Author Topic: Compact 101-key?  (Read 2260 times)
Offline Gurok
Compact 101-key?
« on: Thu, 11 August 2016, 22:28:03 »
Unicomp don't make anything smaller than the Classic in a 101-key layout. What are my options for a new, compact 101-key mechanical keyboard? Alternatively, is there a reasonably clean way to convert a 103-key Ultra Classic to a 101-key layout after the fact?
Offline klennkellon
  • I like bottoming out
Re: Compact 101-key?
« Reply #1 on: Thu, 11 August 2016, 23:35:49 »
By compact do you mean something that doesn't have excessive bezel? Most modern keyboards will usually have a quite clean and low profile case so that's not a problem, but 99% of them will be 103 and none of them buckling springs like the Unicomp.
Offline Gurok
« Reply #2 on: Fri, 12 August 2016, 01:58:15 »
Yes, something that doesn't have an excessive bezel. The Unicomp Ultra Classic fits the bill for me, but they only come in 103- and 104-key configurations. I was hoping it might be possible to cover up the windows and menu keys with either a custom plastic mould or maybe a spacer that kind of fits flush over the surface. I don't know if either of these things exist and are readily available.
Offline balotz
« Reply #3 on: Fri, 12 August 2016, 02:25:06 »
While it doesn't fit your criteria of 'new', the IBM model M2 has a very compact 101 key layout. Check the model number though as some of them are rubber dome.
Offline vincentalpha
« Reply #4 on: Fri, 12 August 2016, 02:35:21 »
I recommend you look into 96 layout. The potential is Red Scraf 96, Duck 96, ZZ96,etc. or winkeyles B.mini EX X2 PCB
Offline mike52787
  • Alps Aficionado
« Reply #5 on: Sat, 13 August 2016, 10:45:13 »
if you are interested in going with a model M2 I will be getting rid of mine soon, it has been cleaned, recapped and works like new.
« Reply #6 on: Sun, 14 August 2016, 02:40:58 »
If you want buckling spring and can live without a numpad, the SSK has a smaller bezel.
Offline klennkellon
« Reply #7 on: Sun, 14 August 2016, 02:44:53 »
Forgot about the M2, it might be a good choice.
It's built like crap but it still feels pretty good and the caps are still great.
