Author Topic: IBM Model M 1394312 terminal keyboard  (Read 6711 times)
Offline Bojan
« on: Sat, 15 October 2016, 15:39:55 »
I recently bought this nice terminal IBM Model M keyboard for $30. Photos are not very good and sharp, but I don't have a better camera (these were taken with camera on a cheap smartphone).
One keycap is missing, one key is dead. Many rivets are broken. Disassembled, vacuumed, cleaned with brush, Ajax, water and 96% alcohol.
Cool German keycap legends.
Sadly, cable is not detachable.
I was a bit confused when I saw RJ45 connector. I always tought that terminal keyboards used 5-pin DIN connectors.
Thanks to Soarer's converter by Orihalcon, keyboard now works with PCs.
This beauty (and the beast!) celebrated 25th birthday only few days ago!
« Last Edit: Sat, 15 October 2016, 15:43:29 by Bojan »
Re: IBM Model M 1394312 terminal keyboard
« Reply #1 on: Sat, 15 October 2016, 17:07:26 »
It is not likely that one key is "dead"
The key stem is probably not seated properly over the spring. Try pulling it out and re-seating it. You may try standing the keyboard up on the bottom (space bar) side, and letting the spring flop down before you replace the key stem.
- D Trump 2026-10-24
Offline invariance
  • ...here with all the other boson's
« Reply #2 on: Sun, 16 October 2016, 06:14:08 »
Happy typing on that beast!
When you can, do yourself a favour and give her a new lease on life: screw mod her.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
« Reply #3 on: Mon, 05 June 2017, 05:23:36 »
OP has been MIA since last year - wonder if he got it working.
And is that a discoloured space bar?  The first one I've seen on a Model M!
« Reply #4 on: Mon, 05 June 2017, 16:49:31 »
Greenock plant went to ABS space bars in the mid-late-1990s. They also have a weird grounding wire to the chassis.
« Reply #5 on: Thu, 22 June 2017, 22:20:13 »
Ugh, same as HHKB.  I don't mind a little yellowing of keycaps, but not uneven like that.
