Author Topic: Topre Realforce Key Weighting  (Read 4099 times)
Offline didjamatic
« on: Wed, 20 January 2010, 08:54:16 »
I want a 103 that has the same variable response as an 87u... or all 45g, maybe even 55g.
My 103u had distinctly lighter pinky keys. I got used to it but if I switch keyboards often then I will aaaaaaaaaaa and ;;;;;;;;;;; with it.  I don't do that with my variable 87u despite it supposedly being the same key switch weighting.
Has anyone else experienced this?  I loaned the 103u to a relative that liked it so much they kept it and paid me for it so I no longer have it to test it's resistance.
« Last Edit: Wed, 20 January 2010, 09:00:25 by didjamatic »
Offline rdjack21
« Reply #1 on: Wed, 20 January 2010, 09:22:56 »
If I remember correctly the 103U has 30/45/55 weighted keys where the 87U has 35/45/55 so on the 87U the pinky keys are slightly heaver. I occasionally have the same issue on my 86U which is also 30/45/55 but I've just learned to not rest my pinky fingers on the keys. The NEO I have is also 30/45/55 as well.
The 30g keys on the pinky fingers don't really bother me but when I use my uniform 30g board I find them to light. I really think Realforce got it right with the 87U by increasing the pinky keys to 35g on it.
If the 30g keys really bug you do ripsters key weight mod on the keys that bother you in particular the a and ; keys.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline didjamatic
« Reply #2 on: Wed, 20 January 2010, 11:37:37 »
That's good to know.  Elite needs to update their description on their 103 keyboards
They list the 103 as 35/45/55 just like the 87u.
Offline rdjack21
« Reply #3 on: Wed, 20 January 2010, 12:34:07 »
I just remembered seeing it some where as being 30/45/55 and you are right EliteKeyboards has it listed as 35/45/55 but just to be sure I went and looked around on some Japanese sites and all of them list it as 30/45/55 including diatec (half way down the page). I guess to really be sure look at the box it came in. Maybe we can get patrickgeekhack to take a picture of his box because he has one.
EDIT: Forgot to add it is extremely hard to tell the difference between the 30g pinky keys and the 35g pinky keys using your pinky. I can tell using one of my other fingers but not my pinky. But that 5g difference does make it a little easer to do the aaaaaa ;;;;;; thing on them. My self I just don't rest my pinky fingers on the keys any more so no problem.
« Last Edit: Wed, 20 January 2010, 12:36:33 by rdjack21 »
Keyboards
Black Alps: ABS M1
Offline rdjack21
« Reply #4 on: Wed, 20 January 2010, 12:40:08 »
Quote from: rdjack21;152280
This is incorrect I just ripOmetered the NEO and the pinky keys are 35g not 30g which is strange because the standard 89 is 30g so I guess this board has a few more mods than just the keys. I don't have the box so who knows what the actual spec is supposed to be.
Keyboards
Black Alps: ABS M1
Offline didjamatic
« Reply #5 on: Wed, 20 January 2010, 14:31:23 »
I can definitely feel a difference side by side with my 87u.  No doubt in my mind.  I have only done ;;;;;;;;; a couple of times on my 87u but do it constantly on the 103u until I have gotten used to it.  At first I thought it was the newer 87u needing to break in but after having about equal time on them the difference was still definitely there.
Offline didjamatic
« Reply #6 on: Wed, 20 January 2010, 16:34:46 »
Quote from: ripster;152416
6 nickels would decide this once and for all.
Next visit to the relatives I will try to remember to bring spare change.
Offline ocdonkb
« Reply #7 on: Thu, 21 January 2010, 18:36:23 »
The box of my Realforce 87U Black says the weighting is 30/45/55
| Filco Brown 87 key | Realforce 87U | Unicomp Spacesaver | IBM Model M | Cherry ML4100 | Dell AT101W | Focus 2001 |
Offline rdjack21
« Reply #8 on: Thu, 21 January 2010, 21:01:51 »
Yea the box for the 87U is incorrect. The box to me looks exactly like the box for my 86U except for the name change.
Keyboards
Black Alps: ABS M1
