Author Topic: [GB] RAMA M4-A [SHIPPED]  (Read 127657 times)
Offline jal
  • I can't believe it's not gravy!
Re: [GB] RAMA M4-A [ORDER THROUGH TO MANUFACTURER!]
« Reply #100 on: Mon, 19 September 2016, 20:22:12 »
But yes I'm all for exploring different materials, brass and bronze are pretty decent choices, relatively machinable and weighty. Copper is nice too but rather soft. Ti 6-4 is a pretty common alloy in my line of work, would like to see one eventually in a keycap  ;D
If you really really want to make it unusual, make it out of a nickel superalloy like Inco 718 or Waspaloy, but they are a ***** to machine  :p, and I'd imagine the selection criteria for these alloys (mechanical strength and low creep at 1500K+) is probably not too relevant in a keycap context  :rolleyes:
I've been playing with milling 6AI4V. (Not caps, this is a different silly hobby.) It is actually easier to work with than I thought it would be - the horror stories, I guess, primed me well. I want to try a Ti keycap soon.
I really don't like copper so far - I've only tried turning it, and only twice, but it seemed to find a way to bind up if given any opportunity. The lathe I was using was not the newest, best cared-for tool on the planet, but getting copper to behave was a bit beyond me on that attempt. (I'm still very new to machining, and this is very much not my day job.)
Are there any keycap templates out there that folks know of? I found a couple at Thingiverse and somewhere else I forget, but one just seemed very wrong, and I forget what was wrong with the other, but it didn't seem like it was going to work. Or actual, canonical specs for the the various rows in different profiles?
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #101 on: Mon, 19 September 2016, 20:36:57 »
I would like one but this is not a great time for me :(
If you really really want to make it unusual, make it out of a nickel superalloy like Inco 718 or Waspaloy, but they are a ***** to machine  :p , and I'd imagine the selection criteria for these alloys (mechanical strength and low creep at 1500K+) is probably not too relevant in a keycap context  ::)
Understandable mate, no worries at all!
Oh damn bro! You know your materials :P What do you do for a living? O_o
I've actually been meaning to do something with Titanium for a while, would definitely be cool.
Hahahah superalloy :P Mate, if I can get it machined it must happen - I want a whole top row of every main element and nice alloys there is :P Would be cool seeing polished with it's natural color for sure!
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
Offline duynguyenle
  • Personal text? What personal text???
« Reply #102 on: Tue, 20 September 2016, 13:14:30 »
I reckon the reason why you are havving issues with copper is probably due to its heat soak characteristics. You are probably experiencing some thermal distortion of the workpiece. Copper conducts heat very well but it's got a relatively low specific heat capacity, meaning that while it's excellent at conducting heat away from the heatsource (machining face), it also doesn't take much energy to raise the temperature of the whole piece. Tool steel and even high speed steel tools and bits have reduced performance at higher temperatures. Add that to the thermal distortion and expansion mismatch between the tool and the workpiece, and that means you will get rather inconsistent results without active cooling. I'd imagine giving it a rest between passes or running a coolant through the piece would help with machining (the latter suggestion is obviously more relevant if you're using a CNC mill  ;D)
I work for a big English gas turbine manufacturer, we make jet engines  :))
I'm not a materials specialist, but I know the broad strokes of what alloys we use in which section of the engine. I was just kidding about using nickel alloys for keycaps btw, probably not suitable at all for this purpose, but I think brass or Ti alloys would do nicely!
Shame I can't afford to get in on your steel cap GB at the moment, big life-related invoices I have to pay soon-ish, I probably will have to sit this one out and count my pennies for Wave R3 in Cherry profile  ;D
« Last Edit: Tue, 20 September 2016, 13:55:23 by duynguyenle »
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #103 on: Tue, 20 September 2016, 21:24:43 »
Oh wow dude, that's awesome!! O_o
Yeah I'm with you on Brass and Ti, I think Tungsten would be cool too from its phenomenal density, it would probably straight actuate most switches on insertion haha.
Gotta pay the important stuff first man! All good :)
Going to borrow a cherry profile escape key off a mate and get to work on it ASAP :P
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #104 on: Thu, 22 September 2016, 01:18:19 »
Hi all!
Just give you guys an update, the prototype from my old supplier have come in! Note that I'm moving to a new manufacturer to produce the M4-A!
Here are a photos of the first prototype :) New prototype is coming in next week.
FEELS AMAZING TO HOLD. Can't wait to get these out once they all come in! :D Also looking forward to receiving the new prototypes from the new manufacturer :)
INSTA: @ramaworks
FB: ramaworks
Offline duynguyenle
« Reply #105 on: Thu, 22 September 2016, 02:02:42 »
Will the big padded case be included?  :p
Offline jal
« Reply #106 on: Thu, 22 September 2016, 02:26:22 »
Sorry to be slow replying, I missed this at first.
I was using cooling. I suspect I my speed on the lathe was too slow on the second attempt (I think I corrected in the wrong direction), and then I ran out of stock, which ended the experiment.
In general, though, I'm pretty sure the problem was inexperienced operator on janky old machine.
Working on fixing the first. Fixing the second is going to have to wait until I'm not living in a second-floor residential walk-up. (Actually, I'm considering going for a mini-mill that wouldn't collapse the floor, but I want to actually run it before dropping that much money on a tool unrelated to my day job, so am working on that.)
Thanks for the tips!
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #107 on: Thu, 22 September 2016, 02:27:14 »
Hah! I would love to if i could ship that affordable  :p
The M4-A alone is pretty hefty! So cold to the touch too, I love it :D
INSTA: @ramaworks
FB: ramaworks
Offline jal
« Reply #108 on: Thu, 22 September 2016, 02:29:17 »
I assume that came handcuffed to a quiet, serious man in sunglasses?
Offline duynguyenle
« Reply #109 on: Thu, 22 September 2016, 02:32:05 »
I've only got very limited machining experience too, haven't done anything since uni, wish I have the space/money/spare time for a proper CNC  :D
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #110 on: Thu, 22 September 2016, 02:45:04 »
HAHAHA yeah he dropped by in a convoy of G-Class Mercedes, dressed in a black suit and tie too  :)) :)) :cool:
"wish I have the space/money/spare time for a proper CNC" oh my don't we all :O
INSTA: @ramaworks
FB: ramaworks
Offline OatmealFor3v3r
« Reply #111 on: Thu, 22 September 2016, 09:39:06 »
Hi.  Possible to give some dates on the next milestones?  Would like a general idea on when to monitor the progress.  Thank you.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #112 on: Thu, 22 September 2016, 16:43:21 »
Cold to the touch?
Awesome to see it in the flesh, even if it isn't the final proto!
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #113 on: Thu, 22 September 2016, 18:16:38 »
Hey Oatmeal, of course mate. Going to keep everyone updated when things happen too :)
So next milestone is receiving the sample from the new manufacturer which is looking like it will come in next week. And once I check off and approve the sample, production will begin.
Production will take around 2 weeks :)
Cold to the touch?
Man, not to boast/brag or anything, but I gotta say that it feels amazing to hold, cannot wait for people to receive there's!
Upon inspecting the sample from the first manufacturer (current prototype) I keep seeing more and more shortcuts/irregularities.
I'm really fussy when it comes to details and I want everything I do to reflect my requirements and design philosophies and I want people to receive something I'd be happy with.
I'm confident the new manufacturer will be able to meet my tolerances and expectations - we shall see next week :)
BONUS:
Here is the Instagram story from the other day (so apologies for the poor quality and vertical video):
« Last Edit: Thu, 22 September 2016, 18:42:50 by KingRama »
INSTA: @ramaworks
FB: ramaworks
Offline swimmingbird
  • keyset hoarder
« Reply #114 on: Thu, 22 September 2016, 18:45:17 »
Dat M4-A be fooken tight ja
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #115 on: Thu, 22 September 2016, 19:08:38 »
haha cheers bird <3 Come over to Melb and I'll show ya in person ;)
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #116 on: Fri, 23 September 2016, 09:35:24 »
Okay guys, another update!
The second prototype/sample is almost completed, they have finished the top aluminium half (got space grey this time), they still have to make the base. They have already made a few bases, but I wasn't happy with the color - so I'm changing it to just standard white nylon as it's made from a better supplier and is typically much better quality.
And news from Machine Industries is that the PCB is all working, just have to fix up a pin error for the LEDs then I'll get those put into production!
All coming together now :)
INSTA: @ramaworks
FB: ramaworks
Offline delivery
« Reply #117 on: Fri, 23 September 2016, 10:09:21 »
Weewwwwww, nice!!
Sent from my SM-N9150 using Tapatalk
Offline xondat
  • i'm not a star
« Reply #118 on: Fri, 23 September 2016, 10:10:18 »
Looks so good, wish I could afford one :(
Offline duynguyenle
« Reply #119 on: Fri, 23 September 2016, 11:10:31 »
Now I'm really glad I got a few extra Wave cap in your last GB, they will go perfectly with this. I'm just gonna pretend that it was all planned all along  :p
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #120 on: Fri, 23 September 2016, 22:08:38 »
Weewwwwww, nice!!
Cheers mate!
Thanks Xondat! :D All good mate, next round perhaps :P
Oh man, yes please. That's gonna look dope! :D
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #121 on: Sat, 24 September 2016, 10:04:05 »
PCB order placed with manufacturer :)
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #122 on: Sun, 25 September 2016, 22:40:46 »
UPDATE:PCB's are now in production - I expect these to come in next week :D
Stainless Steel screws have been ordered - they're going to be slotted screws. I wanted to use something A E S T H E T I C like TORX security screws or pentalobe screws, but I figured that these will need to be assembled/disassembled for soldering switches etc. But you can always replace them with some nice hex/TORX screws yourself if you want to change them up a bit :)
The latest revision of the prototype also has a through hole in the base for pressing the reset button for programming.
hoping the latest prototype comes in this week :)
INSTA: @ramaworks
FB: ramaworks
« Reply #123 on: Sun, 25 September 2016, 23:47:19 »
Robertson screws all the way, because Canada!
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #124 on: Mon, 26 September 2016, 00:05:24 »
hahahaha, yours must now be blessed with Roberston screws to represent the Canadian M4!
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #125 on: Wed, 28 September 2016, 06:29:33 »
UPDATE!
Sample from the new manufacturer is being shipped, this includes 5 parts for me to check out :D Including some different colors for the base.
Unfortunately, this upcoming Friday is a public holiday in Australia :( So, it should be here the following Monday.
Once I'm happy with the sample, production will begin for the remainder of the units!
Bare PCB's have also been completed and are set to be assembled once components arrive, this will be after next week (as it is National Holiday in Asia). Expecting those to arrive the week after next.
Cheers :)
INSTA: @ramaworks
FB: ramaworks
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #126 on: Wed, 28 September 2016, 06:52:04 »
UPDATE!
Cheers :)
HYPED. So excited to get this. Just realized all the components are included which makes me even more hyped.
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #127 on: Sun, 02 October 2016, 21:36:08 »
UPDATE!
Cheers :)
Thanks Jchan! Thought that might excite people :D
Sample from the new manufacturer came in, for the space grey. Much more impressed with how it came out from this new manufacturer. Feels a LOT better.
Potato pics (i'll take better photos later)
(temp screws)
(new USB hole)
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #128 on: Sun, 02 October 2016, 21:45:03 »
I'll upload a video later tonight :)
INSTA: @ramaworks
FB: ramaworks
Offline delivery
« Reply #129 on: Sun, 02 October 2016, 22:58:07 »
Cool Man,,, How soon can we expect to get the real thing?
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #130 on: Sun, 02 October 2016, 23:30:31 »
Realistically, 3-4 weeks :) Will keep you updated throughout!
This sale has taken a little longer than usual as I have made some major design changes and moved suppliers.
These being:
 - Changes to the enclosure (deepened the switch tray, changed the USB hole), minor aesthetic changes.
 - PCB changed from through-hole components to SMD components. Now coming fully assembled (sans switches)
 - Changed manufacturers.
 - Waiting on manufacturing samples from both old supplier and new supplier.
The wait will be worth it! Apologies all for the delay.
INSTA: @ramaworks
FB: ramaworks
Offline delivery
« Reply #131 on: Mon, 03 October 2016, 00:06:53 »
No worries man!!! Eagerly waiting!! Cheers
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #132 on: Mon, 03 October 2016, 06:31:52 »
VIDEO. EXCUSE THE VOICE.
INSTA: @ramaworks
FB: ramaworks
Offline Fictiouz
  • That "White" Guy
« Reply #133 on: Mon, 03 October 2016, 06:38:05 »
Kicking myself in the ass for not ordering one of these...   :-[
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #134 on: Mon, 03 October 2016, 06:49:18 »
Aww :( All good man, hopefully it'll reemerge in the future :)
INSTA: @ramaworks
FB: ramaworks
Offline Fictiouz
  • That "White" Guy
« Reply #135 on: Mon, 03 October 2016, 07:03:17 »
Hopefully! Looks great can't wait to see all the different caps people throw on them!
Offline ambalek
  • Pizza tonight/Threat neutralized
« Reply #136 on: Mon, 03 October 2016, 07:24:08 »
This is cool -- the attention to detail is very impressive. It makes me wish more larger-sized cases and PCBs had this level of scrutiny (not that there aren't good products out there, it's just I've struggled to find an amazing 60% case).
Offline Data
« Reply #137 on: Mon, 03 October 2016, 07:35:31 »
Wow, keep the pics and videos coming!
Love it.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #138 on: Mon, 03 October 2016, 08:06:44 »
Likewise! I'm really excited to see how people dress this one up :D
Woah, thanks heaps mate! I really believe that every detail is super important, all the way down to the packaging (got some extras I've yet to reveal for that ;) ), cannot wait for people to get this in their hands to experience it for themselves :) I will be doing some larger boards in the near future :)
Love it.
Thanks heaps Data, there's definitely a lot more to come! :)
INSTA: @ramaworks
FB: ramaworks
Offline duynguyenle
« Reply #139 on: Mon, 03 October 2016, 09:36:10 »
Enough teasing, when can we get these in our hands?  :p
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #140 on: Mon, 03 October 2016, 17:12:36 »
Aiming for end of this month! Honestly super stoked to get these out to your hands mate. Going to really enjoy seeing what people do with it :D
INSTA: @ramaworks
FB: ramaworks
Offline thaddeus
« Reply #141 on: Mon, 03 October 2016, 19:22:03 »
Thanks for sharing the video with us -- getting me EVEN MORE HYPED for the shipment notification :thumb: Nice work!
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #142 on: Mon, 03 October 2016, 20:45:14 »
No worries! I'll take another when the PCB comes in and it's a full product :) Hopefully I won't have a raspy af voice that time around :P
INSTA: @ramaworks
FB: ramaworks
Offline MikeTheTiger
« Reply #143 on: Wed, 05 October 2016, 00:40:46 »
Wow the refinements you made really shine through in the video.  :thumb: Can't wait for it to show up on my doorstep!!
"all the numbers or none of them cmon man" -Kokaloo
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #144 on: Wed, 05 October 2016, 04:40:52 »
Cheers Mike! Really can't wait for people to get them in the mail :D Super stoked
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #145 on: Fri, 14 October 2016, 08:17:20 »
Really sorry for the long wait with this project, it would have been shipped a lot earlier, but with the change of PCB, the new manufacturer and design changes really set everything back.
All of this was necessary to make sure that you guys will end up a much more polished and refined product!
Good news is that they are all going along well in production! Here is a crappy photo from the manufacturer :P Ready to go off to further processing!
INSTA: @ramaworks
FB: ramaworks
Offline Data
« Reply #146 on: Fri, 14 October 2016, 11:35:51 »
Stacks of fluffy metal pillows.  :p
Offline AceRuckus
« Reply #147 on: Fri, 14 October 2016, 22:16:09 »
Can't wait, Rama!
Offline duynguyenle
« Reply #148 on: Sat, 15 October 2016, 03:39:10 »
**breathing intensifies**
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #149 on: Sat, 15 October 2016, 09:13:42 »
Heh, stacks of not so comfy metal pillows :P
Can't wait, Rama!
Same here mate!!
Good news is that they are all going along well in production! Here is a crappy photo from the manufacturer :p  Ready to go off to further processing!
**machining intensifies**
INSTA: @ramaworks
FB: ramaworks
