Author Topic: Realforce 87U 45g or Leopold FC980C  (Read 5243 times)
Offline moh18one
« on: Sat, 22 October 2016, 10:14:29 »
Hi,
I don't know what to choose between the two
Actually I don't think if the numpad is a problem but I would like a small keyboard with the F1-F12 keys. Also, I dislike the stock keycaps of the Realforce.
 After, I don't know if the 1800 layout is more difficult to type on due to the positionning of some key (never type on a 1800 layout).
I have heard the Leopold FC660C is better for typing than the Realforce (smooth etc ...) and I think if many people think this the Leopold FC980C will have the same experience.... Really difficult to choose between the two :(
Offline Tactile
Re: Realforce 87U 45g or Leopold FC980C
« Reply #1 on: Sat, 22 October 2016, 10:43:50 »
Well, if you don't like the stock caps on the Realforce that's pretty much a deal breaker since replacement sets are very hard to find.
REΛLFORCE
Offline 1391406
« Reply #2 on: Sat, 22 October 2016, 12:52:14 »
The problem may be finding a uniform 45g Realforce 87U.
Offline nrp
« Reply #3 on: Mon, 24 October 2016, 20:01:42 »
Do you need media keys? That is another difference.
Offline Polymer
« Reply #4 on: Mon, 24 October 2016, 21:23:21 »
You don't like the RF keycaps...That really leaves you with nothing left....Stock Leopold ones...Type Heaven...
The RF/HHKB stock keycaps are probably one of, if not the best stock set out there...and in general, a very good set of keycaps...
Maybe you need to look at getting alternate sliders...
« Reply #5 on: Mon, 24 October 2016, 21:47:05 »
Leopold is the manufacturer for all Topre keycaps. Realforce is a subsidiary of Leopold. IIRC Realforce keyboards even have Leopold on the label (or used to. I think mine does, I don't have it in front of me.)
However, I think they've improved the molds for their keycaps in recent years, which may or may not have something to do with the lack of custom keycaps on the market for topre.
Just my $0.02. I love my 45g realforce, but it's modded from a 55g. If you can find one, I definitely think it's worth going for. 55g seems to be a big favorite, though.
Offline Tactile
« Reply #6 on: Mon, 24 October 2016, 22:14:01 »
Realforce keyboards are manufactured by Topre Corp. Leopold is just a distributor, just as Elite Keyboards is the distributor for North America.
REΛLFORCE
« Reply #7 on: Mon, 24 October 2016, 22:15:42 »
True, but I remember something about them being the factory owners for the keycaps or something.
Things might've changed since I've been gone, though.
Offline vivalarevolución
« Reply #8 on: Fri, 28 October 2016, 16:33:05 »
Both.  Always both.
