Author Topic: Cherry profile keycap shapes  (Read 7727 times)
Offline e_l_tang
« on: Wed, 02 November 2016, 19:37:02 »
Where can I find a list of all the keycap shapes which exist in the Cherry profile?
« Last Edit: Wed, 02 November 2016, 19:43:45 by e_l_tang »
Offline xondat
  • i'm not a star
Re: GMK keycap shapes
« Reply #1 on: Wed, 02 November 2016, 19:38:34 »
Do you mean the profiles? They only produce Cherry.
Offline e_l_tang
« Reply #2 on: Wed, 02 November 2016, 19:40:39 »
No, I want a list of all the keycap shapes which exist in the Cherry profile.
« Last Edit: Wed, 02 November 2016, 23:26:16 by e_l_tang »
Re: Cherry profile keycap shapes
« Reply #3 on: Wed, 02 November 2016, 21:37:27 »
Do you mean legends?
« Reply #4 on: Wed, 02 November 2016, 21:52:28 »
Every shape that exist now or has ever existed? And in which materials?
If you are interested in getting double-shot moulded keys done, then I suggest that you email a question to GMK. They are the ones that make double-shot keys now.
Offline Tactile
« Reply #5 on: Wed, 02 November 2016, 23:19:55 »
I don't understand the difference between a keycap profile and a keycap shape.
REΛLFORCE
Offline e_l_tang
« Reply #6 on: Wed, 02 November 2016, 23:31:10 »
No, read my OP again.
I want to know what shapes would be available to the organizer of a future GB. I already know they only produce ABS keycaps.
An example of a keycap profile would be Cherry. An example of a keycap shape would be R3 1x1.
« Last Edit: Wed, 02 November 2016, 23:32:46 by e_l_tang »
« Reply #7 on: Wed, 02 November 2016, 23:44:31 »
[/quote]
Email GMK, they'll give you a list.
Offline e_l_tang
« Reply #8 on: Thu, 03 November 2016, 00:15:53 »
[/quote]
I already tried, but they didn't. They seemed to not have one.
« Last Edit: Thu, 03 November 2016, 00:21:08 by e_l_tang »
Offline nyunyu
« Reply #9 on: Fri, 04 November 2016, 14:22:26 »
Cherry is famous for some nonstandard keycaps, like the off-center 6.25 spacebar and the stepped Caps Lock:
But I was not prepared, that their MY 3000/G81-3xxx series have nonstandard Ctrl/Alt/Win caps too:
Top: B row ISO Shift
Bottom: B row Ctrl
Right: C row stepped Caps
(From some custom branded Cherry XXL Keyboard, G81-3486LUNDE-0)
Does the regular MX 3000/G80-3xxx use center stemmed 1.25U wide Ctrl/Alt/Win caps, or these off-center 1.25U wide ones?
« Reply #10 on: Fri, 04 November 2016, 14:56:41 »
All G80-3000 with Windows keys have centre-stemmed 1.25u modifiers. All G81-3000 with Windows keys have offset-stemmed 1.25u modifiers.
Those are the only non-stabilised keys that are different. A 1.25 Shift key is always centre-stemmed. Caps Lock on G80 and G81 are the same.
As to the other keys:
G81-3000 with Windows keys and in PBT or POM have also different stabilised keys (2u Backspace, right Shift, Space, Enter etc)
The G81-3000 without Windows keys (1.5u modifiers, thick PBT or ABS) use the same keycaps as G80-3000 without Windows keys.
On a G81-3000 with Windows keys and ABS keycaps the Space Bar and 1.25u modifiers are the only keys that are different from a G80-3000 with ABS keycaps. (I think those keys are actually POM)
« Last Edit: Fri, 04 November 2016, 14:58:38 by Findecanor »
Offline nyunyu
« Reply #11 on: Fri, 04 November 2016, 15:21:36 »
Stabilizer wires are hooked into the side of the switches.
Caps are lasered PBTs.
