Author Topic: Screws for 60%  (Read 4007 times)
Offline pixelpusher
Screws for 60%
« on: Sun, 30 October 2016, 12:02:50 »
So, I got everything ordered:
Sentraq underglow 60% PCB
Frosted clear acrylic TEX case
Aluminum universal plate
PCB mount cherry stabilizers
Clear top Gateron black switches
Sip sockets
I have tons of leds on hand
And then I  realized, there are probably not any screws coming.   >:D
Does anyone happen to know the details on the screws I need?
Offline heedpantsnow
  • Old enough to know better
Re: Screws for 60%
« Reply #1 on: Sun, 30 October 2016, 13:15:13 »
M2 for most 60 cases. I prefer hex head black oxide but you can get whatever finish you want.
I'm back.
Offline Tactile
Re: Screws for 60%
« Reply #2 on: Sun, 30 October 2016, 13:39:22 »
As heedpantsnow said. I used M2x6 for my iQunix Lambo case as the included screws were too short and had very little thread engagement after they went through the PCB.
REΛLFORCE
Offline pixelpusher
Re: Screws for 60%
« Reply #3 on: Sun, 30 October 2016, 14:12:19 »
Thanks.  I'll pick some up today
Offline pixelpusher
Re: Screws for 60%
« Reply #4 on: Fri, 04 November 2016, 13:36:46 »
Well, I got my case yesterday and wouldn't you know it... it came with screws.  So, in case you are wondering, the TEX cases do come with screws even though they don't say so in the product description.
