Author Topic: WTS Realforce 87UB 45/55g $190 shipped CONUS  (Read 1468 times)
Offline WOMBO
  • Trade Count: (0)
« on: Thu, 11 August 2016, 15:31:05 »
reddit timestamp: http://imgur.com/a/KQR2z
I'm down to do 180+shipping or 190 shipped, whichever is cheaper; pretty much what I paid for the board before shipping. Practically brand new (only reason it isn't, of course, is because I had to take it apart to dome swap). Works perfectly otherwise and comes in the original box with everything inside. Domes are 45g for esc+main board, 55g for caps lock, lctrl, fn row, homing cluster, and arrow keys. Basically 45g 60% and 55g everywhere else; you can see in the album which keys have the 45g domes.
Located in Massachusetts if that helps shipping-wise; I'll cut it out completely if you're local of course.
