Author Topic: [GB]Revo&Dr.D keyboard  (Read 183510 times)
Offline Trente
Re: [GB]Revo&Dr.D keyboard
« Reply #500 on: Tue, 17 October 2017, 15:08:07 »
Just curious if any one has extra PCB want to sell to me or if any one know what other PCB is compatible for this case?
I have an extra PCB (and an extra plate/side piece if you need those), located in the US. PM me if interested.
Gotcha,PMed
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #501 on: Sat, 25 November 2017, 07:21:37 »
Does the keyboard support ps/2 interface or is the ps/2 Yarbo cable just for the aesthetics? Just wanted to use Dr.D with ps/2 interface however its not recognized. My other ps/2 keyboards do work just fine.
Its not a biggy if the ps/2 interface is just for aesthetics. Tho if there is a away to make Dr.D to work through ps/2 i would love to know how to make this happen.
My Dr.D works with USB adapter just fine but i would love to use it through ps/2 interface.
« Reply #502 on: Sat, 25 November 2017, 10:35:30 »
I'm fairly sure I read that it doesn't, but I can't for the life of me remember if that's true. PM revo.
Remember, PS/2 isn't hotswappable. You have to restart your PC first.
Offline ya23za
« Reply #503 on: Tue, 06 March 2018, 16:14:25 »
HI
where to find this
https://imgur.com/a/3lTqu
« Last Edit: Tue, 06 March 2018, 16:15:58 by ya23za »
« Reply #504 on: Tue, 06 March 2018, 16:18:48 »
Offline ya23za
« Reply #505 on: Wed, 07 March 2018, 04:05:22 »
sorry I'm a newbie here, what you mean? is it a site or a category in the forum?
Offline gr4v3m4n
    • my store
« Reply #506 on: Wed, 07 March 2018, 04:34:45 »
mechmarket is a subreddit and classified is a subforum here on geekhack
Offline xondat
  • i'm not a star
« Reply #507 on: Wed, 07 March 2018, 05:54:59 »
Classified is a subforum on this forum, you need 25 posts to make a buying thread for yourself, so for now you can just browse it and hope someone lists one.
https://geekhack.org/index.php?board=59.0
mechmarket is a subreddit on reddit, think there are some requirements there but I think it's a lower entry anyway.
https://www.reddit.com/r/mechmarket/
Offline ya23za
« Reply #508 on: Wed, 07 March 2018, 16:22:37 »
many thanks
Offline ya23za
« Reply #509 on: Wed, 07 March 2018, 16:23:33 »
 THANKS DUDE
« Last Edit: Wed, 07 March 2018, 16:26:50 by ya23za »
Offline Prelim
« Reply #510 on: Wed, 12 December 2018, 16:00:18 »
is there any pcb ISO compatible that can be used with this?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #511 on: Thu, 13 December 2018, 07:20:03 »
I tested B87 clone pcb, it's fully fit with Revo & Dr.D keyboard. But you can't use mini USB port with Revo, you need a modification.
I got pcb from local store. I think you can find it on taobao (Someone on mechmarket bought it on taobao).
Good luck!
Offline C³—Ears
« Reply #512 on: Thu, 13 December 2018, 08:27:03 »
Try press P when you connect it to PS2. I heard it works that way.When you want to use usb port then press U when connect it. If it not working instantly,then try to restart your computer cause ps2 port usually needs restart to work.
Offline harjoat
« Reply #513 on: Tue, 06 July 2021, 21:03:05 »
Hey there! Just putting this out there in case someone else ends up also looking for this in the furture like I was.
Couldn't find reference to it anywhere but the PCB is reprogrammable using Bootmapper by Winkeyless (also seems to have the same physical dimensions as a B87 from WKL).
Downloadable here: https://blog.winkeyless.kr/183
Hope this helps someone in the future!
