Author Topic: Heaviest universal 60% case?  (Read 4616 times)
Offline snarfarlarkus
« on: Thu, 28 July 2016, 20:23:19 »
Just bought a custom 60% board but want an aluminum case due to heavier heft and I just prefer heavier boards as my daily is a Model F. It also makes the keystroke feel more solid? Cheers
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: Heaviest universal 60% case?
« Reply #1 on: Fri, 29 July 2016, 00:15:52 »
I believe any of the aluminum cases are pretty heavy. It looks like most have a cut out underneath that you can use to add an additional block of metal if you wanted? Not really sure what thats actually for, i've just seen people machine out some fancy signature type stuff and screw it on underneath.
-Dana
Offline redbanshee
  • actually Dade Murphy
« Reply #2 on: Fri, 29 July 2016, 00:31:45 »
I would say the most readily available and heaviest is the iQunix Lambo case. Beyond that would be the Duck Viper/Eagle but those are hard to find. The TEX cases are no where near as heavy as the Lambo
« Reply #3 on: Fri, 29 July 2016, 00:41:22 »
You'd have to look towards a steel case to get model F heft. You'll have trouble finding one of those, I think.
Offline Diokhan
« Reply #4 on: Fri, 29 July 2016, 00:42:26 »
the cast alu cases from poker are the heaviest I think
Offline klennkellon
  • I like bottoming out
« Reply #5 on: Fri, 29 July 2016, 00:52:43 »
You'd probably need to mold your own 60% case out of pure lead to get the same heft of a Model F in a 60%. Like a really giant rectangle shaped bullet. xD
Offline bocahgundul
  • a seal
« Reply #6 on: Sat, 06 August 2016, 02:40:36 »
Hammer case and FMJ case that is the heaviest one for universal 60% case
Offline Leslieann
« Reply #7 on: Sat, 06 August 2016, 17:25:12 »
I have Model Ms, aluminum Filcos (heavier than the Model M), heavy Black Widows, older Das, lightweight Vortex Race, and a Magicforce.
I used to want heavy because i thought it equaled stability. which the Vortex cased Filco provided, but after getting the Magicforce, I found that's not actually true. It's not a matter of weight, it's a matter of stiffness and quality of the feet. Get a good stiff case with some good sticky feet under it to keep it planet, and you won't need a really heavy case. Granted, in most cases a good, stiff case = weight, but it doesn't have to be. Take a poorly made aluminum 60% case that doesn't support the PCB and it will do little to make it feel any better than the plastic case.
Point is, don't be concerned so much with the weight, but more about how stifff the overall keyboard is. The Race had a plastic case, no plate, the Magicforce has a plastic case, with an aluminum plate, the Magicforce feels stiff as heck while the Race feels like a wet noodle. On the other hand, the stock Filco (TKL), Das (TK) and Black Widow (TK)were stiff at the keys, but the cases flexed, the Filco and Das much less so due to better case and feet construction.
I would love to see what a well made carbon fiber case, with aluminum Plate would feel like, should be fantastic.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
