Author Topic: Keyboard for business trip and traveling  (Read 35924 times)
Offline chuckdee
Re: Keyboard for business trip and traveling
« Reply #50 on: Wed, 21 September 2016, 13:22:10 »
Which site, I tried . But I did not find a site sellling wooden case.
This is what I use. The case is a bit pricey but for traveling you can't beat the case + lid combo. You can find them at datamancer http://www.datamancer.com/cart/datamancer-oaken-60-keyboard-case-p-295.html and they also pop up on massdrop from time to time for a bit cheaper price.
There's similar cases on alibaba.  That's what I have on my poker.  More variety in wood that way too.
https://www.aliexpress.com/item/Handcraft-GH60-Solid-Wooden-Case-For-60-Mini-Mechanical-Gaming-Keyboard-Compatible-Poker2-Pok3r-Faceu-60/32596058719.html
Offline 0100010
  • Not Sure
« Reply #52 on: Wed, 21 September 2016, 21:10:32 »
Those wood cases make me want to build a 60% board.  I would add small neodymium magnets around the perimeter to hold it closed though.
Offline Adgar
    • Pheilcia
« Reply #53 on: Thu, 22 September 2016, 19:25:44 »
Well, that sounds good. Do you have any  DIY works right now?
Offline chuckdee
« Reply #54 on: Fri, 23 September 2016, 14:39:51 »
Oooh... good idea!  What force do you think would be required in order to make it a solid grip?
Offline 0100010
  • Not Sure
« Reply #55 on: Fri, 23 September 2016, 14:45:10 »
Don't think magnet strength would be all too important, neodymium is pretty strong in general, so N42 would probably be fine.  I suspect 6 locations / 12 magnets total (1 in each corner, 1 in the middle top/bottom) would be plenty.  They would have to be pretty small to fit in the lip around the edge though.  Maybe some 1/10" by 1/10" N42 cylinders.
Offline captsis
  • Formerly matt2dlg
« Reply #56 on: Sun, 25 September 2016, 01:06:38 »
Would that kill the HDD?
Sent from my SM-G920V using Tapatalk
Offline ctm
  • Hello, world!
« Reply #57 on: Sun, 25 September 2016, 08:13:13 »
There is a Bluetooth version of HHKB http://www.pfu.fujitsu.com/hhkeyboard/bt/
Coming:
Ellipse Model F F62.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #58 on: Sun, 25 September 2016, 08:24:50 »
Beamspring!
Imagine all the puzzled faced when you pull it out of your bag in a meeting or in a coffee shop. You'll have the full attention!
Offline ctm
  • Hello, world!
« Reply #59 on: Sun, 25 September 2016, 10:37:38 »
Beamspring!
Yes! +1 for beam spring! When traveling, beam spring boards can also serve as weapons to defend against robbers :thumb:
Coming:
Offline Ashlyn
« Reply #60 on: Sun, 25 September 2016, 11:35:08 »
Happy Hacking Pro2
Offline Adgar
    • Pheilcia
« Reply #61 on: Tue, 27 September 2016, 03:29:38 »
Bluetooth make it perfect for a traveller. Besides, we should take the weight into our condieration. How about the weight of this HHBK.
Offline Adgar
    • Pheilcia
« Reply #62 on: Tue, 27 September 2016, 03:33:50 »
Beamspring!
I am not prepare to use it in a Coffe bar or some public location. I prefer using it in my hotel. But I think it  doesn't matter to care that . We love machanical keyboard so much and that maybe cool to use our lovely keyboard in front of public.
Offline Adgar
    • Pheilcia
« Reply #63 on: Tue, 27 September 2016, 20:03:35 »
Anything else besides HHBK. :cool: :cool: :cool: :cool:
Offline 0100010
  • Not Sure
« Reply #64 on: Tue, 27 September 2016, 22:25:09 »
Beamspring!
Smallest beamspring I know is the IBM 2976 mobile terminal.
Offline captsis
  • Formerly matt2dlg
« Reply #65 on: Tue, 27 September 2016, 22:28:33 »
Beamspring!
Is that a cop? probably was used as a baton!
Offline AMongoose
  • happy workman user
« Reply #66 on: Wed, 28 September 2016, 04:09:25 »
That is so cute
Offline PollandAkuma
« Reply #67 on: Wed, 28 September 2016, 04:59:55 »
miniVan or JD45 depending on what type of work I need to do.
What makes them good for your different types of work?
« Reply #68 on: Wed, 28 September 2016, 05:03:38 »
If I had a 40% that would be my travelling board. But I only have a Poker 2 :/
Offline chuckdee
« Reply #69 on: Wed, 28 September 2016, 17:36:34 »
The miniVan is a bit smaller than the JD45, and works well for me for writing, i.e. just really using the qwerty in any case.  The JD45 has by default the double legends, which makes it easier for me for coding and such if I have to.  Add to that the fact that my JD45 is bluetooth.
Offline Adgar
    • Pheilcia
« Reply #70 on: Thu, 29 September 2016, 01:12:26 »
I think if you do not have much requirements. The porker 2 is enough. Comparing with HHBK. I like the keycap of porker 2
« Reply #71 on: Thu, 29 September 2016, 05:43:36 »
You mean Poker?  :)) "Porker' sounds delicious though haha.
I know deep in my heart that a cheap (read: poker is "cheap") 60% mech is more enough for the next four years... Try convincing my greed that one is enough  :blank:
Offline ace_of_dunces
« Reply #72 on: Fri, 30 September 2016, 10:42:39 »
I just got a MiniVan for coding while traveling. Hopefully it's not too restrictive.
Wow, nice setup! And thanks for the link. Is it very bulky?
Offline chuckdee
« Reply #73 on: Fri, 30 September 2016, 14:09:39 »
It should be fine - it's really a matter of your key map and taking the time to get it set up for your needs.   I could use the minivan for coding,  but the JD45 has more keys,  and I could get a better layout on it,  and not having to share the same maps or deal with more layers to get both was just a bonus.
« Reply #74 on: Sat, 01 October 2016, 16:04:55 »
Yeah, it seems like getting the mapping right is crucial. For me it'll have to be a balance between what's practical and what will keep tendinitis at bay. If it doesn't work out I guess I'll just have to give the JD45 a try haha
Offline Adgar
    • Pheilcia
« Reply #75 on: Sun, 09 October 2016, 21:18:52 »
In fact, The Duck mini is also a good choice. Look at this one . It looks pretty cute.
Offline Adgar
    • Pheilcia
« Reply #76 on: Tue, 11 October 2016, 02:14:18 »
It reminds me old time
That is so cute
Offline ArchDill
« Reply #77 on: Tue, 11 October 2016, 02:23:33 »
I use a Noppoo Lolita Spyder. Perfect size. Switched the caps out with ABS double shots and modded the usb cable to not be so long. I made a case for it and it fits in my bag perfect. Has Kailh Browns.
Offline Adgar
    • Pheilcia
« Reply #78 on: Tue, 11 October 2016, 21:39:25 »
Oh , that sounds great. Can  you show us the picture of your wonderdul Keyboard? ;D ;D ;D ;D ;D ;D ;D
Offline ArchDill
« Reply #79 on: Wed, 12 October 2016, 00:03:33 »
Here it is. This is before I did the cable mod. The key caps don't look as bright in person. They are more olive drab. Also, by "case" I meant a sleeve.
150342-0
Offline Adgar
    • Pheilcia
« Reply #80 on: Wed, 12 October 2016, 02:38:13 »
Green and black belong to cooler color that accords with  men's favor generally. ;D ;D. But I also like white and blue. Like the layout of White Fox Keycap. Somehow. I think it will be perfect if your nice keyboard  can throw away USB and equipped with bluetooth ;D ;especially when you  go out. If you are a geek. I think maybe you will have the same idea.
Offline Adgar
    • Pheilcia
« Reply #81 on: Thu, 13 October 2016, 00:06:03 »
It gonna be perfect if match with nice keycaps. The black keycap  looks boring.
Offline yowaffle
« Reply #82 on: Thu, 13 October 2016, 00:53:35 »
Yea i have the same case on my poker II and currently use that as my travel board. I also ordered the MiniVan and will probably switch between the 2 when traveling depending on my mood
V60 [MQC] | KC60 [Zealiostotles] | Leopold FC660c [Topre] |  Ducky Shine 4 [MX Brown] | MiniVan [Zealios]
Offline Adgar
    • Pheilcia
« Reply #83 on: Thu, 13 October 2016, 21:18:38 »
Which kind of Minivan you will buy. The standards or the arrow layout.
Offline yowaffle
« Reply #84 on: Thu, 13 October 2016, 23:08:49 »
It was a tough-ish decision for me but I decided to go with the standard layout. The only times I find it convenient to have the arrow keys is at work and I don't plan on bringing it to work.
Offline Adgar
    • Pheilcia
« Reply #85 on: Fri, 14 October 2016, 02:45:30 »
In fact, I am a little confused about your answer. I seems the arrow is much better for travel. But you choose the standar.
Offline yowaffle
« Reply #86 on: Fri, 14 October 2016, 11:13:56 »
Even with standard there are still arrow keys, they just live in a function layer. When traveling, I don't use the arrow keys a lot so I went with standard.
Offline chuckdee
« Reply #87 on: Fri, 14 October 2016, 12:55:12 »
Yeah... I debated getting the arrow key one when he introduced it... but like you said, when typing on something this small, it seemed a waste.
Offline MJL
« Reply #88 on: Sun, 16 October 2016, 18:15:32 »
After 25+ laptops I went to small form factor desktops. (too many damaged in overhead lockers on the plane by inconsiderate fellow travelers). Went years ago to an Apple Mac mini with Apple A1242 keyboard. Am in the process of replacing that setup with an ASUS VC65R (up and running) with a Leopold FC660M (eagerly waiting for, has been shipped).
Offline Adgar
    • Pheilcia
« Reply #89 on: Sun, 16 October 2016, 21:07:44 »
You are right.Both the arrow and standard are small enough to satisfy our need when we go out. But the arrow is a little inconvenient.
Offline Adgar
    • Pheilcia
« Reply #90 on: Mon, 17 October 2016, 21:37:43 »
This is the KB DaleSnail has referring to.
seems this one is too small ...
Offline Adgar
    • Pheilcia
« Reply #91 on: Mon, 31 October 2016, 00:57:21 »
Is there any new ideas.
Offline Pennyz
  • Vegeta
« Reply #92 on: Mon, 31 October 2016, 01:11:11 »
lambo 60% is just ok.
I ♥ Night Caps.  I ♥♥♥ Bro Caps
Offline Adgar
    • Pheilcia
« Reply #93 on: Mon, 31 October 2016, 01:14:52 »
Offline menuhin
« Reply #94 on: Mon, 31 October 2016, 05:13:48 »
For mobile setup, I would suggest trying out a ThinkPad - carrying just 1 piece of equipment is always the best, and usually people would find the ThinkPad keyboard agreeable.
Otherwise, then it would be a Surface Pro 4 (or similar form factor computer) + keyboard setup. And I suggest HHKB for its light weight and size or something like Pok3r or GH60.
If you really want a 75% which is understandable if you need to work on codes, then in China, it's easy to get a PLUM 84. PLUM 84 is decently built and has relatively light weight capacitive key switches at the 35g, oh, and it's fully customizable and programmable. I've heard some of them can even support dual mode (USB + bluetooth). Other working-out-of-the-box choice would be Noppoo Choc mini, where you have many options for Cherry switches and Gateron switches. I believe they've fixed most of the firmware problems existed in their earlier versions. Both of these Chinese 75% keyboards mentioned have the 5.5x space bar which is a pain in the ass to find replacement keys if you love to play with caps; however, these space bar caps themselves on the two boards are of decent quality made of thick PBT and thick POM.
Other 75% options are much more expensive and for most of them you need to make customized orders from makers: I really like Red Scarf 84 and Duck Octagon but they're not as mobile with those feet.
I am a believer of the 75% form factor. I think it should be the modern standard event for desktop computers and the number pad should be located on the left hand side of the keyboard if one ever needs that.
Please show us what you end up, there are so many keyboard clubs and sellers and makers in China.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Crapbag
« Reply #95 on: Mon, 31 October 2016, 14:19:49 »
Nice!  Did it come from a Pawn shop?
Offline MJL
« Reply #96 on: Mon, 31 October 2016, 17:52:12 »
Leopold FC660M with Leopold dye-sub keycaps
Offline losing_ctrl
« Reply #97 on: Mon, 31 October 2016, 18:58:17 »
Very nice. Very classy!
That would be a great travel board.
« Reply #98 on: Mon, 31 October 2016, 19:24:52 »
I want an Atreus. I want it so bad. I just wish it has topre switches. Should I get HHKB JIS then? i really hate how far away my "y" key is to reach for on my poker  :confused:
Offline Minnie2
« Reply #99 on: Tue, 01 November 2016, 00:12:40 »
I would take a 60% board. I think it is convenient enough,It also has the basic position, but also not too heavy.
    A Bro Caps Fan
Just wanted to make sure everyone sees that information. A lot of people missed it ;)
