Author Topic: What is the difference between 3pin / 5pin Cherry MX?  (Read 25375 times)
Offline mamcx
« on: Mon, 26 September 2016, 15:23:17 »
I will buy some keys for first time and find in ebay that some CHerry are 3pin and other 5pin.
Why?
Offline xondat
  • i'm not a star
Re: What is the difference between 3pin / 5pin Cherry MX?
« Reply #1 on: Mon, 26 September 2016, 15:25:54 »
Do you have pictures?
I imagine 3 pin would be plate mount, and 5 pin would be PCB mount.
« Reply #2 on: Mon, 26 September 2016, 15:27:05 »
^^ that is correct, PCB mount has two extra 'pins' or legs to give more stability when not using a plate.
Offline mamcx
« Reply #3 on: Mon, 26 September 2016, 20:06:31 »
So, is problematic buy 5pin if later wanna use a plate?
« Reply #4 on: Mon, 26 September 2016, 20:55:01 »
You can always clip the extra stabilizing legs off of PCB mount switches to make them plate mount or depending on if the PCB you use allows for PCB mount switches (it just needs the extra holes in the PCB),  you can use a plate at the same time.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #5 on: Tue, 27 September 2016, 02:43:19 »
3 pin switches requires a plate. 5 pins ones can be used both pcb mounted or plate mounted (the pins can be snipped off if PCB doesn't support it). You can of course do both (plate mounted switch but still use the 2 extra PCB pins
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
