Author Topic: Keyboard macros - do you use/set them? If you do, what are they?  (Read 3346 times)
Offline menuhin
« on: Thu, 20 October 2016, 11:30:00 »
Modern mechanical board's PCB are mostly customizable: for the default layout or that you can define something called 'macro' - which is basically a series of key presses pre-defined.
Keystroke procedural macros can be achieved within a software, e.g. MS Word, Notepad++, Emacs, Vi, or software at more of a system level, e.g. AutoHotKey.
Do you use your keyboard's macro function? If yes, what macro(s) have you defined and how often do you use them?
« Last Edit: Thu, 20 October 2016, 11:32:07 by menuhin »
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Data
Re: Keyboard macros - do you use/set them? If you do, what are they?
« Reply #1 on: Thu, 20 October 2016, 12:38:04 »
I have 10 macro buttons (requires firmware load) and a macro record/play function that holds ~80 characters.  I don't use them very often.
This board also has pre-programmed macros for Cut, Copy, Paste, Undo, Select All, New File, Open, Save, Find, Run, Lock, Calculator, Media Player, Volume Up, Volume Down, Mute, Prev, Play/Pause, Next; plus mouse keys on the function layer.  I use those quite a bit.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Thu, 20 October 2016, 19:14:54 »
Funny that you mention that, there will be something related this weekend ^^ .
Offline ctm
  • Hello, world!
« Reply #3 on: Fri, 21 October 2016, 10:08:26 »
I have two macros for two of my email addresses and one for my phone number.
Coming:
Ellipse Model F F62.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #4 on: Fri, 21 October 2016, 10:10:06 »
Isn't that something like the Amstrad PCW?
