Author Topic: Ducky shine mini  (Read 1823 times)
Offline djellybeans
Ducky shine mini
« on: Wed, 20 July 2016, 16:31:46 »
Hello guys!
After using the Noppoo choc mini for over 3 years I am ready to get myself a replacement keyboard. Since I loved the noppoo so much i figured i'd go even smaller and purchase the ducky shine mini.
I have been surfing the internet and I don't seem to be able to find any ''reputable'' sellers yet. I was wondering if you guys might know some reputable sellers and if you could point me in their direction that would be much appreciated.
Regards
Offline Peripheral Prophet
  • Lets change the game
Re: Ducky shine mini
« Reply #1 on: Wed, 20 July 2016, 16:42:02 »
Hello guys!
Regards
You mean the ducky one rgb tkl?  MechanicalKeyboards.com sells them i think..
Check out my live build streams on twitch and join my discord! https://discord.gg/QzeSQj2  https://www.twitch.tv/peripheral_installer
Offline jerue
  • (Whenever that happens :P)
« Reply #2 on: Wed, 20 July 2016, 18:23:58 »
Hello guys!
Regards
I think OP is looking for the 60% mini, which some in-stock models are carried by mechanicalkeyboards.com. I have purchased through this retailer several times without issue - they also have a subforum here on geekhack :)
You can also try to purchase one second hand, either through ebay or posting a "Buying" post on reddit's mechmarket subforum. You can look through the Geekhack classifieds, but to make your own "Want to Buy" thread will require 25 posts/2 months membership to geekhack.
Good luck with your search, I just became reunited with the Mini and like this keyboard a lot!
« Last Edit: Wed, 20 July 2016, 18:26:07 by jerue »
