert
« Reply #14 on: Tue, 05 January 2010, 15:43:15 »
For what it's worth: berg connectors were used for connecting quite some kinds of stuff in the original IBM PCs. Because our modern PCs are still largely "PC compatible", you can still find connectors of the same family on ATA cables, floppy cables, jumpers and CD-drive-to-audio-card cables. The trademark of the Berg connector is the square hole with the square pin.
I would advise against making them yourself because I read it is hell to assemble. You can buy the connectors and little pins (mostly sold in a bag of 100), but you'd also need some special tools as those little pins are allmost impossible to clip on to wire without those tools and some experience.
At one point I wanted to hard-wire my model F XT to a parkbd adapter so I took a similar connector with 2x9 pins and simply cut off 2 rows. If you take an ATA cable (everyone uses SATA nowadays) and split it into two with an exacto knife, you might get the same result. Wire up the right strands, get rid of the others and solder it to a regular keyboard cable. Simple and cheap!
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ricercar
  • mostly abides
« Reply #15 on: Tue, 05 January 2010, 16:17:53 »
The original IBM PC has an unused port cutout on the rear of the case, with the label L. The IBM engineers didn't have an exact use for it, yet: it was for (L)ater.
Offline sethstorm
« Reply #16 on: Tue, 05 January 2010, 17:21:09 »
Quote from: JBert;148222
I did that kind of crimping for the keyboard I have now; I would still agree that it's not easy.  The worst of it aside from crimping is stripping enough wire (and keeping it there) for the connector to use.
I have no shortage of pre-crimped stuff, but I find it a lot more easy/durable to not solder wire-wire.
Current:
Offline sethstorm
« Reply #17 on: Tue, 05 January 2010, 18:45:01 »
Quote from: ripster;148263
I think I got the stuff at Mouser.  Don't remember it being all that hard to work with.
Looking for it, and not seeing the exact strip; only seeing the connector side.
What I'm looking for is the metal part that needs to be crimped on the wire.
« Last Edit: Tue, 05 January 2010, 19:03:55 by sethstorm »
Current:
Offline Hak Foo
  • Make America Clicky Again!
« Reply #18 on: Tue, 05 January 2010, 23:36:18 »
Quote from: ripster;148336
I think I got it here. Hope these are the right ones - they worked for motherboard connectors and some custom cables I built (Xfi to front panel IIRC).
They're not too terrible to do if you start with ribbon cable and appropriate plugs.
I did some cables for front-panel display modules ($20 surplus VFD >>>>> $50 pre-made LCD kit) with ribbon cable and these boys :http://web-tronics.com/connectors-2-row-0-1x0-1-female-idc-socket-connectors.html
However, I don't know if you can get ribbon cables for one-row plugs, or only two-row ones.
Overton130, Box Pale Blues.
Offline sethstorm
« Reply #19 on: Wed, 06 January 2010, 04:15:25 »
Those should be - got a sizable sum of them.
CH_123:
You are correct about that - it does use those connectors.
Current:
