Author Topic: New keyboard... deciding on switch  (Read 2055 times)
Offline smoke070
« on: Thu, 08 September 2016, 16:41:00 »
Hello community.. first post in a while but getting a new keyboard :)
I am thinking about getting either a Cherry MX Red, Clear, or Brown. Needs to be full size, around $100, don't care about backlighting. I do a lot of typing for work, and I like playing typing games occasionally, so I am typically working at about 120+ wpm. I want a keyboard that has very low resistance so I can type very fast at all times but also be comfortable in the long term.
It looks like Cherry MX Red is very fast, but should I be looking to have an actuation point? Clear might be better then, but are harder to find than Browns.
Offline klennkellon
  • I like bottoming out
Re: New keyboard... deciding on switch
« Reply #1 on: Thu, 08 September 2016, 16:53:29 »
All MX switches actuate around the same, except for Cherry MX Speed which actuate higher up.
If you need full sized I would get a Dell AT-101w. They use SKCM Black Alps which are like MX Browns except they are more tactile and actuate higher up. Plus the keyboard is built like a tank.
Offline jaffers
« Reply #2 on: Thu, 08 September 2016, 16:55:32 »
Clears are good
Offline smoke070
« Reply #3 on: Thu, 08 September 2016, 17:02:13 »
Would prefer something new and currently being produced even though I do appreciate the old stuff.
Offline Geroximo
« Reply #4 on: Thu, 08 September 2016, 19:03:20 »
I hate to say it, but nobody here can tell you which switch you will like the most. It's trial and error for everyone.
Offline Axiomatik
« Reply #5 on: Thu, 08 September 2016, 23:05:58 »
MX has those new Silver switches, that are supposedly very fast.
-Axiomatik
Offline Birdsht
« Reply #6 on: Fri, 09 September 2016, 00:12:53 »
You might want to try a switch tester.
This tester will let you try 7 different Gateron switches.  You will at least know exactly what you are dealing with.
http://www.ebay.com/itm/272330151731?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have a friend that just got the mx speed switches on a corsair board and I would not suggest them for typing.  From what I can gather I would not use them at all.
A few resources covering switch types:
https://deskthority.net/wiki/Cherry_MX
https://deskthority.net/wiki/Category:Gateron_switches
http://imgur.com/a/MjDTX
http://imgur.com/a/9jqPi
« Last Edit: Fri, 09 September 2016, 05:19:28 by Birdsht »
