Author Topic: I wonder why this isn't a thing (Like Hydro but BETTER??)  (Read 5615 times)
Offline pixelpusher
« on: Mon, 19 September 2016, 10:38:00 »
I wonder why no one has thought of producing a good quality doubleshot set with:
  • white or light gray alphas with translucent legends
  • dark gray modifiers with translucent legends
Then you set your RGB backlighting to blue and you have HYDRO  :p    You could even include a novelty item or two in all transparent to get full color (through your RGB backlighting) on the keycap.
I'm almost tempted to get some cheap Vortex caps and dye them for this effect!  I guess we've yet to see translucent caps praised for their quality??  Why is this not a thing??
TLDR: Two-toned doubleshot with POM transparent legends that is classic yet interesting with RGB backlighting.
« Last Edit: Mon, 19 September 2016, 10:40:20 by reececonrad »
Offline Fictiouz
  • That "White" Guy
Re: I wonder why this isn't a thing (Like Hydro but BETTER??)
« Reply #1 on: Mon, 19 September 2016, 10:45:39 »
A lot of people value no keycap glow through there keycaps here and would rather see the glow around their keycaps. I understand where you are coming from, but GMK is also held with great high regards in terms of quality of their caps.
I would definitely check out massdrop though if those are keys that interest you. They pop up every now and then for a fairly good price.
« Last Edit: Mon, 19 September 2016, 10:48:15 by Fictiouz »
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #2 on: Mon, 19 September 2016, 11:32:05 »
Because RGB backlit is dead to me.
Offline Moistgun
  • Slippery When Wet
« Reply #3 on: Mon, 19 September 2016, 11:38:57 »
Yeah, shine through looks like bootyhole.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #4 on: Mon, 19 September 2016, 11:42:45 »
Idk man. Define better.
Offline pixelpusher
« Reply #5 on: Mon, 19 September 2016, 13:31:29 »
More options.  Don't like blue? Go pink or orange or green
I don't like the way thin caps let light through either, but every now and then I need some backlighting. :)
I might pick them up and experiment.  From what I've seen, once the pbt portion is dyed slightly, the amount of shine through is minimal.  It's mostly just through the POM material. I wish someone other than vortex would try it out. I guess the only way it would look perfect is if it switch and led were designed like the Logitech ones with the focused lens in the center of the stem
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #6 on: Mon, 19 September 2016, 13:43:35 »
Because LED's on most keyboards are not centered. They are either bottom or top mounted. Some letters on the keyboard will not be lit, giving an uneven look. gross.
Also if you are not going to use thick ass pbt, you are going to get bleeding through the cap.
Offline Auxo
  • Formerly CJD_Anthony
« Reply #7 on: Tue, 20 September 2016, 11:08:31 »
Most everybody on this community will tell you that shinethrough keycaps are a no go. the novelty of shinethrough/backlit keycaps are usually outclassed by a good colorway designed to mesh with various custom keyboard builds/designs
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #8 on: Wed, 21 September 2016, 00:18:26 »
I agree.
Offline smithyithy
  • a l p s
« Reply #9 on: Tue, 10 January 2017, 13:09:10 »
I kinda feel the same, in fact I'd go as far as to say backlighting doesn't really interest me at all.
I'd prefer a nice underglow for the case than light around the keys
KBD75; Alps64 trio; some other stuff
Offline Valaris
« Reply #10 on: Fri, 13 January 2017, 09:37:39 »
And that's exactly why I jumped on the Nylon Diffuser version of the M65-A
Offline FLOCKA
  • New name: ghostdeini
« Reply #11 on: Sat, 14 January 2017, 21:39:57 »
Typing in the dark isn't great for your eyes anyways. More "ambient" light, separate from your screen, reduces eye strain... and therefore negates the need for shine-through backlighting.
Plus it does look like bootyhole, as mentioned previously.  :))
