Author Topic: [WTB] SSK bolt mods  (Read 3070 times)
Offline y11971alex
  • Trade Count: (0)
  • Looking for Toronto meetup
[WTB] SSK bolt mods
« on: Fri, 23 September 2016, 13:22:21 »
Want to buy 2 SSK bolt mods.
« Last Edit: Fri, 16 December 2016, 19:05:28 by y11971alex »
  • Trade Count: (1)
Re: [WTB] Model F 122 foam
« Reply #1 on: Fri, 23 September 2016, 18:40:49 »
How much would you be willing to pay? It would take some driving time to the art store, messing around, packing, etc.
And postage to Canada will be at least $8-$10, since it would be rolled up in a tube.
- D Trump 2026-10-24
Offline y11971alex
  • Trade Count: (0)
« Reply #2 on: Fri, 23 September 2016, 19:50:04 »
Can you PM me your offer?
Offline alh84001
  • Trade Count: (0)
« Reply #3 on: Sun, 25 September 2016, 03:37:07 »
Did you check with lot_lizard at https://deskthority.net/for-sale-f55/model-mf-the-haul-parts-from-harvested-ibm-model-f-s-t14377.html? He has no foams listed, but I would be surprised if there weren't any.
Offline y11971alex
  • Trade Count: (0)
« Reply #4 on: Sun, 25 September 2016, 03:50:33 »
I'll check with lot_lizard, but I'm current working out something with fohat.
  • Trade Count: (1)
« Reply #5 on: Sun, 25 September 2016, 17:22:56 »
The original foam, even in excellent condition, is fairly thin and soft with a "skin" layer on one side.
As it deteriorates, the "skin" becomes sticky and the foam turns into gritty particles. The advantage of re-using original foam is that there is little pressure and re-assembly is probably easier.
A sturdier, thicker new foam will add compression, possibly increasing the springiness, but will also dampen sound and vibration. I would consider that a good thing. It also makes re-assembly harder because you have to use more force to press the plates back together. Using clamps, it is no big deal, but it would be extremely difficult to re-assemble by hand alone with thicker firmer foam.
Offline y11971alex
  • Trade Count: (0)
« Reply #6 on: Sun, 25 September 2016, 18:46:19 »
I can attest to that.  I tried using split straws as a temporary mat to test the functionality of the keyboard, and that little bit of height made re-assembly a pain in the posterior.  I had to use books to distribute pressure evenly so the hooks would align properly, and only a heavy mallet could drive the interlocking plates in place.
  • Trade Count: (1)
« Reply #7 on: Sun, 25 September 2016, 19:38:36 »
In general, you should always test these as soon as you get them to make sure that the controller is good.
Unlike an M where enough bad rivets can render it unusable, even an F with completely deteriorated foam should still function properly.
Offline y11971alex
  • Trade Count: (0)
« Reply #8 on: Sun, 25 September 2016, 19:56:27 »
The disintegrated foam actually got trapped inside the springs, which meant many switches didn't even click when I pressed them.  After cleaning them up, though, all of them click properly.  The unit was marked as untested, so I couldn't really do much if it didn't work.  :D
Offline y11971alex
  • Trade Count: (0)
Re: [WTB] SSK bolt mods
« Reply #9 on: Fri, 16 December 2016, 19:05:54 »
New item being purchased!
Offline yangdaddy
  • Trade Count: (0)
« Reply #10 on: Fri, 16 December 2016, 23:40:52 »
I have an 1987 SSK that fohat bolt-modded I'm considering selling. It's very tight and works perfectly. Bought it from Cindy, but had 2 more SSKs come my way at the same time, so I've been thinking of selling that one off. I can take pictures if you're interested.
SSK 1395682, 1392464, 1391472, 1395217, 1392934, HHKBPro2, Model M 1388032, 1390120, 1390131, 1391401, 13H6705, 1394540, AEK M0115, LZ-CLS, Norbatouch, Gon NerD Crystal TKL, RF 87U 55G, Model F122, XT, AT, Ducky YOTG, AEK II M3501
Offline y11971alex
  • Trade Count: (0)
« Reply #11 on: Fri, 16 December 2016, 23:51:16 »
I'm hiring bolt mod services :D
Everyone so far thought I was buying a bolt modded SSK.
Offline yangdaddy
  • Trade Count: (0)
« Reply #12 on: Sat, 17 December 2016, 00:17:50 »
hahaha. oops, apologies and good luck!
