Author Topic: Keyset that Supports JIS/Minila Keyboards  (Read 3544 times)
Offline Dyaems
« on: Tue, 01 November 2016, 23:34:29 »
Besides EnjoyPBT Valentine, are there any other keysets that supports the above keyboards? Or any other keysets that has the following keys included: 2u R1 Shift, 1u  R1 Shift, 1u R1 novelties maybe?, R3 Backslash (beside ISO enter), 1u R4 Backspace and Backslash/Delete.
Not sure if I stated the correct rows, but I'd assume it would be R1 R1 R2 R3 R4 R4 from bottom to top.
Blank keys are probably the last resort but I prefer printed keys for now.
Thanks for any suggestions!
   B.face X2
  65g Zealios
Re: Keyset that Supports JIS/Minila Keyboards
« Reply #1 on: Wed, 02 November 2016, 01:12:50 »
There's 1 set in IC phase.
Aside from that, you're boned. 3u spacebar ruins everything. SP is the only company that makes them 3rd party.
Offline Dyaems
« Reply #3 on: Sat, 05 November 2016, 03:00:14 »
thanks guys  :thumb:
   B.face X2
  65g Zealios
