Author Topic: Coolermaster Masterkeys Pro feedback  (Read 2736 times)
Offline pixelpusher
« on: Wed, 02 November 2016, 08:13:35 »
This is a long shot, I'm sure, but does anyone know if you can open the tops of the switches on the masterkeys keyboards from CM?  I really want a green switch in one of them but all they offer is red, blue, and brown.
Re: Coolermaster Masterkeys Pro feedback
« Reply #1 on: Wed, 02 November 2016, 13:04:01 »
of course you can, but it'll take you some srs surgery (desoldering)
Offline pixelpusher
« Reply #2 on: Wed, 02 November 2016, 14:52:09 »
Boo.  I figured
« Reply #3 on: Wed, 02 November 2016, 16:46:17 »
Boo.  I figured
Plate mounted board, bro.
Takes some time but it's worth it. Soldering is a good skill to have.
Offline kawasaki161
« Reply #4 on: Wed, 02 November 2016, 17:10:46 »
If the switch-holes are made the same way as in the Quickfire TK they are insanely easy to desolder. They should be too big for holtites though.
