Author Topic: IBM 13994428?  (Read 2308 times)
Offline Aran.E99
IBM 13994428?
« on: Tue, 26 July 2016, 11:34:15 »
hi guys,
i'd like to know if anyone knows about an IBM Model M 13994428. it was made in 1993, has no lock lights and has the blue logo in the left corner. I can't seem to find anything about it. the closest keyboard i can find is the 1395665. any info would be great i.e. what type of switches it uses and what system it ran off (probably a terminal)
-Aran
SMK 2nd Gen Blue Alps mount <3
Offline E TwentyNine
    • Some of My Keyboards
Offline Aran.E99
Re: IBM 13994428?
« Reply #2 on: Tue, 26 July 2016, 11:49:42 »
thats it! thanks!
firstly, whats it worth, second, can it work with a pc (with a teensy) and finally, is it buckling spring?
-Aran
Re: IBM 13994428?
« Reply #3 on: Tue, 26 July 2016, 11:52:13 »
It says right in the link it's a Buckling Spring board and it should work with a teensy yes. Terminals are generally cheaper than regular Ms.
Offline Aran.E99
Re: IBM 13994428?
« Reply #4 on: Tue, 26 July 2016, 11:54:41 »
thanks, didn't see the link fully, just clicked on it to check  :-[
