Author Topic: Something in-between MX Brown & MX Clears?  (Read 10571 times)
Offline Micdeez
« on: Mon, 25 July 2016, 18:58:25 »
All,
I've really grown into the enthusiast KB world, owning about 4 mechs since about 4 months ago.
Searching for really, the right switch.
I've tried the Ducky Legend in MX red, Ducky TKL in MX brown, Pok3r in MX clear and Leopold FC750 with MX browns.
I love the ease of use in MX reds, although a little too "easy" to press. I found the browns are quite good too, but essentially I find myself making lots of typos in both.
The MX clears in the Pok3r are great, as I make less typos (and the PBT caps are sweet), but I seem to tire out a little after some intense typing and gaming sessions (FPS mainly).
So what am I asking? Is there a switch lighter than the MX clears, and heavier than the browns? I bottom out on browns of course, less so on the clears most certainly.
I have heard of the ergo clear mod, but frankly having to de-solder and solder is a frightening thought on an expensive board...
Cheers
Re: Something in-between MX Brown & MX Clears?
« Reply #1 on: Mon, 25 July 2016, 19:00:30 »
Topre and Orange Alps could be to your liking.
Offline redbanshee
  • actually Dade Murphy
« Reply #2 on: Mon, 25 July 2016, 19:07:26 »
Im pretty sure any zealio switch is in that range.
Offline Micdeez
« Reply #3 on: Mon, 25 July 2016, 19:18:48 »
Thanks, I will have a look around
Not familiar with Zealio switches, but thanks I will look around also.
I think I like the TKL size factor the best.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #4 on: Mon, 25 July 2016, 19:25:10 »
+1 on da topre.
Offline xondat
  • i'm not a star
« Reply #5 on: Mon, 25 July 2016, 19:27:40 »
This is a question I meant to ask months ago. I still have lots of zealio to try out :))
Offline Micdeez
« Reply #6 on: Mon, 25 July 2016, 21:19:55 »
How is the feels!?
Offline xondat
  • i'm not a star
« Reply #7 on: Mon, 25 July 2016, 21:25:38 »
How is the feels!?
Well I have all weights on hand, and when I reach into the bags they're spiky.
I'll try the various weights soon  :))
Offline ideus
  • Björkö.
« Reply #8 on: Mon, 25 July 2016, 21:29:56 »
All,
Cheers
Welcome to the Ergo Clear's Club. What you need are Ergo Clears, the bump in the Zealios are too small and the plastic too soft to compare with Clears, they feel closer to browns than to clears, your choice, I have used blacks, reds, browns, clears, ergo clears and zealios, I'd take ergo clears any time.
Offline Micdeez
« Reply #9 on: Mon, 25 July 2016, 23:12:56 »
All,
Cheers
Thank you.
Are there any boards that won't require de-soldering? Like PCB boards? Or are most boards plate mounted?
Out of all of my boards, I like the Leopold FC750 the most, its built like a tank and looks really minimalistic
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #10 on: Mon, 25 July 2016, 23:20:45 »
All,
Cheers
Thank you.
poker x. which is what i currently use.
Offline ideus
  • Björkö.
« Reply #11 on: Mon, 25 July 2016, 23:23:27 »
All,
Cheers
Thank you.
There are some PCB mounted keyboards; but, sooner, or later, you will have to build your own board, when you do that you may choose either to mount your switches directly on the PCB, or find a plate with cut outs to allow tops removal, I think, this last option is the best route, because you will be able to remod the switches at any time, just the bottoms will be fixed, just be sure to use dip sockets for LEDs in case you use them.
Offline Micdeez
« Reply #12 on: Tue, 26 July 2016, 00:44:27 »
All,
Cheers
Thank you.
Cheers mate, good tips. Considering going into the modding scene, just need to read up a bit more on the tutorials.
Could I get a plate for the Leopold FC750? Or are these custom plates for certain boards only?
Offline Jpecina
« Reply #13 on: Tue, 26 July 2016, 01:23:32 »
Topre might be what you're looking for. To me, it feels nicer than my MX browns.
Offline ideus
  • Björkö.
« Reply #14 on: Tue, 26 July 2016, 01:23:34 »
All,
Cheers
Thank you.
There are some TKL plates around; but, I am not familiar with TKL components, because I am a sixty user. I am sure someone may answer that question here, or you could post the question at "Simple questions simple answers" thread.
Offline repuls0r
« Reply #15 on: Tue, 26 July 2016, 01:51:30 »
Zeals definitely.  67g
Matrix 8XV1.0  |  FMJ 80  |  SKOG  |  TGR Jane CE  |  Orion V2  |  Mech27  |  LZCP  |  TXCP  |  CPSQ  |  TX1800
Offline klennkellon
  • I like bottoming out
« Reply #16 on: Tue, 26 July 2016, 06:49:42 »
Matias Quiet Clicks or SKCM Orange ALPS. They're both weighted around 60-65g and are even more tactile than MX Clears.
MX Browns are poop compared to almost anything, though.
Offline Micdeez
« Reply #17 on: Tue, 26 July 2016, 23:00:38 »
Thanks your input, this kb looks right up my alley, its TKL and black...
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1603
I have no idea on the quality of KBP products. Are they up there with Leopold/Ducky?
Offline klennkellon
« Reply #18 on: Wed, 27 July 2016, 00:56:56 »
I have the V80 with Matias Quiet Clicks, it's a pretty solid board all around, has a decent weight and little flex to the case with barely any creaking.
I'd recommend you spend a little more on the versions with the Tai-Hao doubleshots because the stock caps are mediocre.
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #19 on: Fri, 29 July 2016, 00:14:37 »
Ergo Clear Mods.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #20 on: Fri, 29 July 2016, 00:20:00 »
Yup i can confirm. I have a brown, clear, and 67g zealios next to each other on a switch tester and i can confirm the 67g Zeal is right in between the two as far as weight.
-Dana
Offline klennkellon
« Reply #21 on: Fri, 29 July 2016, 00:51:43 »
Do the Zealios still have wimpy tactilty? It seems unavoidable in MX switches because of the way they are designed.
« Reply #22 on: Fri, 29 July 2016, 01:40:17 »
I found blues/reds way too light.
Then I found clears a bit too heavy, but after a month or two I am happily bottoming out on them all the time :)
Perhaps give yourself a couple more weeks with the clears and see what happens.
Offline OfTheWild
« Reply #23 on: Fri, 29 July 2016, 20:19:46 »
I mean they're not as big a lump as say the mx clear but they're definitely getting you that "cards in your spokes" kinda feel when you're really going at a paragraph.
-Dana
« Reply #24 on: Fri, 29 July 2016, 20:28:46 »
The cheapest and easiest and completely reversible way to adjust feel is with O-rings.
Give them a try on both brown and clear and you may hit on something you like very easily.
http://www.ebay.com/itm/150x-White-Keycap-Silicon-Rubber-O-Ring-Switch-Dampeners-For-Cherry-MX-Replace/331456707767
- D Trump 2026-10-24
Offline ideus
  • Björkö.
« Reply #25 on: Fri, 29 July 2016, 20:40:46 »
In my experience, the o-rings just turn the feel into a mushy one, that's all, I do not know if someone likes it, but not me, the feeling is awful. Talking about reversibility, if you have a plate with cut outs for top removal, any change in the stem and springs is reversible. Also with PCB mounted switches.
« Reply #26 on: Fri, 29 July 2016, 20:50:40 »
Cherry sucks, of course, but O-rings are generally an improvement, it would seem to me.
Reduced travel, attenuated noise, quicker bounce-back, what's not to like?
My son, the gamer, (MX black in a Filco TKL) likes the tightening and quickening that they give him.
Offline ideus
  • Björkö.
« Reply #27 on: Fri, 29 July 2016, 20:56:20 »
Interesting way to put it, I'd say, instead, that I like MX switches, the travel, the noise the feeling of them bouncing; but, o-rings make them more similar to a rubber dome, short travel, mushy noise, less spring back,  :)) .
Offline alienman82
« Reply #28 on: Fri, 29 July 2016, 21:28:24 »
removed.
« Last Edit: Thu, 01 March 2018, 14:58:45 by alienman82 »
Offline [Lewynlight]
  • Formerly Dymloslouire
« Reply #29 on: Sat, 30 July 2016, 08:36:00 »
try ergo clears, zealios, or topre.
i was on the same boots as you.. faced with the decisions, and went with topre as a result.
fortunately, i didn't regret my choice.
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline BucklingSpring
« Reply #30 on: Mon, 01 August 2016, 16:24:01 »
Here another vote for Matias quiet tactile.
Boards I own, click ->
Offline Micdeez
« Reply #31 on: Mon, 01 August 2016, 19:03:40 »
Update guys.
So I tried the Matias QC's the other day through a friend of a friend that owned a V80 TKL.
Argh... Disliked them. They felt mushy and just simply didn't feel right IMO.
So I'm thinking. I like my Leopold FC750RT and the MX Browns. Thinking about lubing them up and adding sticker vinyls on the switches and clipping the modifier stems. I really do like my 750R.
Q - Would lubing MX browns almost feel like a red switch? I really want to make the browns more buttery smooth before I invest in another switch board.
I do like the sound of the Zealios though; this could be my next switch.
Offline Micdeez
« Reply #32 on: Mon, 01 August 2016, 19:08:06 »
I forgot to add too, I tried Topre for the very first time.
It is indeed a great switch. Black Realforce 87U 55g uniform.
Switches were just buttery smooth and nice and tactile.
I think the only thing swaying me from buying one is the lack of availability of keycaps and non-removable USB cable. Moreso the former being heavily influenced....
I would also think Topre would work fine for gaming too.
Offline Hypersphere
« Reply #33 on: Mon, 01 August 2016, 19:26:15 »
A good thing about Topre is that the caps are perfectly designed to form a functional unit with the switch. Topre switches have become my tie for favorite, alongside IBM capacitive buckling spring (Model F) switches.
Next in line are various Alps and Alps clones, including Matias Click and Matias Quiet Click.
Never could find a Cherry mx or clone that I liked until I tried Gateron yellow switches. Cherries and their clones are inherently linear, so it made sense to gravitate to an unfettered linear switch. For me, the Gateron yellows occupy a sweet spot in actuation and bottoming-out force, and they are very smooth.
Nevertheless, although I find it fun to rotate through my collection, I always come back to my all-time favorite, a HHKB Pro 2 with silenced and lubed Topres.
However, if you like Cherry mx and the grafted-on tactile bump in browns and clears, but you find the browns too light and the clears too heavy, you might try ergo clears or Zealios with a suitable spring weight.
Offline Micdeez
« Reply #34 on: Mon, 01 August 2016, 19:44:59 »
Thanks man, I agree Topre was a nice experience when I demo'd the 55g uniform variant.
Again, I feel like if they had more aftermarket caps for them, or approached it like CM with their Nova hybrid stems, that would be awesome.
I might still try lubing the MX browns to see if I can get it buttery smooth, should I expect this result when lubing browns?
I found some pretty good soldering stations (inc a hot air gun), I think its a Hakka brand or clone for $50 from eBay.
Offline Micdeez
« Reply #35 on: Mon, 01 August 2016, 22:44:54 »
Hey guys, so just affirmation on lubing the browns, would they become a lot smoother, similar to reds, or am I just wasting my time?
Also interested to hear if anyone has opened up their FC750R so I know what to expect without breaking any plastic!
