Author Topic: [IC] The Banana Split 60 - Group Buy Launching June 1st!  (Read 271683 times)
Offline SNReloaded
Re: [IC] The Banana Split 60 - Keyset Google Form and PCB Prototypes soon!
« Reply #600 on: Sat, 06 May 2017, 12:11:57 »
Quick question, I don't remember if this has been confirmed: will the group buy include the option to buy the stabs needed (for split spacebar layout)?
If no, what stabs do I need and where would be a good place to get them? This will be my first build so that's why I wonder. This layout seems perfect for me and I literally cannot wait!
I believe if you look on the first page it will list stabilizers for $10
Sent from my XT1650 using Tapatalk
Offline Arhipio
  • TheBananaMan
« Reply #601 on: Sat, 06 May 2017, 12:15:16 »
Correct, a stab pack will be offered for $10 that should cover all the layouts.
Offline 8megabit
« Reply #602 on: Sat, 06 May 2017, 12:36:05 »
Ah, my bad. Tried searching but failed.
So just to be clear, since I'm a noob, a 2u stabilizer works for a 2.25u and 2.75u key?
Offline Arhipio
  • TheBananaMan
« Reply #603 on: Sat, 06 May 2017, 13:05:12 »
Correct.
Offline Arhipio
  • TheBananaMan
« Reply #604 on: Sat, 06 May 2017, 15:05:55 »
Going live in 5 minutes, Q&A and BananaSplit Build. https://www.twitch.tv/arhipio
Offline Arhipio
  • TheBananaMan
« Reply #605 on: Sat, 06 May 2017, 18:24:57 »
Thank you to everyone that joined, it was a blast to hang out with you guys and answer some questions. Here's the VOD to the stream if you missed it.
https://www.twitch.tv/videos/140631099
Pictures of the BananaSplit built during the stream.
Offline SNReloaded
« Reply #606 on: Sat, 06 May 2017, 18:57:49 »
Looks great!
Offline ShishKabobJerry
« Reply #607 on: Sun, 07 May 2017, 00:21:37 »
Awesome sauce! I missed the stream. Will watch the vod later!
Offline Krakob
    • Krakblog
« Reply #608 on: Sun, 07 May 2017, 01:06:29 »
Glad to see this coming along! I almost gave in and bought an XD60, but I have persevered!
If you're running a keycap set I would love to see Nordic included, if you think that is feasible. You can look into Wodan's NorDe kit, which is a compressed version of German, Swedish/Finnish, Norwegian, and Danish in something like 15 keys.
Ducky Shine 2 (MX Blue, white backlight) • Obins Anne Pro (Gateron Brown) • Model M • XD60
Offline tinyprawn
« Reply #609 on: Sun, 07 May 2017, 06:36:12 »
Did you end up with extra PCB prototypes that you're not going to use? I'm getting a plate cut that's similar enough to what you're building that the PCB should be compatible. I don't mind soldering the surface mount stuff.
If not, I'll wait for the GB and get some PCBs.
Looks great!
Offline Arhipio
  • TheBananaMan
« Reply #610 on: Sun, 07 May 2017, 12:14:36 »
Looks great!
I'll be using the rest to test different layouts to make sure everything works
Sent from my Nexus 5X using Tapatalk
Offline Arhipio
  • TheBananaMan
« Reply #611 on: Sun, 07 May 2017, 19:27:09 »
Some awesome news, after the stream a lot of you showed interest in having a case sold with the board. I talked it over with Evan and we will offer the Retro60 case with BananaSplit groupbuy launch. He is getting some prototypes made in a rush and hopefully we will post some pics by next week. Here are some renders of the case in question.
Offline SNReloaded
« Reply #612 on: Sun, 07 May 2017, 19:55:00 »
I love the look of the case! I will be making a case with my dad, a custom wood one with a wrist rest. Good to see the case partnered with it though.
Offline neon_tom
« Reply #613 on: Sun, 07 May 2017, 19:59:11 »
The case looks amazing. I'm really looking forward to this board!
Offline ChitownM2
« Reply #614 on: Sun, 07 May 2017, 21:22:16 »
Great looking case, I'll be in for pcb, plate, & case if the price isn't crazy.
Offline SNReloaded
« Reply #615 on: Sun, 07 May 2017, 21:48:23 »
Remember to grab the Stabilizers as well!
Offline ChitownM2
« Reply #616 on: Sun, 07 May 2017, 21:50:13 »
Of course!
Offline Str1pez
« Reply #617 on: Sun, 07 May 2017, 23:15:31 »
Oh crazy.  Wasn't expecting a case.  That thing is nice.  Is the addition of the case gonna push back the launch of the PCB's and plates?  I already sourced a case for my Banana Split build.
« Reply #618 on: Sun, 07 May 2017, 23:19:53 »
Ohh man oh man, that's a nice looking case. Reminds me of that planck alu case that's hard to find.
Offline sklin
« Reply #619 on: Mon, 08 May 2017, 00:06:00 »
wow! That case makes me interested in the GB..This set is way better than RAMA65 for me as I really don't like that extra column on 65 layouts.
Offline Arhipio
  • TheBananaMan
« Reply #620 on: Mon, 08 May 2017, 01:03:03 »
It won't push back the pcb/plate launch :D
Offline ectoplasmatic
« Reply #621 on: Mon, 08 May 2017, 05:26:02 »
whoa looking really good!! Question - from the CAD drawings can't 100% tell if the alu case is going to be high profile or low profile. It looks pretty deep with the USB connector, but can't be sure. Looking at adding feet for an angle as well? This project is really looking to tick so many boxes...! An incredible looking PCB with so much flexibility, custom keycap set, and now a custom large bezel alu case? You're doing a lot of things right!
Offline 8megabit
« Reply #622 on: Mon, 08 May 2017, 06:56:04 »
He said on stream it was high profile.
@Arhipio: I also wonder if the case will have feet. And what price are you looking at for the case?
« Reply #623 on: Mon, 08 May 2017, 07:51:17 »
nice, thanks!
yeah just checked the reddit thread where evangs shows the retro60... he says it's intended to be used flat, but there are holes for feet if wanted. He also had some renders of the same case with an acrylic middle for underglow, wonder if they will pursue that too...
Offline ChitownM2
« Reply #624 on: Mon, 08 May 2017, 12:52:55 »
nice, thanks!
link? I'd like to check it out.
Offline megaforce
« Reply #625 on: Mon, 08 May 2017, 13:14:13 »
Whispers Brass plates
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline qn0x
« Reply #626 on: Mon, 08 May 2017, 13:24:50 »
Just stumbled upon this. Looks really promising and it's exactly what I'm looking for!
Stop it, you're making me drool!
Offline Arhipio
  • TheBananaMan
« Reply #627 on: Mon, 08 May 2017, 14:00:11 »
nice, thanks!
I could ask about the acrylic mid piece, but I believe that idea is scrapped.
Offline FoC_Tow
  • Brokehlicious
« Reply #628 on: Mon, 08 May 2017, 14:00:27 »
don't believe the hype
Offline Arhipio
  • TheBananaMan
« Reply #629 on: Mon, 08 May 2017, 14:00:54 »
Like people have answered it will have holes for feet, price is still undetermined.
Offline Arhipio
  • TheBananaMan
« Reply #630 on: Mon, 08 May 2017, 14:01:48 »
What have you done...
but on a serious note. Round 2, round 2...
Offline megaforce
« Reply #631 on: Mon, 08 May 2017, 14:02:33 »
fntaLUL
Sent from my Nexus 6P using Tapatalk
« Reply #632 on: Mon, 08 May 2017, 14:12:27 »
nice, thanks!
here you go! https://imgur.com/a/J9GEF
« Reply #633 on: Mon, 08 May 2017, 14:13:15 »
nice, thanks!
i see! either way man, thanks for all your excellent work!
Offline vim_commando
    • LaserCTRL
« Reply #634 on: Mon, 08 May 2017, 17:28:35 »
I love what you are doing with the layouts :thumb:
The 6u-7u space bar just seems like such a waste of... uh... space. But I'm not convinced I'm ready for the jump down 40%.
Offline Arhipio
  • TheBananaMan
« Reply #635 on: Mon, 08 May 2017, 17:41:45 »
Exactly, although I'm not gonna deny how nice it is to carry my planck to work. I have plans for even more layout support, including WKL  and split WKL.
Offline SNReloaded
« Reply #636 on: Mon, 08 May 2017, 18:17:30 »
What is WKL?
Offline kmba
  • Formerly tameone
« Reply #637 on: Mon, 08 May 2017, 20:30:30 »
Winkeyless
keyboards.
Offline SNReloaded
« Reply #638 on: Mon, 08 May 2017, 20:36:21 »
Winkeyless
Thank you!
Offline atomicus
« Reply #639 on: Tue, 09 May 2017, 09:16:38 »
nice, thanks!
That looks great. Will it come in that colour option, other colours also? Acrylic middle would be sweet! :)
Offline Str1pez
« Reply #640 on: Tue, 09 May 2017, 12:00:52 »
Myyyyyyy maaaan!  Nice.
Getting ultra stoked for this.  I'm like seriously considering getting 2.... sorta want to build a Miami Dolch one as well for my girlfriend.  Buuuut the K-Type is next week.  Aaarrrrggghhhh too many cool keebs coming out!
Offline Arhipio
  • TheBananaMan
« Reply #641 on: Tue, 09 May 2017, 14:04:33 »
We'll have extras if you wanna pick up a second one later ;)
Offline Arhipio
  • TheBananaMan
« Reply #642 on: Tue, 09 May 2017, 22:01:10 »
For anyone wondering, the pcb does support pcb mounted switches. Working on a build atm :D.
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #643 on: Tue, 09 May 2017, 22:56:07 »
look good :thumb:
key set is XDA Middle Earth, I presume?
Offline Arhipio
  • TheBananaMan
« Reply #644 on: Tue, 09 May 2017, 23:06:41 »
look good :thumb:
Yeah, so excited to finally use the caps.
Offline stoic-lemon
« Reply #645 on: Wed, 10 May 2017, 04:30:40 »
With a case this just went from "Will pick it up if timing is right" to "Must have!"
Offline mnmlisme
Just found this IC and I'm really liking this layout:
I don't use the right shift/win/Ctrl keys ever and always wanted to replace that section with an arrow cluster. A split spacebar would just be icing on the cake.
I love the name too! Give me a Banana Split with DSA Nanner and a Banana Snackey and I would love that board <3
sorry if I missed out but does this layout supported in the end? I love the split spacebar and the "arranged" arrow keys. I don't really like the single 1U between the spacebar in the original layout.
XD60 (gat.black) | SABER68 (gat.blue) | VORTEX Core (cherry blue) | YD40 (gatistotle)
Offline SNReloaded
« Reply #647 on: Fri, 12 May 2017, 17:54:12 »
This is what is currently supported.
Offline mnmlisme
« Reply #648 on: Fri, 12 May 2017, 22:45:53 »
aww bummer. guess the 1u stays. is that a usual layout among split spacebar? what are you guys planning to use the 1u between the spacebar for?
    • LaserCTRL
« Reply #649 on: Fri, 12 May 2017, 22:59:28 »
My plan is to make it my Fn layer key. I like the right thumb Fn key on my Tex, and it has a 5u space bar. I find it much nicer than using a pinky for the Fn layer like I have on the Infinity (6u space).
