Author Topic: Lube Mixture Recommendations: RS II MX Clear  (Read 1801 times)
Offline Deep
« on: Sun, 02 October 2016, 19:53:14 »
So I'm looking for some good lube mixtures and where to find them for my upcoming build. I want to lube my 65g MX clears. I don't really want anything too expensive but I don't want a crap quality mixture at the same time. I have a syringe of Cubicle Silicone Lube (weight 4) for my speed cube, don't know if it will work or not.
Offline Rayoui
Re: Lube Mixture Recommendations: RS II MX Clear
« Reply #1 on: Tue, 04 October 2016, 07:05:00 »
I used Krytox GPL 205 when I made my 62g ergo clears for the B.face. I didn't mix it. Worked great  :thumb:
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline Ashlyn
« Reply #2 on: Tue, 04 October 2016, 19:51:22 »
I m using Krytox 103 for switch lube and 205 for stabilizer
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #3 on: Wed, 05 October 2016, 01:18:59 »
I used straight GPL205 and liked it but I think its a bit thick and slow. I missed the snappy feeling on my blacks. So I took a small bit of 205 and mixed it 1:1 with GPL100 which is an oil rather than a grease and the result is really nice.
To each his own.
-Dana
