Author Topic: [GB]Revo&Dr.D keyboard  (Read 183507 times)
Offline joey
Re: [GB]Revo&Dr.D keyboard
« Reply #50 on: Thu, 01 September 2016, 10:24:30 »
update here,we are adding two colors now. Orange and deep blue for T0mb3ry's Yuri IC.
Have you got any colour samples?
I wish there was a full board sample of the dark grey. Deciding on colours is hard!
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #51 on: Thu, 01 September 2016, 10:29:05 »
Yey!  :)
I am sitting on the fence. How are the chances you can share with us the svg file for the plate (switchplate)?
I'd like to make a custom plate from materials i want and with switch top removal cutouts.
I think we can share the file for the plate,but i am not sure it's svg file. I'll talk to Dr.D and get back to you.
That would be very nice, if you can share those with us. I mean i can reverse engineer the plate its not that hard, however getting the original draws makes it much easier.
Thanks for taking it into consideration.  :thumb:
Any ideas on how this special plate will be distributed to the buyers? Through another group buy sometime after this buy perhaps?
Would be really good addition to this board if there are any solid information on the switch-top opening plate! :thumb:
Pm RevoTeam about it. They do offer carbon fiber plates :)
Offline kokokoy
« Reply #52 on: Thu, 01 September 2016, 11:25:18 »
Agree sample on the new colors would be nice.
Either I'm adding a middle layer or switching to those new ones. Is the additional mid layer still approx $50?
Offline JDragon
« Reply #53 on: Thu, 01 September 2016, 12:38:18 »
Oooooh... even more things to add to my indecision. Hoping for color samples. :)
Offline RevoTeam
« Reply #54 on: Thu, 01 September 2016, 21:08:56 »
Yep,it about ¥50. i am still trying to make a render for the new color. But you can see them from Yuri.
Offline joey
« Reply #55 on: Fri, 02 September 2016, 08:28:00 »
I hope you really meant 50 chinese yuan :P
Offline RevoTeam
« Reply #56 on: Fri, 02 September 2016, 09:34:23 »
sorry its USD . my bad.
从我的 iPhone 发送,使用 Tapatalk
Offline joey
« Reply #57 on: Mon, 05 September 2016, 17:59:24 »
Finally submitted :thumb: Gotta start on the PCB soon!
Offline RevoTeam
« Reply #58 on: Tue, 06 September 2016, 20:34:10 »
:thumb: :thumb: :thumb:
Offline JDragon
« Reply #59 on: Wed, 07 September 2016, 00:54:53 »
Submitted my entry as well - put in some custom requests as discussed over PM; please let me know if any questions!
Hype hype hype  :thumb:
« Reply #60 on: Wed, 07 September 2016, 01:06:21 »
Any way to get Yarbo cable only?!
Offline RevoTeam
« Reply #61 on: Wed, 07 September 2016, 13:16:58 »
No,sorry.
Offline eksuen
  • Ambassador of explosions.
« Reply #62 on: Wed, 07 September 2016, 13:44:51 »
Stabilizers are not included, right?
Offline joey
« Reply #63 on: Thu, 08 September 2016, 05:09:17 »
No.
Offline CMYK
« Reply #64 on: Sat, 10 September 2016, 18:56:39 »
« Last Edit: Sat, 02 September 2017, 09:32:34 by CMYK »
Offline fublamchu
  • ㅋㅋㅋ
« Reply #65 on: Sat, 10 September 2016, 20:50:51 »
Hi, new member here looking to build a custom board.  This might be cutting it a little close to the deadline, but I had a bunch of questions regarding this group guy.
Why would someone pick a partial plate over a full plate?
What advantage is there to getting the Yarbo cable?
Is the D logo permanently attached to the plate?
Partial plates can allow you to have the feeling of PCB mounted switches on your board (which some people think is a better typing experience over plate mounting) while also having the stabilizers secured by plate.
I'm pretty sure the Yarbo cable is simply aesthetic choice, no performance advantages afaik
The D logo doesn't have to be included on the plate (it's an option on the gb form)
LZ-CE VBlacks
910-CE
Offline KatzenKinder
« Reply #66 on: Sat, 10 September 2016, 21:22:46 »
When invoice? :v
Offline CMYK
« Reply #67 on: Sat, 10 September 2016, 21:58:49 »
« Last Edit: Sat, 02 September 2017, 09:32:26 by CMYK »
Offline fublamchu
  • ㅋㅋㅋ
« Reply #68 on: Sat, 10 September 2016, 22:20:55 »
Thanks for the reply.  For some reason I thought the D logo was something that would be glued to the keyboard if you wanted it.
Do people buy extra plates, and pcbs for extra switch choices and color choices?
PCBs maybe (just to keep extras...?), but plates are a bit harder to mess around with since they're kept in place with the soldered switches so I would think extra plates are a bit uncommon
LZ-CE VBlacks
910-CE
Offline kokokoy
« Reply #69 on: Sat, 10 September 2016, 22:50:26 »
Btw @RevoTeam how do we add additional parts to an existing order? Submit a new one?
Offline garoti
« Reply #70 on: Sun, 11 September 2016, 07:23:01 »
Which is this colour in image? Pink or Red?
Offline joey
« Reply #71 on: Sun, 11 September 2016, 07:31:26 »
That's the pink. I hope!
Offline RevoTeam
« Reply #72 on: Sun, 11 September 2016, 12:04:43 »
You can pm me.... I've been really busy with my factory these days.
Offline RevoTeam
« Reply #73 on: Sun, 11 September 2016, 12:05:32 »
Pink. my friend...
Offline RevoTeam
« Reply #74 on: Sun, 11 September 2016, 12:09:46 »
Sorry, i have been busy these days with my factory to do the new colors. Invoice will be sent on 14th. Thank you everyone for your support.
Offline JDragon
« Reply #75 on: Mon, 12 September 2016, 13:31:45 »
What's the difference between the Yarbo cable and the normal cable? Is it just PS/2 support?
« Reply #76 on: Mon, 12 September 2016, 13:33:23 »
Yarbo is PS/2 only and has a much more refined connection.
In other words, snake oil. :))
Offline redbanshee
  • actually Dade Murphy
« Reply #77 on: Mon, 12 September 2016, 13:49:27 »
USB has to send an IN token before it can ACK the host to execute a keycommand and is therefore fundamentally slower than a PS/2 that is directly addressed. USB runs in polling mode vs PS2 being "constantly connected".
Offline jerue
  • (Whenever that happens :P)
« Reply #78 on: Mon, 12 September 2016, 13:56:34 »
...what?
« Reply #79 on: Mon, 12 September 2016, 14:03:48 »
...what?
Offline RevoTeam
« Reply #80 on: Tue, 13 September 2016, 07:03:15 »
all invoice have been send out. thanks everyone.
Offline Moistgun
  • Slippery When Wet
« Reply #81 on: Tue, 13 September 2016, 10:54:38 »
...what?
Thanks for clarifying!
Offline T0mb3ry
    • Flickr
« Reply #82 on: Tue, 13 September 2016, 11:54:16 »
paid... ;)
Offline Data
« Reply #83 on: Tue, 13 September 2016, 19:44:27 »
Invoiced & paid.  ;D
Offline Moistgun
  • Slippery When Wet
« Reply #84 on: Tue, 13 September 2016, 19:50:11 »
Just waiting for an email reply from Raymond and I'll pay up
Offline MMKB
« Reply #85 on: Tue, 13 September 2016, 20:07:19 »
Paid. Hope the production goes smoothly.
Offline RevoTeam
« Reply #86 on: Tue, 13 September 2016, 20:41:10 »
The production will go very smoothly. I have so many experiences. The hard part for me is collecting payment. Using Paypal is very new to me.
Anyway, i am hoping to ship it out between late November and early December,so it could your Christmas present. :cool:
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #87 on: Tue, 13 September 2016, 21:07:04 »
Paid and pumped! Merry Christmas to all!! :)
Thanks Revo for a super smooth GB so far.
Offline Moistgun
  • Slippery When Wet
« Reply #88 on: Tue, 13 September 2016, 21:16:11 »
Paid up for a board with yarbo and an extra pcb/plate!
 :p :p :p :thumb: :p :p :p
Offline kokokoy
« Reply #89 on: Tue, 13 September 2016, 21:19:10 »
Paid yestarday. Thanks Revo
Offline JDragon
« Reply #90 on: Tue, 13 September 2016, 21:52:19 »
Paid! Hoping for a very merry Christmas  :thumb:
Offline joey
« Reply #91 on: Wed, 14 September 2016, 15:21:13 »
Paid.
Just want to confirm:
Winkeyless layout(black case,pink case,black plate)
On my invoice meant black top/bottom and pink middle piece?
Offline JDragon
« Reply #92 on: Wed, 14 September 2016, 16:46:09 »
Paid.
Would like confirmation of this as well.
Winkey layout(black case,yuri blue case,black plate) = black/blue/black layering? With black plate?
Thanks :D
Offline poolside
« Reply #93 on: Wed, 14 September 2016, 18:00:55 »
I also asked Raymond about this. He confirmed that the first color listed is that of the bottom and top parts of the case (if of the same color, of course).
Offline JDragon
« Reply #94 on: Wed, 14 September 2016, 19:17:33 »
Great to hear! I'm so hyped about this board; want everything to be perfect. :D
Offline RevoTeam
« Reply #95 on: Wed, 14 September 2016, 23:07:12 »
Paid.
Yep, i left middle in the second case.
My bad. It means black case,pink middle case, black full plate.
Everybody chose a full plate. :D :D :D
Offline Moistgun
  • Slippery When Wet
« Reply #96 on: Fri, 16 September 2016, 14:55:40 »
T0m, It would be really great if you shared your outcome with the rest of us.
Would love a plate with switch top opening
Offline T0mb3ry
    • Flickr
« Reply #97 on: Fri, 16 September 2016, 15:10:05 »
Yeah Revo offered me carbon fiber plate for 30$, and i took it beacuse it is really good offer. :)
So if someone want an carbon fiber plate, i think you can still pm Revo for it. Maybe you can get it as extra.
Offline JDragon
« Reply #98 on: Fri, 16 September 2016, 20:33:38 »
:O
Does it allow for switch top opening?
Offline poolside
« Reply #99 on: Sun, 18 September 2016, 06:14:57 »
Paid as well. Looking forward to this great keyboard!  :)
