Author Topic: Teensy 3.5 and 3.6  (Read 2949 times)
Offline chuckdee
Teensy 3.5 and 3.6
« on: Tue, 30 August 2016, 13:21:37 »
I back a lot of kickstarters, so they suggest things to me at times.  I just received this suggestion:
Teensy 3.5 & 3.6
https://www.kickstarter.com/projects/paulstoffregen/teensy-35-and-36
I'd not seen any discussion here, and it's in its last week.
I see that the creator also did a Teensy 3.0 project
https://www.kickstarter.com/projects/paulstoffregen/teensy-30-32-bit-arm-cortex-m4-usable-in-arduino-a
Looking at the updates, it appears that one went relatively well, even shipping on time:
https://www.kickstarter.com/projects/paulstoffregen/teensy-30-32-bit-arm-cortex-m4-usable-in-arduino-a/posts/334642
His site also has a lot related to Teensy: https://www.pjrc.com/teensy/index.html
Does anyone have any knowledge about it or thoughts?
Offline joey
Re: Teensy 3.5 and 3.6
« Reply #1 on: Tue, 30 August 2016, 13:30:50 »
Teensy 3.5 & 3.6
They're overkill for keyboards, but pretty cool dev boards.
Offline derezzed
« Reply #2 on: Mon, 05 September 2016, 21:05:20 »
The site says the new Teensies  have audio capabilities.  I wonder if they could be used to incorporate active noise cancellation into a keyboard to silence the keystrokes, or to enhance the sound of the keystrokes (a wood percussion sound, perhaps).
