Author Topic: Cherry MX 3D?  (Read 2088 times)
Offline Flipp3rix
Cherry MX 3D?
« on: Fri, 26 August 2016, 11:45:06 »
Hi! Has anyone a 3d models or cad files of cherry mx black's parts? I want to try 3d print a switch...is it possible? TIA
Offline kingpilcrow
Re: Cherry MX 3D?
« Reply #1 on: Fri, 26 August 2016, 12:41:54 »
Sure - they are all over Thingiverse.
http://www.thingiverse.com/thing:755557
« Last Edit: Fri, 26 August 2016, 12:43:30 by kingpilcrow »
Offline Flipp3rix
Re: Cherry MX 3D?
« Reply #2 on: Fri, 26 August 2016, 12:48:34 »
Nope xD...imean switch it self not keycap
Offline kingpilcrow
Re: Cherry MX 3D?
« Reply #3 on: Fri, 26 August 2016, 12:54:12 »
Nope - probably won't be durable enough and you still have metal parts.
Offline Flipp3rix
Re: Cherry MX 3D?
« Reply #4 on: Fri, 26 August 2016, 17:35:15 »
Soo...i can't build my own switch...Thats because ii have no money for mechanical keyboard :(
Offline AMongoose
  • happy workman user
Re: Cherry MX 3D?
« Reply #5 on: Sat, 27 August 2016, 08:49:14 »
You can buy mx switchs from a lot of electronic components suppliers. It will probably be cheaper than printing your own and they will work much better.
