Author Topic: Glorious Modular Mechanical Keyboard Released (Hot-Swappable Switches)  (Read 42415 times)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: Glorious Modular Mechanical Keyboard Released (Hot-Swappable Switches)
« Reply #50 on: Thu, 01 September 2016, 03:49:45 »
This is possible to do, but not the route we are planning to take right now. Maybe in the future or as a stand-alone barebones kit option.
If you offer it as a barebones kit, watch yourselves being inundated with orders from all the Keyboard Nerds out there.
Having possibly the only removable ALPs switch keyboard in the market, will make you KINGS amidst the keyboard fraternity  8) .
Offline Glorious
  • * Commercial Vendor
« Reply #51 on: Tue, 06 September 2016, 15:12:26 »
Ideally, in the future, we would like to have it setup where you can select your base body (full, tkl, compact), select switches (optional), select keycaps (optional).
Currently exploring options for PBT keycap set.
Offline pchatterjee
« Reply #52 on: Sat, 10 September 2016, 11:27:40 »
Any chance you guys would sell this keyboards with mx-clears? Or have MX-clear as an option on your website?
Also, anyone know which type of Alps the old apple m3501s (apple Extended keyboard IIs -- they were my favorite switch other than buckling spring) had and if those switches are available for purchase anywhere?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #53 on: Fri, 16 September 2016, 17:01:53 »
from experience swapping switches in and out of plates (i test all my plates when i make them with switches) the little clips switches use to hole themselves to the plate (for dear life) will be damaged when removing them. so i guess the question is does this board hold the switches securely enough to re-use switches once they have been pulled from the plate more than once. if so about how may times in your experience? full switch removal usually happens when swapping key caps. happened to me before.
also when are you going to get Terry Cruze for your mascot?
i ask ... because reasons
That pick made my day  :)) Terry Crews with the bear glove ***** slap!  :p
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #54 on: Fri, 16 September 2016, 17:09:55 »
Offline Glorious
« Reply #55 on: Mon, 26 September 2016, 01:25:37 »
Currently on Massdrop. Drop will end in about <24 hours:
https://www.massdrop.com/buy/glorious-modular-keyboard-gateron-brown
Offline Glorious
« Reply #56 on: Tue, 04 October 2016, 10:21:16 »
Another review by Rhinofeed:
Offline mushman
« Reply #57 on: Sun, 09 October 2016, 15:57:47 »
Since I'm not an accountant I will wait for the tenkeyless version.
Offline JDragon
« Reply #58 on: Mon, 10 October 2016, 01:07:31 »
I'm an accountant and waiting for the TKL version. :P
Offline skuko
« Reply #59 on: Mon, 10 October 2016, 06:35:14 »
i am so buying a TKL version of this, the case design is awesome
Offline mushman
« Reply #60 on: Fri, 14 October 2016, 17:16:19 »
Glorious: Are you going to stock Gateron Yellows?
Offline Glorious
« Reply #61 on: Sat, 15 October 2016, 15:16:01 »
Nope. They are quite similar to blacks, and we decided to carry only one variant.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #62 on: Sat, 15 October 2016, 16:09:52 »
I'm still lost as to why Gateron made the Yellow switches
Offline mushman
« Reply #63 on: Sat, 15 October 2016, 21:10:10 »
From what I've read Gateron Blacks are like Vintage Blacks where you press and at the bottom of the key travel you feel more resistance  building up at the end.  With Yellows the key feel is supposed to feel more even throughout the entire keypress.
Offline mushman
« Reply #64 on: Sun, 23 October 2016, 11:20:41 »
My buddy bought one of these and we played with it for a bit for a better part of a day.
As the SNK Neo-Geo's slogan goes: THE FUTURE IS NOW.
If you're the kind of person that always "what if you combined this stem, with this spring, with this lube what would it feel like?" this is the board for you!  Even if you don't want to use it day in and day out it provides a platform for rapid prototyping of your "end game" switch.
Lately I've been gravitating away from Cherry MX/clones because of the "chattering" that can occur in time.  However replacing bad switches is stupid easy with this board.
As the Regular Car Reviewer would say, "I'm back in the high life again!"  :cool:
Offline klennkellon
  • I like bottoming out
« Reply #65 on: Sun, 23 October 2016, 13:44:14 »
I will definitely buy the TKL version! I am sold already.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #66 on: Sun, 23 October 2016, 14:01:44 »
I have to admit I am a bit enticed by a gateron green option
Offline 1391406
« Reply #67 on: Sun, 23 October 2016, 14:15:21 »
If and when a TKL version becomes available, I'll buy one.
Offline yoitsmegabe
« Reply #68 on: Wed, 26 October 2016, 18:17:20 »
This looks awesome. Any chance of a blue led or rgb version?
Offline Stevec
« Reply #69 on: Wed, 26 October 2016, 21:34:43 »
Or maybe make it hot-swappable for LEDs too? SIP Socket-ting every switch.
Offline Macsmasher
« Reply #70 on: Wed, 26 October 2016, 23:47:10 »
Cool idea. Without the switches being solidly married to the mounting plate, I wonder if that will change the feel. Or if they will loosen up over time.
Offline dilbertprogrammer
  • Keyboard Connoisseur
« Reply #71 on: Thu, 27 October 2016, 07:18:14 »
When purchasing switches to swap into this board, I surmise the recommendation would be to buy plate-mount switches?  Or buy PCB-mount switches and then snip the plastic legs?
Offline Glorious
« Reply #72 on: Thu, 27 October 2016, 15:07:26 »
Plate Mounted. The Gateron switch packs we sell on our site are all plate mounted. Snipping the plastic legs from a PCB-mount also works.
RGB version is development.
Offline Glorious
« Reply #73 on: Mon, 31 October 2016, 12:23:14 »
Another review:
Offline Erzegovaz
« Reply #74 on: Mon, 31 October 2016, 14:12:28 »
Good job! :D I really would like a 60% or TKL version :D I finally want try gateron and swap with cherry for feel the different...aaaaamazing
If u are searching one reviewer for Italy, contact me.  :thumb:
Offline pr0ximity
« Reply #75 on: Wed, 02 November 2016, 06:13:26 »
I can't believe someone made a brand out of that "master race" crap. It's childish and doesn't suggest a very high quality product.
Offline skuko
« Reply #76 on: Tue, 08 November 2016, 07:03:14 »
TKL! needs more TKL!
any news on the release timeline please? i read the "probably towards early 2017", do you have any more specific info since then?
« Last Edit: Tue, 08 November 2016, 07:06:02 by skuko »
Offline skuko
« Reply #77 on: Thu, 29 December 2016, 10:36:25 »
any news on the TKL version please? i really want one just for sake of the case design :)
Offline dante
« Reply #78 on: Thu, 29 December 2016, 11:04:39 »
^^^ me too.  I have o-rings/jspacers/keycaps either in hand or in transit for this.
Don't wait too long because the Input Club K-Type is coming!
Offline skuko
« Reply #79 on: Thu, 29 December 2016, 20:54:58 »
that's not hotswappable though.
Offline hking0036
« Reply #80 on: Thu, 29 December 2016, 21:08:52 »
It is, actually:
Oh wow they added an led strip. Still really want this especially after the decision to move to cherry stabs :)
We also added hot swappable switches.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline skuko
« Reply #81 on: Thu, 29 December 2016, 22:53:41 »
It is, actually:
it's not mentioned anywhere on this page https://input.club/
also, from the renders, it seems there will be costar stabs, which i'm not a fan of :(
Offline hking0036
« Reply #82 on: Thu, 29 December 2016, 22:55:07 »
Look at the thread here and you can find out more, they haven't updated the page for all their new stuff. Click on the quote I made in the last post and you can jump there.
Offline dante
« Reply #83 on: Thu, 29 December 2016, 23:02:05 »
Check out this article:
http://www.tomshardware.com/news/input-club-interview-mechanical-keyboards,33140.html
The K-type will be available early in 2017.
Offline clappingcactus
« Reply #84 on: Fri, 30 December 2016, 09:04:41 »
Nice. A USB-C fully programmable, full RGB control keyboard sounds perfect. Guessing I'll grab a PCB in January!
Although, I'm not really enjoying the brushed aluminium look. It looks cheap, though it certainly isn't!
Offline nyunyu
« Reply #85 on: Fri, 30 December 2016, 16:08:02 »
Is there any barebone ISO version?
Offline psiclone
« Reply #86 on: Mon, 11 September 2017, 11:53:40 »
I can't figure out what key sizes we have here are?  For instance, what size is the spacebar, etc?  I would like to order new keycaps for the GMMK I just ordered (I didn't order it with switches or keycaps, so I can't tell).
So I managed to find the answer.  It's (1.25)(1.25(1.25)(6.25)(1.25)(1.25)(1.25)(1.25) for those that want/need to know.
« Last Edit: Mon, 18 September 2017, 12:35:05 by psiclone »
Offline phinix
« Reply #87 on: Wed, 13 September 2017, 14:36:53 »
Any ISO plans for TKL?
Offline Merranza
« Reply #88 on: Thu, 14 September 2017, 09:06:37 »
This keyboard is close to perfection :)
I have absolutely no need for media keys (like those on the K70) but a volume wheel and a mute button are so handy (at the very least the volume wheel).
If the GMMK added that it would be amazing :)
Offline Nrocket
« Reply #89 on: Tue, 27 February 2018, 22:12:04 »
Can Kailh Speed Gold or Kailh Box switches be used with this keyboard? Sorry I am a total newb.
Offline klennkellon
« Reply #90 on: Wed, 28 February 2018, 01:30:54 »
yes
Offline lemur
  • personal text
« Reply #91 on: Sat, 03 March 2018, 03:02:46 »
I acquired one of these keyboard earlier this week.
I ordered the barebones TKL version.. which for the price (with referral code) of about $60 is very reasonable.
As has been said elsewhere, the stabilizers are pretty terrible out of the box. Clipping and lubing them improves them greatly.
The board itself is mostly metal, with a small plastic back.  There is a very tiny amount of flex in the case if you try and twist it, but it doesn't result in any sort of squeak or creak. If you weren't looking at it closely enough you would not even notice that it could be twisted slightly.
There is a bit of a hollow ring to the keyboard as is.. The case is easily taken apart with easily accessed screws on the top of the board, with no plastic clips.
The inside of the board is *very* cramped, If you're looking to fill it up with some stuff to deaden the noise, it will be a bit of a pain to get it all to fit.
I was able to get the board sounding *much* better with about 1 hour of work, dealing with the stabilizers, and filling what I could into the bottom of the case.
For those looking for a big fancy switch tester, this is a great board.
For people who are used to fancy customs maybe you'd be let down a bit..
If you're willing to either mess a bit with the stabilizers, or replace them with better ones,.. and address the hollow sounding case..  this board is a very serviceable board and I would say it is worth a buy.
(I am using SA caps and NovelKeys Kailh Box Heavy 'Pale Blue' switches on my unit, cannot say if the board is pleasing on anything else, also I have zero interest in the rgb lighting stuff, so cannot comment on if that is any good)
If I had any suggestions for manufacturer: Leave some more space in the bottom plastic case area so that folks who desire it can stiffen things up a bit in terms of acoustics.. or to add weight if they're into that sort of thing...  Also, use better stabilizers (or at least perhaps pre-lube the ones already offered?)
« Last Edit: Sat, 03 March 2018, 03:06:39 by lemur »
keyboards
Offline Nrocket
« Reply #92 on: Wed, 07 March 2018, 21:19:44 »
For someone new to Mech keyboards who really has only used a cheap $30 MX Brown board and has felt the Model F only once. Should the stabilizer issue be a deal breaker for me? I know nothing about lubing or soldering. I would just like to experiment with switches and have a solid keyboard for typing as a daily driver. Let me know if this would be something worth it for me.
