Author Topic: [PACKAGING] 88 Commando: Combat Soldier SA Keyset - Army font  (Read 173000 times)
Offline jil_jil32
  • Tokyo Press <3
« on: Fri, 09 September 2016, 13:39:46 »
"88 Commando: Combat Soldier" keyset
Fighting to protect.
PACKAGING!
ORDER HERE => goo.gl/LtniQG
- Double-shot keyset
- SA family (1-1-2-3-4-4)
- Semi-matte finish surface
UPDATES April 26 2019
Me, a summer afternoon, so far so good.
Uhhhohhh, that's delicious. Wait for me...
Ugghhh, what's this @!#$?
To be continued...
Here -> https://imgur.com/a/xFbSdbr
1 - Combat Soldier kit - $95
2 - Upgrade kit 01 - $45
3 - Upgrade kit 02 - $25
4 - Numpad kit - $30
5 - Gamer kit - $15
6 - S:76 kit - $10
7 - CS kit - $50
8 - Forest Commando kit - $70
9 - ErgoDox kit - $30
10 - Vietnamese Lotus kit - $15/50
11 - WASD kit - $10
12 - Blank kit - $20
13 - Enter kit - $15
23 - Ghost Commander set - $250
88 Commando - Mock-ups
PACKAGING!
« Last Edit: Fri, 26 April 2019, 01:25:08 by jil_jil32 »
Offline jil_jil32
  • Tokyo Press <3
Re: [TAKING ORDERS] 88 Commando: Combat Soldier SA Keyset - Army font
« Reply #1 on: Fri, 09 September 2016, 13:39:53 »
Details of the kits
!!! As many people keep asking me in my IC form about the size of the Army font legends (why those being too small for Function Row, Number Row, ...), I would like to thank for your interest, and also to tell you that what you saw are just my very simple mock-ups to help you get the idea about the keyset. The mock-ups shall only give you the rough ideas of what text, what colors, what symbols, ... will be used.
Since almost every legend will be made from scratch, I and my artwork file maker (HUGE thank to this guy) are working hard and closely together to make every single legend one by one. And because I'm a picky person when it comes to little details of the Keyset which I love, we may have to revise the artwork files many more times to get the best ones using in the GB. Those need to match the manufaturer specs too so there are still lots of work for us to do.
So, in short, the legends for Function Row, Number Row or Modifiers on the actual product of the keyset will be larger, spreading more evenly and wider on top surface of the key cap, and it shall look more well balanced with the Alpha legends.
Thank you!!
- This kit is required as minimum order.
- Top to Bottom: R1 - R1 - R1 - R2 - R3 - R4 - R4 - Spacebar
- For common 87 keys layout keyboard.
- Stepped Caps Lock included.
- Extra Function Row keys.
- Extra 2.25u ROW3 key as Enter replacement.
- F & J are deep-dish keys.
- Green VF, Beige GAW, Brown TBN
2 - Upgrade kit 01
- Top to Bottom: R1 -  R3 - R4 - R4 - R4 - R4
- For special needs (1.5u ROW4, 7u Spacebar, 1.75u Shift ROW4, ...).
- Extra 2u ROW1 key as Backspace replacement.
- Extra Stepped and Full touch 1.75u ROW3 .
- 2 extra 2.25u ROW3 keys as Enter replacement.
- Extra 1.5u ROW4 keys, 1.25u ROW4 keys, 1u ROW4 keys.
3 - Upgrade kit 02
- Top to Bottom: R1 - R2 - R3 - R4
- Upgrade kit for special needs (ISO Enter, ...).
- Extra 2.25u Shift.
- 2* 1.75u ROW4 keys.
- 1.25u ROW4 key.
4 - Numpad kit
- Top to Bottom: R1- R1 - R2 - R3 - R4 - R4 - R4
- For regular Numpad or 104 keys layout keyboard.
- 5 is deep-dish key.
- Extra Symbol key as Enter replacement.
5 - Gamer kit
6 - S:76 kit
7 - CS kit
- Top to Bottom: R1 - R1 - R2 - R3 - R4
- The kit includes 03 Pad-printed images on the keys of your choices. Images are available in Brown color and are center aligned.
- By default, the images will be printed on 1.25u CTRL, 2.25u SHIFT and 6.2u Spacebar in your Combat Soldier kit.
- You can choose to have another key in your order printed instead (no additional cost), or you can order extra keys of any size then have it printed (with flat $5 each key).
- No printed-images order is also accepted but without any discount.
- Top to Bottom: R1 - R1 - R2 - R3 - R4 - R4
- Green VH
9 - ErgoDox kit
- 20* 1u VF keys (2* ROW1 with Symbols, 10* ROW4, 4* ROW2, 4* ROW3).
- 12* 1.5u VF keys (2* ROW1 with Symbols, 2* ROW2, 6* ROW3, 2* ROW4).
- 4* 2u VF keys ROW3 (2 Symbol keys).
- ROW3 gloss finish surface.
- Full kit contains 24 keys with 24 diffirent colors. 6 out of 24 are misterious colors.
- Kit of 6 contains 6 random choosen keys of total 24 keys.
- There's a limit of 24 VL keys per Combat Soldier kit, and 24 VL keys per Ghost Commander set. If you buy both Combat Soldier kit and Ghost Commander set, you can order up to 48 VL keys.
11 - WASD kit
- People who donated for Commando Project during the Valentine Groupbuy will get this kit for free of charge. Thank you again for your generous help when I needed it the most. Please give me a note in case you are the one!
12 - Blank key/kit
- Kit includes 2u, 2.25u, 2.75u and 3u blank keys in Green VF color, ROW4 profile.
- If you order 01 kit then would like to have extra blank keys, it will be $5 each.
- Otherwise you can purchase individual key for $8 each.
13 - Enter kit
- 3* 2.25u ROW3 keys as Enter replacements.
- Limited quantity 88 sets.
- 01 set per order. Priority to purchase the set will go for highest donors in donation list from top to bottom.
- You are qualified to register for a slot to purchase this set when:
     + You join this GB with at least minimum order (Combat Soldier kit) - It will automatically get you into the donor list as a $0.99 donor. You may donate more to get higher rank in the donor list.
     + Or you don't join the GB but at least donate for a legend ($50) in my next Project with new theme (IC will be present in the next couple of weeks) - It will get you into the donor list as a $20 donor (considering $30 is the fee to jump in for this set). You may donate more to get higher rank in the donor list.
BUT NOTICE: If at the end you are not in the top 88 donors and you do not get the slot to order the set, your donation amount shall NOT be refunded. Please donate for the 1st reason as you love the work I'm delivering and would like to see more happen.
- At the end, if there are more qualified people than the available slots, the remaining slots will be random raffle for every donor in the donation list who doesn't get a slot yet.
!!! If you donated for Commando Keyset Project during the Valentine GB but didn't get the slot to purchase Love Sweet Love keyset then your donation amount will be considered for the GB this time instead.
Shipping
America orders will be shipped by our US proxy via USPS or orther express services of your choice.
Remaining orders will be shipped from Vietnam.
Shipping fee should be invoiced SEPARATELY by ME after your order has been sorted, packaged and is ready for shipping.
- I will try to provide the most suitable shipping method that secure and with fair price.
- There are normal shipping option (by Post System just like USPS) and EMS/FEDEX... option (express service with trackable & traceable number) for everyone to choose.
Example from previous GBs:
01 Full set of Valentine 2014 Pink & White keyset around 300g (normal shipping)
$16 to USA
$10 to Asian countries & Australia
- Handling & materials fee ~$3 also will be added to the total amount of shipping fee.
Notes
- Deadline for order & payment is 29 September 2016.
- The keyset is expected to be made, shipped and delivered to me before 25 May 2017.
- Order if you can pay the invoice within 2 days and don't have to use that money in the next 3-4 weeks. Your social life is the highest priority so if you have money problem please just save it.
- You will receive two invoices. One is for the key caps. The other is for the shipping fee. The invoice for keycaps will be sent to you after you fill the Order form (possibly 2-3 days delay). And you will be charged for shipping fee when your order's ready to be shipped to you.
- I will prepare some replacements for the faulty keys. Please be patient while I'm trying to help resolving the problem with your keyset if there's any. If anything bad happens to the package while on transit, I'm afraid I can NOT do much about it.
- Same as my previous GBs, there will be no extra set for sale after this GB get closed. So please put your order in before it's too late ;)
- I will send invoice through Paypal to everyone, so you need a VERIFIED Paypal account to receive, and to pay. Also please check the information carefully before submitting your order. There will be paypal fee added to the price.
- If you want to make changes to your order, please fill a new Form, or send me a PM: https://geekhack.org/index.php?action=pm;sa=send;u=6989.
« Last Edit: Thu, 06 December 2018, 13:29:42 by jil_jil32 »
Offline jil_jil32
  • Tokyo Press <3
« Reply #2 on: Fri, 09 September 2016, 13:40:03 »
Order list
GeekHack & R/MK & Taobao
  • jil_jil32
  • Sky - Sub-GB organizer @Taobao
  • lovestream1989 - Sub-GB organizer @Taobao
  • kenshinjeff - PAID
  • cswanic - PAID
  • tacnificent - PAID
  • scivive - PAID
  • rawrsor1 - PAID
  • FrostyToast - PAID
  • Ho Young Kim - PAID
  • sandifo - PAID
  • myan - PAID
  • hackerbeavis - PAID
  • jjwax - PAID
  • q1w2e3r4t5z - PAID
  • shengpizi - PAID
  • revbooyahi - PAID
  • Geckt - PAID
  • nasby99 - PAID
  • sdiearly - PAID
  • FatGuy - PAID
  • clicker - PAID
  • rsr - PAID
  • vicissitude - PAID
  • volcor - PAID
  • Kalopsia - PAID
  • gtxorb - PAID
  • tasik - PAID
  • Slash Emperor - PAID
  • neorobo - PAID
  • khuya - PAID
  • YOU
VNMK
  • thangtran - PAID
  • meowXVII - PAID*
  • chien198x - PAID
  • wasabi174 - PAID
  • blitzer - PAID
  • vincentalpha - PAID*
  • thanhnguyen561 - PAID
  • Hoang Vo - PAID
  • kimanageer - PAID
  • gik_nguyen - PAID
  • zabuza1997 - PAID*
  • TungQuan
  • herombe
  • quaiquai12 - PAID
  • hangf - PAID
  • taysungtre0111 - PAID
  • nmtien1609 - PAID
  • xoboomer - PAID
  • meobold - PAID
  • ms.hungle - PAID
« Last Edit: Sat, 01 October 2016, 22:16:29 by jil_jil32 »
Offline Hypocaffeinic
« Reply #3 on: Fri, 09 September 2016, 21:53:54 »
Great to see this going ahead!  :thumb:
So the overall deadline for orders & payment is 29 September, but if we submit an order at any time before that we still have to pay within two days?
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #4 on: Sat, 10 September 2016, 00:20:52 »
Its awesome that you included VE.A spacebar support :thumb:
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline Zophos
« Reply #5 on: Sat, 10 September 2016, 01:21:45 »
What a great job with this set!
Keep it up guys!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #6 on: Sat, 10 September 2016, 01:36:22 »
so tempted, but It depends if that ghost commander set is still available on the 19th  :confused:
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #7 on: Sat, 10 September 2016, 03:58:25 »
Thanks for getting this up and running BUT the order deadline is quite severe here.
Can't complain because that are the rules, it will be tight getting my order in before the 29th of this month but it shall be done for all 3 colour versions  :thumb: .
Offline jil_jil32
  • Tokyo Press <3
« Reply #8 on: Sat, 10 September 2016, 07:30:51 »
Yes I would like to have confirmed orders so please order only if you are ready to process the payment within 48 hours.
Thanks! Did I miss any key by the way?
Keep it up guys!
Thank you!!
The donation list will be closed on 29/09 then we will see who the top 88 donors are. So there are the chances!!
I hope we can somehow manage it because I know you love this set just as much as I do! Thank you Elrick!
Offline jil_jil32
  • Tokyo Press <3
« Reply #9 on: Sat, 10 September 2016, 07:49:36 »
And for US participants, I'm contacting a vendor there to help me as a proxy in the US so please stay tuned!
Offline Phenix
« Reply #10 on: Sat, 10 September 2016, 11:52:29 »
Lovely set! Why isnt there an international /german kit?
Winter is coming.
Offline Shados
« Reply #11 on: Sat, 10 September 2016, 18:51:26 »
Well, that's awkward. The only colour scheme I like here is the Ghost Commander one. Guess I'll have to pass on that.
Offline mes09
« Reply #12 on: Sun, 11 September 2016, 03:09:02 »
So if I'm reading this correctly I would need to buy a commando kit to purchase a Lotus kit?  I'd love to buy just the Lotus 24.
Offline yowaffle
« Reply #13 on: Sun, 11 September 2016, 17:47:43 »
Sitting this out since I already have the base set from the original commando. but if the kits become available without it I'm definitely interested in an upgrade kit and s76 kit
V60 [MQC] | KC60 [Zealiostotles] | Leopold FC660c [Topre] |  Ducky Shine 4 [MX Brown] | MiniVan [Zealios]
Offline tynorton
« Reply #14 on: Sun, 11 September 2016, 17:51:49 »
Also interested in the kits
Sent from my SM-N910U using Tapatalk
Offline jil_jil32
  • Tokyo Press <3
« Reply #15 on: Sun, 11 September 2016, 19:47:55 »
Thank you! Sorry for the missing of that kit because I didn't receive any request or suggestion about it during the IC phase.
That's a bit sad to hear though.
Sorry for any trouble it may cause to you guys. But maybe it's a good chance to make some friends and combine orders! There are people ordering only the Combat Soldier kit.
Offline Zophos
« Reply #16 on: Mon, 12 September 2016, 00:53:14 »
I will be ordering a kit most probably, anyone from the EU, interested in the kits only can PM me to see if we can work something out.
Offline tacnificent
« Reply #17 on: Mon, 12 September 2016, 09:19:33 »
Keep us posted
I filled out the form already not having seen this.
Offline mes09
« Reply #18 on: Mon, 12 September 2016, 09:54:04 »
Thank you for the clarification!
Offline Vigrith
« Reply #19 on: Mon, 12 September 2016, 09:56:54 »
Very kind! PM'd.
Offline Rawrsor
« Reply #20 on: Mon, 12 September 2016, 14:03:00 »
Joined! Was a little hesitant at first because of the legends, but they grew on me :)
TINA-C | Gat Blacks /// JD45 | Jailhouse Greens /// JD40 | 65g Zealios /// Minivan | Fosen Aquamarines /// JJ50 | Kailh Box Blacks /// KC60 | Cherry Clears
Offline Phenix
« Reply #21 on: Mon, 12 September 2016, 16:33:04 »
Well, then I guess you wont bring quick a intl (or just German) adapter set. (essentially copy e. G carbon intl)
too bad, I really like the font
Winter is coming.
Offline jil_jil32
  • Tokyo Press <3
« Reply #22 on: Mon, 12 September 2016, 20:41:40 »
GOOD NEWS: I've got us an US proxy, so America orders will be automatically shipped by USPS (or UPS/other services if you would like).
1st wave of invoices will be sent out very soon!
Thank you very much for the early orders!
Offline jil_jil32
  • Tokyo Press <3
« Reply #23 on: Tue, 13 September 2016, 22:56:48 »
Invoices sent!
Offline yowaffle
« Reply #24 on: Wed, 14 September 2016, 05:00:49 »
If anyone from the US would like to help me get an upgrade kit that'd be awesome!
Offline jil_jil32
  • Tokyo Press <3
« Reply #25 on: Wed, 14 September 2016, 05:39:15 »
Where are those arrows in front of WASD keys in CS kit from?  :p
Offline tacnificent
« Reply #26 on: Wed, 14 September 2016, 09:21:18 »
Payment sent.
Thanks
Offline jil_jil32
  • Tokyo Press <3
« Reply #27 on: Wed, 14 September 2016, 10:31:10 »
Payment sent.
Thanks
Received and updated order list. Thank you!  :thumb:
Offline chuckdee
« Reply #28 on: Wed, 14 September 2016, 10:38:04 »
What is the expected timeline with this set?  I don't see that one detail, though I may have missed it?
Offline jil_jil32
  • Tokyo Press <3
« Reply #29 on: Wed, 14 September 2016, 10:55:13 »
Oh it's in the form "The keyset is expected to be made, shipped and delivered to me before 25 May 2017."
Offline chuckdee
« Reply #30 on: Wed, 14 September 2016, 14:39:07 »
You might want to update your info area with it  ;)
Offline jil_jil32
  • Tokyo Press <3
« Reply #31 on: Wed, 14 September 2016, 21:47:30 »
Yes of course! I updated the Notes so people can see it now without having to click to the Order form link.
Thank you!!
Offline jil_jil32
  • Tokyo Press <3
« Reply #32 on: Fri, 16 September 2016, 09:34:30 »
Fighting! Wow so many amazing GBs at the same time!
Offline Geckt
« Reply #33 on: Sat, 17 September 2016, 21:30:23 »
Hoping this makes the cut for moq.
This is the only one I'm eyeing, no other keyset has my attention atm.
Offline kaeeeede
« Reply #34 on: Sun, 18 September 2016, 02:44:10 »
I feel like you running ghost commander in this manner is going to cause less people to be interested. If it was just first 88 or even a raffle I could see it working, but having to spend at least $100 just to be considered for the set and having a blind auction is kinda insane.
Offline jil_jil32
  • Tokyo Press <3
« Reply #35 on: Sun, 18 September 2016, 23:40:35 »
Thanks for your interests! It looks like I got >50% of the MOQ needed and we still have 2 more weeks to go (though many GBs pop up at the same time)
And I'm still waiting for your order  :thumb:
The Combat Soldier kit and its add-ons are still the main dishes, and people should consider it as "limited" too. Because I won't run it again.
The color combination started years ago with the 23 Commando GB, and now with new font & novelties the keyset will be "complete" to me if we make it this time, then I will move on since I have other projects with the new font.
Thanks everyone for your support so far!!  :thumb: :thumb:
Offline laminam
« Reply #36 on: Sun, 18 September 2016, 23:45:41 »
Definitely. The only kit I'm even interested in is ghost commander. Not paying $100 to for a chance to spend more.
Offline jil_jil32
  • Tokyo Press <3
« Reply #37 on: Sun, 18 September 2016, 23:56:09 »
Another option: you can just donate $50 so you will be in the donor list as a $20 donor.
Buying the Combat Soldier kit at $95 and get in to the donor list as a $0.99 donor is for people who are interested in the Combat Solder kit as well. There are people don't buy the Ghost Commander set so you might want to try combine orders with them.
Offline Geckt
« Reply #38 on: Mon, 19 September 2016, 04:33:49 »
@jiljil_32
Just filled in the form, could you also pm me the list of kits I opted for as well along with my invoice?
I think I might have missed out a few items.
« Last Edit: Mon, 19 September 2016, 04:43:09 by Geckt »
Offline jil_jil32
  • Tokyo Press <3
« Reply #39 on: Mon, 19 September 2016, 04:53:56 »
@jiljil_32
Just in case please fill a new form to make sure you've picked everything you need.
Invoice will be sent soon with list of items so do not worry.
Invoice sending might be delayed a bit since I'm in the middle of changing my ISP so my internet connection is not stable atm.
And thank you for the order! <3
Offline KetchyKech
« Reply #40 on: Mon, 19 September 2016, 05:52:14 »
really wanna get in this....will try to before the 29th  :p  :thumb:
Offline Geckt
« Reply #41 on: Mon, 19 September 2016, 08:21:24 »
@jiljil_32
Alright, I have corrected the lists of kits I wanted.
I had to correct the pad printing to default and not "NO". ;D
PS: Really wished that the Ghost Commander set didn't have to be made altogether with your "Combat" and "Forest" sets at the same time. Hope it is at least offered again with your future OW design as if that's possible.
« Last Edit: Mon, 19 September 2016, 08:48:22 by Geckt »
Offline weifanwang
« Reply #42 on: Mon, 19 September 2016, 12:22:56 »
Can I only buy the Upgrade kit 01? I have 23 Commando.
Offline martinyeah
« Reply #43 on: Mon, 19 September 2016, 15:26:20 »
Support!!!!!!
Offline Geckt
« Reply #44 on: Tue, 20 September 2016, 02:25:02 »
Support!!!!!!
@martinyeah
Is that an RS68 with dual LEDs?
Sent from my 2013023 using Tapatalk
Offline simonyunhe
« Reply #45 on: Tue, 20 September 2016, 02:42:15 »
Support!!!!!!
@martinyeah
I believe that is the Smart68, see the fn key located beside the spacebar.
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
Offline Geckt
« Reply #46 on: Tue, 20 September 2016, 03:55:50 »
Support!!!!!!
@martinyeah
ooh, I see. it looks just about the same
Offline punksinatra
    • Random Stuff
« Reply #47 on: Tue, 20 September 2016, 09:11:08 »
I did see this being posted in taobao. I think someone from China is organizing a group buy
Offline jil_jil32
  • Tokyo Press <3
« Reply #48 on: Tue, 20 September 2016, 21:32:26 »
Yes please!
Thank you for your order!
The Ghost Commander SA might reappear in 2023 I guess xD. I have no confirmed plan for it atm.
Sorry the minimum order requires 01 Combat Soldier kit. You might try to contact someone in the order list and combine orders with them.
Support!!!!!!
 :thumb:  :-*  :thumb:
Yes there are sub buys going @ Taobao. If you are able to buy @ Taobao please join there.
Offline jil_jil32
  • Tokyo Press <3
« Reply #49 on: Thu, 22 September 2016, 02:41:56 »
Fighting! One more week to go!
