Author Topic: Power surge on hub port  (Read 3388 times)
Offline eksuen
  • Ambassador of explosions.
« on: Sat, 06 August 2016, 00:19:50 »
Did I fry my PCB somehow?  :(
Re: Power surge on hub port
« Reply #1 on: Sat, 06 August 2016, 03:20:16 »
Power surges usually fry things properly - does it smell bad?
Offline eksuen
« Reply #2 on: Sat, 06 August 2016, 03:30:08 »
No bad smell. There was no indication that anything was fried until I plugged in the USB and got the error "Power surge on hub port. A USB device has exceeded the power limits of its hub port."
« Reply #3 on: Sat, 06 August 2016, 03:34:49 »
That's good - the computer noticed a problem and tried to stop it so you're probably fine.
That message usually means you have a short but without knowing the schematic of the hub it's hard to say if it's the hub itself or whatever you plugged in to it.
Offline eksuen
« Reply #4 on: Sat, 06 August 2016, 12:30:57 »
I did try the PCB on another computer and got the same results, which leads me to believe it's a problem with the PCB.
« Reply #5 on: Sat, 06 August 2016, 17:23:06 »
Oh so it's complaining when you plug the PCB straight into the computer port?  Yes that's a PCB/cable problem.  Most commonly seen when someone uses a TRS cable between Ergodox halves instead of a TRRS...
Pic of the USB socket on the PCB?
Offline eksuen
« Reply #6 on: Sat, 06 August 2016, 18:57:24 »
Some quick shots. Not sure what to look for.
« Reply #7 on: Sat, 06 August 2016, 19:09:51 »
That looks fine.  Have you tried the cable in something else to be sure it's the PCB?
Other than that I guess more details can't hurt - what PCB is it?  Did you do something abnormal to it (adding LEDs to a board that came with none)?
Could also be shorting to the case, if that's metal?  Try it out of the case if you haven't already.
Offline eksuen
« Reply #8 on: Sat, 06 August 2016, 20:49:20 »
The cable is fine. I tried it with another keyboard and there are no problems.
It's an Octagon V2. I added 1.8mm LEDs but that shouldn't be an issue. There was one LED connection that wasn't working. I tested the LED so it wasn't the LED itself. I reflowed the joints, tried again, and got the error.
It's not in a case yet. The metal in the picture is the plate.
Offline eksuen
« Reply #9 on: Wed, 10 August 2016, 00:18:30 »
Did not fry PCB. There was an LED with defective pads that was somehow creating a short. Desoldered that LED and functionality returned. So I just have no LED on my left Ctrl. Oh well.
