Author Topic: School me on ALPS TKL options  (Read 3283 times)
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« on: Fri, 09 September 2016, 21:45:17 »
So what else is out there that might be a bit more obtainable than the leeku pcb/plate option in an Orion?
« Last Edit: Fri, 09 September 2016, 22:12:53 by boostdemon »
-Dana
Offline klennkellon
  • I like bottoming out
Re: School me on ALPS TKL options
« Reply #1 on: Fri, 09 September 2016, 22:42:40 »
You can buy a KBParadise V80 with Matias or Fukkas and swap the switches. It's already programmed so all you have to do is swap the switches.
Offline E3E
« Reply #2 on: Fri, 09 September 2016, 23:05:18 »
A Leeku PCB/plate option for LZ custom keyboards?  :p
Offline OfTheWild
« Reply #3 on: Fri, 09 September 2016, 23:09:55 »
Oh very cool. I just read cptbadass's review and it sound like a good option to get going.
-Dana
Offline Hak Foo
  • Make America Clicky Again!
« Reply #4 on: Fri, 09 September 2016, 23:47:59 »
Ducky 1087XM if you can find one.
Overton130, Box Pale Blues.
Offline E3E
« Reply #5 on: Sat, 10 September 2016, 00:03:55 »
On that note, a Filco Zero works too, and I believe it works with Frosty Flake or whatever custom controllers are compatible with Filcos (not all that familiar), so you can turn it into a fully programmable keyboard.
Offline E3E
« Reply #6 on: Sat, 10 September 2016, 00:13:32 »
Offline klennkellon
« Reply #7 on: Sat, 10 September 2016, 15:51:30 »
The Zero is suppossed to be very similarly built and looking to the V80 as well. I wonder if KBParadise made the Zeros?
Offline mike52787
  • Alps Aficionado
« Reply #8 on: Sun, 11 September 2016, 10:52:31 »
will a v80 plate and pcb fit in a filco style tkl case? theres a sweet aluminium filco case on pmk.
Offline Delirious
« Reply #9 on: Sun, 11 September 2016, 13:45:42 »
Yes, you can check it out here
I'm holding off on buying KB v80 until we have confirmation that it works with Pegasus Hoof like the good old Filco.
Offline Wingpad
  • The Kumquat Kid
« Reply #10 on: Sun, 11 September 2016, 15:35:04 »
This might end up being what I do with my extra Blue Alps, it's way too cool! I am waiting to give Zealiostotles a try before I settle on my next clicky keyboard build but I know I'm definitely shooting for an aluminum case and TKL this time around. If I'm going with Blue Alps I could just wait for the Rosa/BlueNalgene's GB, though... Decisions, Decisions!
