Author Topic: [IC]GMK Hydro (closed)  (Read 273516 times)
Offline Auxo
  • Formerly CJD_Anthony
Re: [IC]GMK Hydro 🐳💦🌊 (Launches for GB Sept 19, 2016).
« Reply #350 on: Mon, 12 September 2016, 18:49:46 »
I wonder how this set would look with electric bluegaloo mods
Offline baloo25
« Reply #351 on: Mon, 12 September 2016, 20:09:54 »
These look great! Can't wait for the GB
Offline WarCommand
« Reply #352 on: Wed, 14 September 2016, 05:54:22 »
Getting close.  ;D
Offline rotciveel
  • Fugu Curator Extraordinaire
« Reply #353 on: Wed, 14 September 2016, 10:08:47 »
Will pricing be revealed before the drop?
Offline ideus
  • Björkö.
« Reply #354 on: Wed, 14 September 2016, 10:22:31 »
This will run over keyclack, not MD.
Offline rotciveel
« Reply #355 on: Wed, 14 September 2016, 10:26:16 »
Oh, I was just using the word drop as in, the group buy is dropping  :)
Offline ideus
  • Björkö.
« Reply #356 on: Wed, 14 September 2016, 10:46:11 »
I see, my bad, I associate it with that other site.
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #357 on: Wed, 14 September 2016, 13:56:42 »
Yes! It will be revealed tomorrow, or later today. I just got pricing updates from gmk a few moments ago but I'm in the middle of something at this moment.
First post will update with everything!
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline Moistgun
  • Slippery When Wet
« Reply #358 on: Wed, 14 September 2016, 13:57:39 »
YUUUUUUUUUSSSSSSS
Offline rotciveel
« Reply #359 on: Wed, 14 September 2016, 13:58:45 »
It's all good :) I can see the confusion
Awesome! Looking forward to it! Hope it's a pleasant number! :p
Offline lawnzie
« Reply #360 on: Wed, 14 September 2016, 14:24:28 »
I might be dumb but does a B.mini x2 count as a standard 75%?
 i really wanna use this set on a b.mini
« Reply #361 on: Wed, 14 September 2016, 14:33:22 »
Yes.
Offline Grissnap
« Reply #362 on: Wed, 14 September 2016, 17:25:24 »
Registered, because I am super excited about this set. Just curious regarding the spacebars - in the description it says it supports FC660M, but some Leopolds have different spacing for the stems. Will the spacebar having support these different spacings? It'd be nice to have but not holding my breath.
Offline ideus
  • Björkö.
« Reply #363 on: Wed, 14 September 2016, 17:36:14 »
The original version of the FC660M's had the space bar's stems in non standard positions; so, if you have one of those these bars will not fit it. No standard space bar does. When I had one of those boards I got some PBT blank sets at Tai Hao that carry compatible space bars.
Offline Grissnap
« Reply #364 on: Wed, 14 September 2016, 17:48:23 »
Alright that makes sense, I figured that might have been the case. I'm okay with leaving the spacebar as is (or possibly modding a spacebar to work). Thanks for the response... now just waiting for that price update.
Offline ideus
  • Björkö.
« Reply #365 on: Wed, 14 September 2016, 17:54:36 »
It was really unfortunate that those nice boards were built with such a glitch, actually that was the main reason I sold it, it was really annoying not being able to use full sets with it, the other non standard features are that you will need two 2.25u shifts and 1u window or similar key for the bottom row, while these are not as annoying like the space bar issue, they are still silly.
Offline ahtan
Re: [IC]GMK Hydro 🐳💦🌊 (Launches for GB Sept 19, 2016. Pricing Updated)
« Reply #366 on: Thu, 15 September 2016, 08:38:33 »
any idea if the fc660m coverage will be for the original spacebar or the newer version?
« Reply #367 on: Thu, 15 September 2016, 08:51:27 »
YES! THE TOP ROW IS PERFECT NOW!
Offline maximm
« Reply #368 on: Thu, 15 September 2016, 08:57:28 »
Oh lord, thank you for saving the upper row this night. Our wish have been granted!
Offline tofgerl
« Reply #369 on: Thu, 15 September 2016, 09:04:17 »
Does anyone know how the alphas will compare to the TA alphas? I haven't been able to find TA color codes - I know the mods were color matched against the originals, but were the alphas customs as well?
Offline ideus
  • Björkö.
« Reply #370 on: Thu, 15 September 2016, 09:14:01 »
The updated version of the FC660M is known to use standard stems 6.25 space bar; thus, any standard space bar of that size would fit it, including GMK's that are standard, also. Very few space bars fit the stem positions of the original FC660M.
Here is a picture of the sample I owned that shows the stems and a picture of the space bars that I had that fits it, I found that neither GMK nor SP space bars fit it.
Original version of the FC660M.
Space bars that fit the odd stems of the original FC660M, the gray one is the original Leopold one, the white above it fits them, as well as the black one, the other white is from a Skull Squadron set that as you can see does not fit the stems.
« Reply #371 on: Thu, 15 September 2016, 09:20:48 »
From the looks of it, the alphas on TA will be just a smidge darker.
Offline tofgerl
« Reply #372 on: Thu, 15 September 2016, 09:22:09 »
Good. If they were identical, I don't think I would have been able to talk myself into buying this kit ;)
Of course the mods are extremely different, but they really only take up 30% of the 60% keyboard...
Offline WarCommand
« Reply #373 on: Thu, 15 September 2016, 09:45:27 »
Solid pricing fam
Offline ideus
  • Björkö.
« Reply #374 on: Thu, 15 September 2016, 10:45:12 »
$$$ Ouch! This is out of my budget, I am afraid.  :(
Offline WarCommand
« Reply #375 on: Thu, 15 September 2016, 10:55:17 »
This is relatively tame for a GMK pack with this many options...
Offline duynguyenle
  • Personal text? What personal text???
« Reply #376 on: Thu, 15 September 2016, 11:15:25 »
It is a bit more than I was hoping, I'm probably going to have to drop the novelties pack and just go for Base  :(
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
« Reply #377 on: Thu, 15 September 2016, 11:17:27 »
Yeah, same. If I can squeeze the novelties, great, but definitely have to secure the base kit.
Offline Moistgun
  • Slippery When Wet
« Reply #378 on: Thu, 15 September 2016, 11:17:56 »
Only ever was eyeing base in the first place.
Do we have any idea it it will break 500?
« Reply #379 on: Thu, 15 September 2016, 11:24:52 »
Yeah, just jump into the future and check for us.  ;)
Offline jchan94
  • Keyclack Inc
    • KeyClack
« Reply #380 on: Thu, 15 September 2016, 12:49:50 »
Hope to see you join! For the number of keys, compatiblity, we think the price is pretty fair as they all include trays to prevent damage.
I definitely believe we can break 250 as we have kingnestea, a member of camp team china to help us run internationally;)
Offline tofgerl
« Reply #381 on: Thu, 15 September 2016, 12:54:22 »
Oh, the ****ING trays...
Offline Moistgun
  • Slippery When Wet
« Reply #382 on: Thu, 15 September 2016, 12:57:35 »
Could you please elaborate?
im not familiar with GMK or keycaps in general
Offline jchan94
  • Keyclack Inc
    • KeyClack
« Reply #383 on: Thu, 15 September 2016, 12:59:05 »
Also!  Gmk has informed me that the trays have been updated to include more locking mechanisms so keycaps don't spill in transit!
Photo to follow soon.
Offline Fictiouz
  • That "White" Guy
« Reply #384 on: Thu, 15 September 2016, 13:49:19 »
Will there be a limit on the number sold? Also how long do you project the group buy being open?
« Reply #385 on: Thu, 15 September 2016, 13:55:36 »
Long enough for me to get the funds to order one.  :cool:
Offline Moistgun
  • Slippery When Wet
Re: [IC]GMK Hydro (Launches for GB Sept 19, 2016. Pricing Updated)
« Reply #386 on: Thu, 15 September 2016, 13:59:00 »
It said in the op before that it would be open for like 4-5 days I think? I may be high. IDK
He also said you can get a number of sets, as long as you don't seem like a flipper.
« Last Edit: Thu, 15 September 2016, 14:05:32 by Moistgun »
Offline duynguyenle
« Reply #387 on: Thu, 15 September 2016, 15:00:30 »
2 weeks
Offline Auxo
« Reply #388 on: Thu, 15 September 2016, 15:49:02 »
$150 hollllyyyyy
Offline MediocreBadGuy23
« Reply #389 on: Thu, 15 September 2016, 15:56:19 »
$150 hollllyyyyy
How's that compare with other GMK set?
Offline duynguyenle
« Reply #390 on: Thu, 15 September 2016, 16:07:30 »
$150 hollllyyyyy
It's pricey, but not unreasonable TBH, GMK sets tend to be pretty expensive anyway.
Offline Vigrith
« Reply #391 on: Thu, 15 September 2016, 16:17:57 »
Yea I just paid $130 a few weeks ago for Keyboard & Co GMK which had basically the exact same keys included as this one does - $150 doesn't sound unreasonable to me personally, it's expensive of course but GMK is expensive.
Offline jchan94
  • Keyclack Inc
    • KeyClack
« Reply #392 on: Thu, 15 September 2016, 16:20:13 »
* Almost the exact same keys.
This has 20 more keys for ultimate compatibility and the pricing includes trays. Gotta keep these babies safe of we'll have another TA issue.
Updated Trays that are included:
« Last Edit: Thu, 15 September 2016, 16:27:36 by jchan94 »
Offline Vigrith
« Reply #393 on: Thu, 15 September 2016, 16:33:21 »
Oh yea, you're right, my bad I was just saying it off memory - you have more layout flexibility and a few extra top row keys, yep.
Wasn't accounting for the tray, still, even if it didn't include it the price would still be very competitive, especially if 250 sets are reached for both the base and novelties with Nestea and the Chinese community's help. Plus the stickers, let's not forget the godlike stickers!  :eek:
Offline Auxo
« Reply #394 on: Thu, 15 September 2016, 16:42:33 »
I'm goin in deep on this, catch me on the other side fam
Offline duynguyenle
« Reply #395 on: Thu, 15 September 2016, 16:48:28 »
No one's doubting you jchan  :thumb: but I can't quite make my budget fit both base and novelties so...  :(
Offline jchan94
  • Keyclack Inc
    • KeyClack
« Reply #396 on: Thu, 15 September 2016, 16:51:03 »
:D glad to see you on board regardless!
Offline chuckdee
« Reply #397 on: Thu, 15 September 2016, 18:33:48 »
Exactly this.  A lot dropping this month- keyboards and keysets.  And I have to save for Nantucket Selectric too.   Now, I'm glad I didn't get Ice Cap!
Offline ahtan
« Reply #398 on: Thu, 15 September 2016, 22:43:52 »
cheers! thanks man! appreciate it!
Offline Mr_BeastQuake
    • Reddit
« Reply #399 on: Thu, 15 September 2016, 23:19:18 »
Matching cables available with purchased keyset? I mean blue, grey, and white aren't too tough to match but.. ya know. Sometimes people just like decisions to be made for them.
