Author Topic: [IC] GODSPEED SA - TOUCHDOWN  (Read 117509 times)
Offline Vigrith
Re: [IC] GODSPEED SA - L I F T O F F
« Reply #100 on: Thu, 22 September 2016, 20:15:14 »
Hypu. I'm secretly hoping it launches tomorrow in prep for the weekend but that may be me being optimistic.
Offline MiTo
  • にんたい
« Reply #101 on: Thu, 22 September 2016, 20:16:37 »
see OP
Offline Vigrith
« Reply #102 on: Thu, 22 September 2016, 20:38:03 »
Offline norbauer
  • Plz email shop@norbauer.com; I miss PMs sometimes
    • Ryan Norbauer's personal site
Re: [IC] GODSPEED SA - C O U N T D O W N
« Reply #103 on: Thu, 22 September 2016, 20:45:27 »
This is fantastic beyond description.
Offline milchek
« Reply #104 on: Thu, 22 September 2016, 22:15:47 »
Keen on this, will be the first SA set I buy. So many nice sets out right now that it's hard to choose between a few (hyperfuse and hydro, urgh), but this one is a no brainer for me.
Nice work  :thumb:
Offline jebbra
  • jebbra.net
« Reply #105 on: Fri, 23 September 2016, 00:25:37 »
Holysh it really happened tonight! Nice time placement since it gives time to think how to spend next month salary :)) (assuming MD open GB is always 2 weeks)
Offline wodan
« Reply #106 on: Fri, 23 September 2016, 00:49:17 »
Love the two color ISO-enter variants. Real service for the international users. Brilliant kit selection.
Offline yeahsure
  • -lurks-
Re: [IC] GODSPEED SA - 3,2,1... 🚀 🌕
« Reply #107 on: Fri, 23 September 2016, 01:13:44 »
While I'm definitely down for this set for my 60% but just to ask, could there be some 1.75 blanks tossed in for split space bar support on JD40/45 boards?
I'm with yeahsure. A 1.75 R3 blank would come in handy.
What kits are you planning to get in order to almost cover the JD (since you're short 1 x 1.75u)?
The 40s kit pretty much has me covered on everything except a 1.75 spacebar. But I was planning on using a novelty as a substitute if it wasn't possible to add any more keys
anyways. :thumb:
Offline fraay
« Reply #108 on: Fri, 23 September 2016, 06:30:12 »
Can anyone confirm if the novelty set 'Hard Over' is a 1.75 R3?
Offline xondat
  • i'm not a star
« Reply #109 on: Fri, 23 September 2016, 06:43:41 »
Yes it is.
Offline fraay
« Reply #110 on: Fri, 23 September 2016, 07:05:42 »
Yes it is.
Thanks! haha didnt think to do that
Offline MiTo
  • にんたい
« Reply #111 on: Fri, 23 September 2016, 08:00:46 »
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #112 on: Fri, 23 September 2016, 09:40:56 »
I wasn't sure but I see you snuck it into the 40s kit, which is perfect. Alphas, 40s, novelties, and labs will have me covered.
Thanks for getting that 1.75 R3 blank in there!
Beautiful set!
Offline KetchyKech
Re: [IC] GODSPEED SA - L I V E
« Reply #113 on: Fri, 23 September 2016, 10:04:29 »
that 40s kit....choice between sculpting.....OH MAN...will be ordering sometime next week....great work ~   :thumb:
*wishing I had a yellow kosmo rite bout nao
Offline phinix
« Reply #114 on: Fri, 23 September 2016, 10:52:41 »
Is this solarised color same as Penumbra solarised color?
Offline MiTo
  • にんたい
« Reply #115 on: Fri, 23 September 2016, 11:09:03 »
Beautiful set!
Glad you like it, enjoy the set!
Offline MiTo
  • にんたい
« Reply #116 on: Fri, 23 September 2016, 11:10:35 »
Same as Carbon, which is a little less butter-like than Penumbra.
Offline phinix
« Reply #117 on: Fri, 23 September 2016, 11:13:37 »
Sweet, I'm buying one now :D
Offline punksinatra
    • Random Stuff
Re: [IC] GODSPEED SA - preparing for launch
« Reply #118 on: Fri, 23 September 2016, 14:15:04 »
What should I order to get this setup? Cockpit and Novelty Row 1?
Offline Vigrith
« Reply #119 on: Fri, 23 September 2016, 14:17:59 »
That kit is the Cockpit, it just got renamed - minus the red cluster on the top right, I assume Mito opted out of offering those as standard with the uniform set due to community feedback, those are available through the Novelties kit yep!
Edit: oh and the planet novelties on the bottom row too.
« Last Edit: Fri, 23 September 2016, 14:50:31 by Vigrith »
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #120 on: Fri, 23 September 2016, 14:24:55 »
This is an absolutely gorgeous set @MiTo, thank you for putting this together! :thumb: I just ordered my set from MD, been wanting to try SA keys for quite some time now & this colorway caught my eye enough to be a instabuy for me. ;D I got one question though. I went with Solar alphas, modifiers, & the novelty kit. That will give me the more sculpted 1123433 look correct? I'm thinking that is the profile I want with this set. Although I own 3 - 60% boards, a 65% board, & a TKL, would going with the flatter 223333 Cockpit set & novelties be a better choice for me because of the boards I own? Or is it more a personal preference & either profile is compatible with any boards? Any input on that from anyone with experience with SA keys would be greatly appreciated! :thumb:
« Last Edit: Fri, 23 September 2016, 20:20:18 by Rob27shred »
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #121 on: Fri, 23 September 2016, 14:29:19 »
irritated that the TSAFox set doesnt have the row 1 2.0u backspace needed for the "Aria" layout or the arrows we need either.
Anyone figure out if we can just rock an Alpha, Fox, and Novelties set to build a whitefox? or do we need to add modifiers too.
-Dana
Offline jebbra
  • jebbra.net
« Reply #122 on: Fri, 23 September 2016, 19:41:40 »
Congrats on the launch!
Another question appeared and it about the Dox.
Why or where do you decide that particular layout? When I search about Dox layout and no one appeared like the Godspeed.
Offline MiTo
  • にんたい
« Reply #123 on: Fri, 23 September 2016, 21:00:40 »
Hey Rob, thanks for the support mate!
Regarding your questions:
1) The Alphas + Modifiers + Novelties indeed look and feel more sculpted (1-1-2-3-4-3);
2) I don't believe it would be a bad or good choice for you (it's all about personal preference, really) but I personally prefer the 2-2-3-3-3-3 layout (if I were to use a SA keycap set), as I find it more confortable to type on as I explained here;
3) Any profile is compatible with any boards, it all comes down to personal preference!
I hope you enjoy the set, good luck and godspeed pal.
Offline MiTo
  • にんたい
« Reply #124 on: Fri, 23 September 2016, 21:03:44 »
But that's because you need the modifiers or Cockpit kit as well, the TsaFox is just an addon for non-standard users not a standalone kit!
Alphas + TsaFox + Novelties could work, just make sure you have the proper keycaps for the navigation cluster (Home, Del - in this case Lock, Mal) etc. does that make sense?
Let me know if you require further assistance mate, I'm here to help.
Offline Geckt
« Reply #125 on: Fri, 23 September 2016, 22:46:46 »
L I V E
Doesn't matters if it has a 6U or not, I'm hopping on!
Sent from my 2013023 using Tapatalk
Offline Hypocaffeinic
« Reply #126 on: Sat, 24 September 2016, 00:06:20 »
Quick question! I really like the look of the red mod keys on the Novelty pack, but prefer the 2-2-3-3-3 layout for typing (and need to stem my haemorrhaging wallet somewhat). If I mix in some of those sculpted Novelty keys with the Cockpit kit for my TKL would the mixed profiles be problematic / really obviously look a little funky?
« Last Edit: Sat, 24 September 2016, 00:40:47 by Hypocaffeinic »
Offline dreadful
« Reply #127 on: Sat, 24 September 2016, 01:07:01 »
Not sure if this helps I asked a similar question https://www.massdrop.com/buy/godspeed-custom-sa-keycap-set/talk/525473
He said it should be fine at least in my case here's the reply I received https://www.massdrop.com/buy/godspeed-custom-sa-keycap-set/talk/525480
« Reply #128 on: Sat, 24 September 2016, 01:52:40 »
Ahh fantastic, thank you o Dreadful one! I was hoping it would look alright, with those keys a bit separate in location and function anyway, but it's very good to hear from the experts.
Now the only thing I need to work out is whether I'll definitely replace my TKL with a B.mini, and what this would mean for this set. Changing the keyboards would happen before the end of this year if I decide to go ahead, so I really need to make that call asap so that I make best decisions regarding this purchase.
If I do end up having the B.mini before Godspeed arrives it'll change a few things. The combination of row keys on the arrow cluster will look awesome still, as in the board in MiTo's reply to your question, but the final stack of special keys on the right hand side would look weirder with sculpted profiles in a single column than they would on a TKL. In that case it really wouldn't be worth getting the Novelty set, but I love them so much! Alternatively if I go for the sculpted profile, buying Alphas & Mods & Novelties, I'm basically buying an entire kit of Mods just for those 12 function keys.
So conflicted that novelty kits always look amazing, but are mostly made to go on that cluster of TKL keys that I never, ever use. Then if I buy a keyboard that does away with those unused keys, I miss out on using lots of pretty novelties! /firstworldproblems :(
Offline MiTo
  • にんたい
« Reply #129 on: Sat, 24 September 2016, 08:24:10 »
I'm going to get some pictures of a R1 against a R2 keycap to visually display what the red R1 ROW PITCH YAW versus a R2 function row would potentially look like on a TKL keyboard, for you people that want a flat profile combined with red ROW PITCH YAW (from the Novelties). I don't have the actual labeled keycaps so you'll have to use a bit of your imagination.
A red ROW PITCH YAW would pop up a bit when assembled with the Cockpit kit, kind of ressembling the actual spacecraft high, tall and pronounced function switches that are present on the cockpit cabin. One could pretend that the keycaps are meant to be that way, as a "tribute" to the spaceshuttles. I had to make a choice and thought it would be bummer to ruin a sweet blue/beige cockpit kit with a weird out of place red cluster. So the red cluster is a bit of a "luxury" addon for 112343 users, if we can put this way. It's impossible to make everyone happy without offering literally multiple hundreds keycaps.
Like I previously said it's not ideal, but it looks okay in my personal opinion and gives the board a very unique and stylish terminal feel - it adds an odd bit of personality to the keyboard. Again, it's not ideal and there's obviously a difference. But in my perception as the designer it's a classic example of mix & match that works.
Please stand by.
Offline punksinatra
    • Random Stuff
« Reply #130 on: Sat, 24 September 2016, 11:52:39 »
Ei thanks  :thumb: So the cockpit set is the full TKL layout and since I want the extra modifiers including the red buttons I should buy with the novelties correct?
Offline MiTo
  • にんたい
« Reply #131 on: Sat, 24 September 2016, 12:18:50 »
Yes, but like I said the "red buttons" aren't an exact match for the Cockpit kit. The "row of buttons" on the Cockpit kit is bit taller than the "red buttons" from the Novelties, so although they work together it's entirely up to personal preference.
« Reply #132 on: Sat, 24 September 2016, 15:19:18 »
Please stand by.
I understand what you mean with the decisions you've had to make re. inclusion of various key colours for different kits, and rather like the sound of this; the taller red switches grouped together would look good and physically stand out beside the flatter alphanumerics. I think I'm going to get Cockpit, Novelties, and 40s (impending Minivan), so have different options for various future boards. If I could I'd grab one of everything though, or at least add in Alphas, Mods, and Calculus just in case I do end up with a Lightsaver or similar in the future! Dangggg that would look epic....
ETA: Just added Calculus too. Good thinking, me.
« Last Edit: Sat, 24 September 2016, 15:25:01 by Hypocaffeinic »
Offline Chicken Chaser
« Reply #133 on: Sat, 24 September 2016, 16:04:57 »
I want to get a set to fit my full-size keyboard. I also want the red and yellow caps too. So let me get this straight... My options are:
1. Sculpted set
- Solar Alphas ($39.99)
- Novelty Set ($49.99) (these can be interchanged with the Modifier set to complete a TKL/fullsize build?)
- Calculus Set ($29.99)
Subtotal: $119.99 before tax/shipping
2. Cockpit Set
- Cockpit Set ($88.99) (comes with Novelty modifiers and yellow keys, but not the red/green keys)
- Calculus Set ($29.99) (profile won't match?)
Subtotal: $118.98 before tax/shipping
Leopold TKL Blues || Leopold TKL Reds || Filco TKL Ninja Browns
« Reply #134 on: Sat, 24 September 2016, 16:11:24 »
1. Sculpted set
2. Cockpit Set
Yup, both those options will fill your full-size board. :thumb:
« Reply #135 on: Sat, 24 September 2016, 16:38:16 »
What questions should I be asking myself to predict which set I will enjoy more?
1. Previous daily driver had Cherry profile alphas + SP profile modifiers, so I was used to having angled keys on the modifiers. Currently typing on OEM profile which I don't mind.
2. I have the Retro DSA set from years ago--interesting set, but I didn't like the uniform feel for daily use.
3. I usually type with the tips of my fingers, angled/curled.
What's the issue with R4 being sculpted? Does it affect only a certain group of people who type a certain way?
Offline punksinatra
    • Random Stuff
« Reply #136 on: Sat, 24 September 2016, 17:24:10 »
Thanks Mito let me decide on this first. Very nice set indeed  ;D :thumb:
Offline jebbra
  • jebbra.net
« Reply #137 on: Sun, 25 September 2016, 05:33:18 »
1. Sculpted set
2. Cockpit Set
With option 1 you still need Modifier kit to get the F row if you wanna fill TKL/Fullsize. But you are good to go up to fullsize with option 2.
Offline punksinatra
    • Random Stuff
« Reply #138 on: Sun, 25 September 2016, 10:02:24 »
Hope the cockpit set gets unlocked to $69.99 so I can have enough for the novelties  :(
Offline MiTo
  • にんたい
« Reply #139 on: Sun, 25 September 2016, 11:05:07 »
It will absolutely be unlocked (it probably already is at this point, the numbers will be updated soon).
Offline jebbra
  • jebbra.net
« Reply #140 on: Sun, 25 September 2016, 11:38:50 »
Honestly I still can't believe a TKL-size SA on $69 price AND full of novelties.
Extraterrestrial's knowldge I believe.
Offline Bluestrike2
« Reply #141 on: Sun, 25 September 2016, 14:18:38 »
Sigh. I think I'm going to have to buy these keycaps as well. There's really no other option. In the face of such geeky awesomeness, I'm truly powerless. They'll look great on my work keyboard.
Offline MiTo
  • にんたい
« Reply #142 on: Sun, 25 September 2016, 16:49:27 »
You're welcome, let me know if you require more thelp bud!
Offline punksinatra
    • Random Stuff
« Reply #143 on: Sun, 25 September 2016, 18:50:33 »
Will wait for the next update need to manage my finances  :D
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #144 on: Sun, 25 September 2016, 22:30:12 »
The Good thing about MiTo here is that he's been invaluable on MassDrop for those wanting to know which sets to fill out their keyboards with.
Kudos to you Sir for making key-cap purchasing that much easier.  Not all of us have the Geekhack experience to know what to buy hence thanks for making it a lot easier.
Offline MiTo
  • にんたい
« Reply #145 on: Tue, 27 September 2016, 20:22:51 »
As you wish, the table has been updated yesterday sir.
Offline PriusProblems
  • No ISO, no interest.
« Reply #146 on: Wed, 28 September 2016, 13:56:25 »
I was going to grab an all-blue set, but then I realised that there aren't any blue ISO alphanumerics. :(
Offline eodomo
« Reply #147 on: Wed, 28 September 2016, 18:42:58 »
Just bought the Cockpit and Planck sets, can't wait to finally have letters on my Planck. I can type with blanks, but I'm getting tired of people thinking I'm crazy for it.
Offline MiTo
  • にんたい
Re: [IC] GODSPEED SA - LUNARS?
« Reply #148 on: Thu, 29 September 2016, 10:58:49 »
Does anybody have interest in lunar space bars?
Offline Vigrith
« Reply #149 on: Thu, 29 September 2016, 11:07:15 »
I'm very interested but you knew that already!
