Author Topic: Poseidon Z Keycaps?  (Read 3715 times)
Offline THEMIKEBERG
Poseidon Z Keycaps?
« on: Fri, 26 August 2016, 16:39:37 »
So I finally jumped ship from my broken membrane and grabbed myself a Ttesports Poseidon Z, it's an alright keyboard but from what I've gathered getting custom keycaps for it is not possible due to the weird bottom row, non standard spacebar (I think it's a 7 length), and the stabilizers used?
Has anyone actually tried switching up the keys on it? I've tried looking around but it seems like not too many people have tried.
Any help would be appreciated!
Offline Auxo
  • Formerly CJD_Anthony
Re: Poseidon Z Keycaps?
« Reply #1 on: Sun, 28 August 2016, 06:54:36 »
idk about the stabilizers, but it does look like a non-standard bottom row.
1.25 - 1 - 1.25 - 7 - 1.25 - 1 - 1 - 1.25
Assuming you're looking at a normal set of keycaps from a website like mechanicalkeyboards or WASD, it may be difficult to find a set that would cover that bottom row. If you are willing to move your price range up to $50-85, you should have no issues finding a set to throw on that keyboard that covers multiple layouts (like my EnjoyPBT set, for example)
Can you pull off the space bar and take a picture of it?
