Author Topic: [GB] Massdrop x Zambumon GMK Nautilus Custom Keycap Set  (Read 282333 times)
Offline Auk
Re: [IC] GMK Nautilus
« Reply #500 on: Tue, 20 June 2017, 16:39:37 »
Tai-Hao made a copy...
That was on reddit, some of the comments there said it was a copy of Danger Zone rather than Nautilus. Either way it looks pish...
Offline rioc
« Reply #501 on: Tue, 20 June 2017, 16:39:58 »
Apparently Tai-Hao made a copy of this set! Right before it goes on GB!
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2501
That's not really a copy of this set, that's a copy of danger zone
http://imgur.com/uChIaQH
true... it's the deep blue that reminded me of this set
Offline merlin64
    • MechMerlin
« Reply #502 on: Tue, 20 June 2017, 16:40:54 »
My apologies! You are correct, I completely forgot about that set!
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #503 on: Tue, 20 June 2017, 16:48:29 »
What about this  :))
« Last Edit: Tue, 20 June 2017, 18:12:13 by Zambumon »
Offline rioc
« Reply #504 on: Wed, 21 June 2017, 01:56:11 »
What about this  :))
ah, that's the one I meant which was seen at computex... not the other one
this is defo nautilus rip
Offline Auk
« Reply #505 on: Wed, 21 June 2017, 05:16:13 »
What about this...
Is that also Tai Hao? quality looks quite dubious, but maybe it's just because it's shine through legends? whatever the reason I can't see it taking sales from Nautilus.
Offline merlin64
    • MechMerlin
« Reply #506 on: Wed, 21 June 2017, 09:16:10 »
If it were me 2-3 years ago, I'd probably say. "Plastic is plastic...go for this because its cheaper and you get it faster".
Within the enthusiast community I don't think anyone would choose this over GMK. However it's a good way to get new people into the hobby!
Offline ppp
  • KappaKeepoKoopa
« Reply #507 on: Wed, 21 June 2017, 09:26:18 »
This. Cheap keysets get you suckered in then you realize there are quality ones and that's what we stay for.
Offline kmba
  • Formerly tameone
« Reply #508 on: Thu, 22 June 2017, 23:04:21 »
If you're having cap problems I feel bad for you son
I got 99 problems but cheap plastic ain't one
keyboards.
Offline jacobavenkraft
« Reply #509 on: Fri, 23 June 2017, 17:41:29 »
I've never actually used an Ergodox.  Are the keycaps different for the left and right sides?  Or do they only differ based on row profile (i.e. R1, R2, R3, R4)?  The render shows a vertical R2 keycap for open braces/open bracket ("{", "[") on both the right-hand and left-hand sides, but unless the right-hand and left-hand sides have different stem patterns it seems like that would be a duplicate keycap which could potentially have a different label on it.
Offline colbs
« Reply #510 on: Tue, 27 June 2017, 12:26:41 »
Same keycap, but legend is flipped 180 degrees.  The vertical keys on the ergodox are R2 profile, 1.5u (exactly the same as the tab key).  On the ergodox, the 'front' face of the vertical keys points towards the gaps between the two halves.  So even though they are the same key profile and width, their different orientation on each half of the ergodox requires that both keys be made.  If you open up the ergodox render and look at those keys more closely, you can see that the less steep face of the keycaps point in different directions depending on which hand of the ergodox they are on.
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #511 on: Tue, 27 June 2017, 15:39:52 »
What about this  :))
This looks terrible :D
Offline rippor
« Reply #512 on: Wed, 28 June 2017, 10:49:46 »
Probably a dumb question, but will this come in those cool trays like the other GMK sets?
Offline Zambumon
    • Keyset projects
« Reply #513 on: Wed, 28 June 2017, 11:08:32 »
Of course. And they'll be packed in a custom banderole.  :thumb:
Offline ppp
  • KappaKeepoKoopa
« Reply #514 on: Wed, 28 June 2017, 11:11:41 »
Can carbon end already so we can get on board??? I've been waiting foreverrrr x__x
Offline typischt
« Reply #515 on: Wed, 28 June 2017, 11:22:34 »
Seriously, Carbon is going on for aaages! O.o
But tbh, in regards to budget, I'm kinda glad it's like that. :)
Envoyé de mon iPhone en utilisant Tapatalk
Offline kmba
  • Formerly tameone
« Reply #516 on: Wed, 28 June 2017, 11:35:58 »
Yup carbon can Giiiit Ouuuut
keyboards.
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #517 on: Wed, 28 June 2017, 11:39:06 »
Offline ppp
  • KappaKeepoKoopa
« Reply #518 on: Wed, 28 June 2017, 11:51:53 »
<3 just teasing. I'm just mad cuz I can't afford all the mods  :p
Offline rippor
« Reply #519 on: Wed, 28 June 2017, 12:49:32 »
a custom what?
Ive never purchased GMK keys so pardon the ignorance
Offline ppp
  • KappaKeepoKoopa
« Reply #520 on: Wed, 28 June 2017, 13:06:53 »
a custom what?
It's just one of those slip-on box type things.
The box with no sides.
here's a picture of the hydro banderole + tray http://i.imgur.com/MrqxOxr.jpg
Offline Zambumon
    • Keyset projects
« Reply #521 on: Wed, 28 June 2017, 15:59:19 »
Offline Konjungamo
[IC] GMK Nautilus
« Reply #522 on: Wed, 28 June 2017, 16:00:16 »
Novelty hype \o/
« Last Edit: Wed, 28 June 2017, 16:03:50 by Konjungamo »
Offline Zambumon
    • Keyset projects
Offline merintil
« Reply #524 on: Wed, 28 June 2017, 16:18:28 »
Looking great! I can't wait for the set to drop!
Offline Konjungamo
« Reply #525 on: Wed, 28 June 2017, 16:19:00 »
The price for the NORDE-Kit is fantastic!
If I'm being honest I have no idea what the enter novelty is supposed to be though :D
Offline Zambumon
    • Keyset projects
« Reply #526 on: Wed, 28 June 2017, 16:25:15 »
I'm really happy too with how the NORDE kit has been priced.
The enter key is the Nautilus II from the League of extraordinary gentlemen, I thought it was a cool addition and tried my best to match the original one.
Offline euphxenos
« Reply #527 on: Wed, 28 June 2017, 16:25:52 »
Thanks for adding the R3 PgUp and R4 PgDn, and I really like the Nautilus II novelties.  I'm in as soon as this drops.
Offline Konjungamo
« Reply #528 on: Wed, 28 June 2017, 16:33:03 »
Oh that's cool, definitely an eyecatcher and something to talk about even for people not interested in keybaords!
Offline eksuen
  • Ambassador of explosions.
« Reply #529 on: Wed, 28 June 2017, 16:50:33 »
Big fan of the novelties. The diver helmet just makes me think of Bioshock.
Offline ppp
  • KappaKeepoKoopa
« Reply #530 on: Wed, 28 June 2017, 16:56:11 »
Oh **** I'm so excited. Gogo Zambumon :)
Offline ctrl
« Reply #531 on: Wed, 28 June 2017, 17:25:20 »
That's it. I'm in for Nautilus as soon as it drops. Just noticed the Massdrop page update and the stunning novelty keys.
I was going to go for Carbon (because it is a damn fine set! Love those hexagons!), but I was planning on using this purchase for a split spacebar build (which likely will become my first build ever) and I'd like the bottom row to be uniform. For this purpose Nautilus would be better, I think.
Offline Konjungamo
« Reply #532 on: Wed, 28 June 2017, 19:30:54 »
Sooo, definitely no barred F and J keys?
Would be sad to see this set without them as I definitely prefer bars to scoops for orientation.
Maybe at 1000 orders, pretty please?
Offline e_l_tang
« Reply #533 on: Wed, 28 June 2017, 19:41:18 »
What is the reasoning for keeping certain keycaps in the ErgoDox/Planck kit concave? I don't see any reason why they should stay concave when they can be made convex as they should be without any extra cost.
Offline Zambumon
    • Keyset projects
« Reply #534 on: Wed, 28 June 2017, 20:14:11 »
Convex keycaps don't have legends and are intended to be used as spacebars by Planck users, the rest of the keycaps have to be concave, as it allows them to get legends.
Offline e_l_tang
« Reply #535 on: Wed, 28 June 2017, 22:00:33 »
Why can't convex keycaps have legends?
Offline pab
  • Dvorakian Nightmare
« Reply #536 on: Wed, 28 June 2017, 22:07:35 »
My naive guess is that they would requite separate molds, and therefore more expensive.
Offline bun
« Reply #537 on: Thu, 29 June 2017, 07:19:24 »
VIM KEYS..!!!!
DO WANT. SHALL HAVE.
 ;D
Offline Belgaer
« Reply #538 on: Thu, 29 June 2017, 08:08:10 »
Absolutely brilliant and beautiful novelties. Gutted that there's nothing in it for ISO but not saying that was the wrong decision. That red on blue Nautilus II <3. I'd never have thought that another colour would work (especially red) but it really looks fantastic!
Leopold FC980M ISO MX Brown
Offline Arallu
« Reply #539 on: Thu, 29 June 2017, 08:31:40 »
No barred F/J keys is really a letdown.
Offline ppp
  • KappaKeepoKoopa
« Reply #540 on: Thu, 29 June 2017, 08:36:28 »
Oh I didn't even notice... +1.
Still going to buy but I'd rather have bars than learn something new  :p
never really used scoops before.
Offline Konjungamo
« Reply #541 on: Thu, 29 June 2017, 08:53:57 »
Same situation here. Apparently, there can also be light bleeding issues when GMKs scooped caps are paired with switch LEDs (althought that might affect light-alpha sets like Plum or Carbon more than a dark set like Nautilus).
Offline Zambumon
    • Keyset projects
« Reply #542 on: Thu, 29 June 2017, 10:36:15 »
The light leaks were produced in Triumph Adler due to a change in the composition of the plastic used (Source) and I haven't spotted a single keyset that has had them after it.
Offline ideus
  • Björkö.
« Reply #543 on: Thu, 29 June 2017, 10:38:28 »
Dolch looks way too good, even against the new colorful sets like HF. Impressive.
Offline Konjungamo
« Reply #544 on: Thu, 29 June 2017, 10:59:41 »
Not trying to start a fight or anything, but it seems to be a more recent problem as well, at least with Plum:
https://www.massdrop.com/buy/massdrop-x-jessica-gmk-plum-custom-keycap-set/talk/1733595?utm_source=linkshare&referer=65KF82
https://www.reddit.com/r/mechmarket/comments/6jwqom/usca_h_paypal_w_gmk_plum_scooped_f/
https://www.reddit.com/r/MechanicalKeyboards/comments/6k4iby/gmk_bleedthrough_of_backlighting/ <-- Admittedly, this is where I first heard of this problem and it seems to be isolated incidents.
So probably nothing to worry about with the darker color of Nautilus, just trying to find some more reasons for including our beloved barred F/J caps.
Offline Auk
« Reply #545 on: Thu, 29 June 2017, 11:25:52 »
so what we're saying here is, Zambumon is some kind of...
Scoop Nazi ?!
NEXT !!!
« Last Edit: Thu, 29 June 2017, 11:27:55 by Auk »
Offline dubious
  • 쏘쿨
« Reply #546 on: Thu, 29 June 2017, 11:27:03 »
stubs are clearly superior
scoops are just warped keys  :rolleyes:
Offline e_l_tang
« Reply #547 on: Thu, 29 June 2017, 11:27:36 »
This doesn't apply to most of the legends in the kit, since they have to be made new anyway. No one's ever going to need concave Lower and Raise keycaps for example and only a legend mold for convex keycaps would be needed.
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #548 on: Fri, 30 June 2017, 13:15:45 »
FWIW, I also prefer bars. >terminal_ came with them and they are awesome.
I didn't even check earlier because I had assumed all GMK sets came with them.
I just find them easier to home on than scoops.
Either way, I'm still in for the set, because ...
Zambumon, I missed the post where you had reconsidered DC support so when I saw them in the drop preview I was stoked!
Thanks man, you rock!!!!
Offline KnightDX
« Reply #549 on: Fri, 30 June 2017, 13:17:35 »
Does this drop today ? June 30th?
