Author Topic: NovaTouch sliders on a Topre 23U?  (Read 4107 times)
Offline zslane
« on: Wed, 02 November 2016, 13:10:53 »
I have two questions regarding the viability of replacing the stock sliders in a Topre 23U external numpad with NovaTouch sliders:
1. Would the Topre stabilizers (on the 2u keys) be a problem? IOW, do they make it infeasible to install MX-stemmed keycaps?
2. Does anyone know where 23 NovaTouch sliders can be acquired now that CM has discontinued the product? (Note, I'm not too keen on using the Chinese knock-offs found in Aliexpress).
Offline sony
  • Formerly ultraidiot
Re: NovaTouch sliders on a Topre 23U?
« Reply #1 on: Wed, 02 November 2016, 13:28:13 »
Novatouch has mx compatible stabilized keys so if you swap the whole housing and slider, those should not be a problem.
As for sourcing them, if you want to be able to use mx keys for the 2u keys, you'd have to get a novatouch or part of a novatouch. Ctrlalt is also making mx compatible Topre sliders, but I am not certain on their availability.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #2 on: Wed, 02 November 2016, 14:04:12 »
I have never owned a 23u, is it plate mounted or is is plastic like the hhkb?
If it is plate mounted like the realforce it should be easy.
If it is plastic mounted like the hhkb, some modding will be needed.
You can still buy barebone novatouchs from their site until they are sold out.
« Reply #3 on: Wed, 02 November 2016, 14:06:53 »
The 23U is plate mounted.
http://imgur.com/a/QZ3KE
Offline zslane
« Reply #4 on: Wed, 02 November 2016, 14:09:51 »
I already have a NovaTouch. It lacks a numpad, which is why I am investigating a Topre 23U in the first place. But I'd like the 23U to have the same sliders as the NT it would be sitting next to. I wasn't aware that I'd have to get another NT just to harvest its stabilizers. That alone probably kills the whole idea for me.
Offline Bromono
  • Wanabe Cicerone
« Reply #5 on: Wed, 02 November 2016, 14:44:07 »
Only other way to source sliders is marketplace or Chinese ones.
Sorry =(
Offline zslane
« Reply #6 on: Wed, 02 November 2016, 14:47:52 »
Well, as I'm discovering, it isn't just about the sliders.
It was possible at one time to get bare NovaTouch sliders, but AFAIK those did not come with NovaTouch stabilizer housings. So even if I could find someone with spare NT sliders and willing to sell some, I'd still need to find a source for the stabilizer housings. Are there Chinese sources for those too?
Offline Bromono
  • Wanabe Cicerone
« Reply #7 on: Wed, 02 November 2016, 14:51:00 »
When I bought a novatouch to harvest the sliders for my hhkb, I sold all my leftovers which included the housings.
Offline zslane
« Reply #8 on: Wed, 02 November 2016, 14:56:04 »
Okay so basically I am either looking at harvesting a second NT myself, or looking for someone who has leftover sliders and stabilizer housings from a harvesting session of their own.
Thanks for the info everyone!
« Reply #9 on: Wed, 02 November 2016, 16:41:13 »
Sliders and stabs can be had on aliexpress and taobao, iirc.
Offline keykaiser
« Reply #10 on: Wed, 02 November 2016, 16:52:06 »
JTK sounds like they will have sliders.
Offline zslane
« Reply #11 on: Wed, 02 November 2016, 17:00:30 »
Aliexpress and Taobao...you're talking about Chinese knock-offs of the components in a NovaTouch, yes?
Offline zslane
« Reply #12 on: Wed, 02 November 2016, 17:01:49 »
Apologies for my ignorance, but what is JTK?
« Reply #13 on: Wed, 02 November 2016, 18:28:22 »
I've only seen sliders. You have a link for stabs?
JTK is a new manufacturer working with ctrlalt on making cherry profile keycaps as well as topre mx compatible sliders including stabilizers and replacement cherry profile topre space bars.
They have not shipped yet but should be soon.
« Last Edit: Wed, 02 November 2016, 18:30:31 by SpAmRaY »
« Reply #14 on: Wed, 02 November 2016, 19:13:58 »
Quick dig pulls up nothing, but I don't actually think I've seen them before.
