Author Topic: Tilde problem: What to put in Tilde location left in a HHKB-friendly 75% layout?  (Read 7889 times)
Offline menuhin
Playing around with 75% layout with a HHKB key placement.
However, 'Esc' is up there and there is an empty space left by the moved 'Tilde'.
What can be put there? What do you think?
150287-0
« Last Edit: Tue, 11 October 2016, 04:55:56 by menuhin »
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Tactile
Home/End
REΛLFORCE
Offline Laurel
Yep, Home/End.
Very useful keys.
Offline menuhin
I planned to integrate from with the "Page Up" and "Page Down" keys.
Now it's more clear.
150301-0
Although I use bash shell quite often, I use the 'tilde' e.g. for home and 'backtick' e.g. for output substitute not as often...
I do hit the Home/End more often then those two keys.
A few keys are not included here:
Menu, Meta
Keys that can usually be compromised in some other layouts:
Super/Win, Insert, PrtSc, NumLk, ScrLk, Pause, Break
I just notice that even the Type 5 and Type 6 keyboards of Sun MicroSystem have an empty key in front of F1 when they have their Esc key in front of '~' (Tilde).
Unlike their Compact 1 keyboard.
[https://docs.oracle.com/cd/E19683-01/806-4743/estar-chapter-78/index.html]
IBM M13 black
HHKB Pro 2 HasuBT
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
I like tilde for shortening certain directories when I'm in bash but I can see why some wouldn't want it as a primary key
Offline hasu
  • @tmk
Esc definitely, otherwise make no sense :D
I can use Ctrl+a/e for Home/End easily but not Ctrl+[ for Esc
Offline menuhin
You mean yet another Esc key? i.e. 2 Esc keys on this 75% keyboard?
Otherwise, then it will have a blank key on the left side of F1, like the Sun Type 5 and Type 6 keyboard.
In this case, what key will you put at that empty key location then?
IBM M13 black
HHKB Pro 2 HasuBT
Offline nathanrosspowell
    • nathanrosspowell.com
If it's HHKB friendly, it should be an escape.
Then your question would be, what to use the key next to F1 for.
On my CP-SQ I just just have another tilde key because it's not  a very useful position.
Offline Fictiouz
  • That "White" Guy
With HHKB Number Row on boards with a Function Row I always make regular layout Tilde Esc and make Esc my handy dandy calculator button. Nine times out of ten I will have an artisan on that button anyways.
