Author Topic: [GB][FINISHED] Mekanisk Group Buy / LeandreN round 5  (Read 255835 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][FINISHED] Mekanisk Group Buy / LeandreN round 5
« Reply #750 on: Wed, 15 February 2017, 09:11:37 »
Yes, thank you! Now it's not so far away to Sweden.
Yours shipped today!
Got it!
Can't wait for pictures and build log.
Teaser...
Teaser part II...
Waiting for stabs so nothing is soldered yet.
Thanks for sharing!
Stabs came in today so here's the final result.
Silver aluminium case, silver carbon fibre plate, lubed Cherry mx clears in RGB housing with Sprit 85g springs, Zeal gold plated stabs, Pexon cable and of course Nerd60 Mekanisk/1up keyboards edition.
Thank you for sharing! I appericate it. Looks sick.
The package has arrived safely downunder!
Should've ordered 2 mint PCBs! lol.
the subtle mint green colour is really" nice
Thanks for running an awesome GB, LeandreN  :thumb:
Thank you for posting in the thread, good luck with the builds-
First ever build. More or less a success with a few hiccups on the way.
Dropped case with plate while fiddling: scratched case, bent plate at the sensitive enter\iso location.
Soldered \| switch not lined up, so keycap was crooked and interfered with enter keycap.
Clipped the stabilizers like a good boy, but some how backspace is still very mushy and sticky. Tried to lube the wire through the plate holes.... Should have checked\lubed them before soldering everything...
But anyway, it's done ant it works :cool:
Cheap clear case, gateron browns + whites for modifiers (courtesy for pinkies).
I don't think i would ever go back to full size or tkl board, even after so little time with this one. Fears about not having arrows and stuff were proved false. Though i can clearly see now, that i would prefer a layout that uses thumbs more and pinkies less, but that's for another day.
About leds. Never cared much for them, but now i am thinking since the pcb supports them, why not. I want leds to ligtup on layers. Problem is side leds are single color, so how to show two layers? Crazy idea about using switch leds for that. If i would solder them on the bottom. Effectively having two color underlight. Ideally i would want to use only some of them (for example only on the sides). Is this possible or leds wont work if i don't solder all of them?
P.S. Again, thanks LeandreN for this group buy.
If the plate ends up not working somehow, let me know!
Thank you for posting!
60% is really a fantastic form factor-
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #751 on: Wed, 15 February 2017, 09:13:08 »
I appericate all the posts here! Thanks.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #752 on: Wed, 15 February 2017, 09:13:36 »
After three weeks of hide and seek and catch me if you can games with Poste Italiane, someone finally decided to let go my box.
Pictures to come.
Haha! That link
Thanks for posting.
Offline finalarcadia
« Reply #753 on: Wed, 15 February 2017, 14:39:34 »
Received everything, thanks Leandren for the smooth GB. Really loving the steel plate, all steel plates should be sandblasted like this.  :thumb:
Offline Owntrolf
« Reply #754 on: Thu, 16 February 2017, 01:44:48 »
isnt it bad for the screw to be pushing on the plate instead of the pcb itself?
« Reply #755 on: Thu, 16 February 2017, 03:11:14 »
This case specifically uses wood screws directly into it, and it's pretty hard to find smaller wood screws. As far as it being bad, not really since the keycaps never bottom out enough to hit the screws.
Offline fanman888
« Reply #756 on: Thu, 16 February 2017, 21:32:08 »
Just wanted to let you know that my order arrived! Thanks William!  :thumb:
Offline Gosnat
« Reply #757 on: Sun, 26 February 2017, 07:46:44 »
Are we going to see a restock with the leftovers on mekanisk any time soon?
Me need plate!
Offline TalkingTree
    • My projects
« Reply #758 on: Sun, 26 February 2017, 09:56:07 »
Me need plate!
Which one?
Offline Gosnat
« Reply #759 on: Sun, 26 February 2017, 10:18:18 »
Which one?
Hoping for a steel one.
Offline TalkingTree
    • My projects
« Reply #760 on: Sun, 26 February 2017, 10:28:31 »
What layout? I might have one for you, if LeandreN doesn't.
Offline Gosnat
« Reply #761 on: Sun, 26 February 2017, 12:06:55 »
How kind of you, really appreciate it!
I need a universal plate for a standard ISO layout.
There is no rush, i have other things needed for this board that i'm waiting for.
Offline TalkingTree
    • My projects
« Reply #762 on: Sun, 26 February 2017, 12:12:16 »
I'll have a look at my stuff.
Offline TalkingTree
    • My projects
« Reply #763 on: Sun, 26 February 2017, 12:47:28 »
Found nothing, I'm afraid you have to wait for a restock.
Offline Gosnat
« Reply #764 on: Mon, 27 February 2017, 13:21:09 »
Thanks anyway  :)
I'm waiting on alot of things, i can wait on this as well!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #765 on: Fri, 03 March 2017, 15:34:46 »
https://mekanisk.co/collections/keyboard-parts
Left over aluminium and carbon fibre.
No left over steel as of now, but I am looking at putting an order in for some depending on when I get brass...
Thanks for your patience, there are little amounts per type, so get them while you can.
Offline eksuen
  • Ambassador of explosions.
« Reply #766 on: Fri, 03 March 2017, 15:53:29 »
Still waiting for an aluminum case restock.  ;)
Offline dorf
  • divine creator
« Reply #767 on: Fri, 03 March 2017, 16:19:38 »
Offline Atredl
« Reply #768 on: Fri, 03 March 2017, 17:27:47 »
Silver twill ordered. Now just need a blue fjell to go with it ;D
Offline Skuloth
« Reply #769 on: Fri, 03 March 2017, 17:30:19 »
I want a purple normal 60% case :(
Planck w/ Zealios
Offline TalkingTree
    • My projects
« Reply #770 on: Fri, 03 March 2017, 17:39:39 »
Offline Skuloth
« Reply #771 on: Fri, 03 March 2017, 17:43:39 »
Ideally aluminum and with no angle.
Planck w/ Zealios
Offline TalkingTree
    • My projects
« Reply #772 on: Fri, 03 March 2017, 17:47:31 »
This one has angle but I'm afraid it's the best I could find.
Offline eksuen
Offline Sempre
« Reply #774 on: Sat, 04 March 2017, 00:59:36 »
I bought this a few days ago
Ill post pictures here when it arrives if anyone wants to see it before buying
Offline Gosnat
« Reply #775 on: Sat, 04 March 2017, 04:45:53 »
Bummer, no steel! Got a purple plate for my 60% Plum build tho  :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #776 on: Sat, 04 March 2017, 04:47:09 »
Thanks for your purchase. :)
Offline johuu
« Reply #777 on: Sat, 04 March 2017, 04:50:32 »
How far away is R6?  :cool:
Offline Skuloth
« Reply #778 on: Sat, 04 March 2017, 09:23:33 »
I grabbed a purple plate too :D
Gonna be going on my zeal60 when the next round comes out!
Planck w/ Zealios
Offline Schw4rz
« Reply #779 on: Tue, 07 March 2017, 09:52:36 »
I have now also finished my build in ISO DE:
Carbon Plate, Stabilizers, White PCB from this Group Buy. Caps are from Tai Hao. Cable from Pexon PCs. Switches are 78g Zealios.
Very happy with my first very own Keyboard! Thank you!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #780 on: Tue, 07 March 2017, 10:12:52 »
Looks great!
What do you think of the carbon plate?
LeandreN
Offline Schw4rz
« Reply #781 on: Tue, 07 March 2017, 10:41:52 »
Looks great!
LeandreN
I like the look and feel of the carbon plate. The whole build is so much better than my old Steelkeys 6G (the old one; MX Black) and the MX-Board 3.0 with MX Brown that I am using at work.
But I cannot really judge the plate individually but only the build as a whole, which is awesome!
Offline Brammm87
« Reply #782 on: Tue, 07 March 2017, 23:33:57 »
Build log of zeal60 with plate from this buy: http://imgur.com/a/2fpal
pls gief bbv2
Offline Atredl
« Reply #783 on: Wed, 15 March 2017, 16:24:01 »
The Post tried as hard as they dared to break this plate in transit, but they could not get through LeandreN Superior Shipping.
This plate is absolutely brilliant in the sunlight. It's a real same it will primarily live indoors and under keycaps :,(
https://i.imgur.com/PyxxWIh.jpg
https://i.imgur.com/DIhB6wu.jpg
Offline menuhin
« Reply #784 on: Wed, 15 March 2017, 16:51:14 »
Okay, have been missing out.  :eek:
This is the place I can get well thought keyboard parts from LeandreN before the options are quickly sold out on Mekanisk website.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline TalkingTree
    • My projects
« Reply #785 on: Sun, 26 March 2017, 06:03:45 »
It took me a long while to realize that HHKB plates are basically my favourite layout without the Control cutouts. So I decided to make those cuts myself.
I overlapped the HHKB plate over a winkeyless one and put three switched through for a more precise alignment, then I marked the cutting area with a blackmarker, like so.
I drilled through the inside to make room for a hand file to finish the cutout.
Originally I wanted to do this with a steel plate, but it was so hard that I couldn't get through even with a power drill, and I don't own a drill press, so props to LeandreN for making my life a living hell providing us with top-notch materials.
I then filed the cutout to make them square. It look like five minutes each.
I filed again the left cutout later on because it wasn't square but I don't have a picture for that.
I populated plate and PCB with switches and it looked great.
For this keyboard I used a plastic 60% case bought on Aliexpress.
Close ups on the hand cut holes.
Keycaps.
I really like the contrast between black keycaps and red plate, and I'm very satisfied with the result. I'll try again with the steel plate in the future but surely I'll be getting more aluminum HHKB plates.
Lastly, some technical details and a summary:
Parts used
PCB: White GON's NerD 60% Mekanisk - 1UPkeyboards edition, with TMK firmware
Plate: R4 HHKB red aluminum plate.
Switches: Gateron KS-3 Black, bought on Aliexpress.
Keycaps: Mods are from WoB icon mods GB, alphas are OG cherry lasered and infilled ABS, right shift is a gracious present from LeandreN himself.
Tools used
Dremel 3000 to cut the extra holes.
USBasp programmer to replace NerD's bootloader and firmware.
This great guide to achieve the previous goal.
That's it.
Thanks for reading.
Offline steetyj
« Reply #786 on: Mon, 03 April 2017, 15:56:18 »
New guy here: Any HHKB plates going to be restocked on the website anytime soon?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #787 on: Mon, 03 April 2017, 15:59:06 »
Keycaps.
Parts used
Tools used
That's it.
Thanks for reading.
Thanks for sharing. Great read! If you ever need any custom plate, please let me know :)
Sent from my Nexus 5X using Tapatalk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #788 on: Mon, 03 April 2017, 15:59:57 »
Not before the next group buy.
I am talking to GON.
William
Offline steetyj
« Reply #789 on: Mon, 03 April 2017, 16:01:23 »
Nice, I'll get in on next round for sure. Really want to do orange case/plate combo.
Offline tinyprawn
« Reply #790 on: Thu, 13 April 2017, 23:39:40 »
Should I have done something special with the enter switch when mounting it?
The corner toward the "]" key seems to be very close to that key and when I press it down, it feels mushy and seems to twist a little counterclockwise. Just like 4 or 5 degrees...  I feel like the stabilizers or switch are somehow out of whack...
165748-0
165750-1
Offline TalkingTree
    • My projects
« Reply #791 on: Fri, 14 April 2017, 05:59:29 »
If the switch is plate mounted, i.e. if it doesn't have the two small plastic pins on the bottom side, desolder and reseat it. It might be slightly rotated.
Offline tinyprawn
« Reply #792 on: Fri, 14 April 2017, 09:31:20 »
It's a PCB mounted Zealio switch. I will try desoldering and reseating tonight.
