Author Topic: O-ring removal tool  (Read 4201 times)
Offline Lpwl
  • * Moderator
  • lpwl.bigcartel.com
    • My O-ring Store
O-ring removal tool
« on: Mon, 17 October 2016, 10:24:11 »
O-rings can be a pain to remove and using metal tools can cause damage to the material, paint or coatings of your keycaps  :(
I reckon that pretty much anything with a small hooked end should work ... but here is my contribution for the less savvy ones amongst us !
>> LINK TO THE SHOP <<
« Last Edit: Thu, 20 October 2016, 05:18:58 by Lpwl »
Offline ddot
  • Master of Suspense
Re: O-ring puller [coming soon]
« Reply #1 on: Mon, 17 October 2016, 14:22:23 »
Interesting.  What are the picks made of?  Any chance of scratching the plastic on the stems?
Offline Lpwl
  • * Moderator
    • My O-ring Store
« Reply #2 on: Mon, 17 October 2016, 14:31:22 »
Those are made out of nylon (plastic).
« Last Edit: Thu, 20 October 2016, 05:20:32 by Lpwl »
Offline MandrewDavis
  • Son of Demeter
« Reply #3 on: Mon, 17 October 2016, 14:54:35 »
If you are installing o-rings, I can confirm this tool on ThingVerse works great! All thanks to the user that 3D-printed a few for me.
