Author Topic: Restocking Varmilo vb87m?  (Read 79168 times)
Offline lolkey
« on: Tue, 13 September 2016, 23:30:14 »
Are there any plans to restock the vb87m with gateron switches?
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: Restocking Varmilo vb87m?
« Reply #1 on: Mon, 19 September 2016, 12:06:46 »
So sorry for the delayed response.
We have no active plans to do so. IMHO there are better alternatives available soon which allow both Bluetooth AND USB connectivity. This model is Bluetooth only, with USB charging.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline geostation
« Reply #2 on: Sat, 01 October 2016, 06:53:38 »
care to mention these better alternatives ?
Offline Heezy
  • Formerly trynds
« Reply #3 on: Sat, 01 October 2016, 08:55:15 »
https://geekhack.org/index.php?board=192.0
they have their own subforum here, you can email them, ask for a price list, and then you can choose and build from there. you can choose your own led and gateron switches.
Rig - i3 6300, 240GB SSD, 500GB SSD, Gigabyte H170N Wifi, 16GB DDR4, Zotac 1060 Mini, 650w SuperFlower
Monitor - HKC144hz Mouse/Mousepad/Keyboard - Zowie EC1A - Zowie GS-R - Zowie Camade - Filco TKL MX Pink
Offline geostation
« Reply #4 on: Sat, 01 October 2016, 17:55:26 »
sorry  i wasnt clear, i already have a VB87M , i was looking for upcoming ones with with bt + usb and preferably programmable ones
Offline 00zeRO
  • * Moderator
« Reply #5 on: Sun, 02 October 2016, 08:12:22 »
We will see what we can do
Offline victorhooi
« Reply #6 on: Mon, 24 October 2016, 00:02:41 »
I had a look on https://geekhack.org/index.php?board=192.0, and wasn't able to see any USB+Bluetooth keyboards?
You mentioned there are better alternatives to the Varmilo VB87M - to confirm, these are new keyboards in the pipeline from Varmilo?
Or if not Varmilo, what other USB + Bluetooth keyboards would you recommend?
Offline 00zeRO
  • * Moderator
« Reply #7 on: Wed, 26 October 2016, 10:29:19 »
Easy, check out the following:
https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=342
Offline Kvracing
« Reply #8 on: Tue, 24 July 2018, 08:57:09 »
This isn't backlit, which is a huge deal for some of us.
