Author Topic: [GB] Custom CNC Aluminum Cases for Cooler Master TKL boards (SHIPPED)  (Read 202091 times)
Offline poolside
Re: [GB] Custom CNC Aluminum Cases for CoolerMaster TKL boards (TAKING ORDERS)
« Reply #50 on: Mon, 07 November 2016, 18:35:28 »
 :thumb:
Currently trying to decide between warm gray and space white. About the latter, the store's description says that the powder coating will only be applied to the visible surfaces of the case. I therefore wonder what the finish will look like at the joint between the two case halves. May we get a close-up picture of that area once you receive the powder-coated prototype from the CN shop?
Also, any chance for the Galaxy Class set to make a come-back in the future? I passed on it when it dropped and only realize now it looks really good in your pictures with the warm gray anodized case.
Offline pixelpusher
« Reply #51 on: Mon, 07 November 2016, 18:52:10 »
:thumb:
I agree about galaxy.  It didn't float my boat until I saw it with this case for some reason.  Would love to see it again.
I had the same question about the white and he said he would update with closeup photos showing details on the seam and edges once he got a production version in. The one pictured is still the prototype.
« Last Edit: Mon, 07 November 2016, 19:41:52 by reececonrad »
Offline McPwned
« Reply #52 on: Mon, 07 November 2016, 20:59:42 »
Waiting patiently for news on the Enigma Black sub-buy.
If anybody is particularly keen on on a case in Enigma Black (wrinkle coat), my recommendation is actually to buy a custom color as part of this group buy and put in "Enigma black" as your color of choice in the "special instructions for seller" field of the cart.
The only caveat on that is it'll take me around a month longer to deliver those, as I'll have to get them powder coated here locally in the SF area. What I'll essentially do is order a case for you as part of this group buy without any pigment finishing and then drive it over to a powder coat place here locally. A bit unsophisticated, but it should work, and my sense is that it'll cost about what the add-on fee is for the custom color (hopefully). Sorry for the extra cost on these. I tried to get the factory to do wrinkle coat, but they consider this a specialty finish that is beyond their scope of expertise.
The added $100 CAD is pretty disappointing, but I guess that's the choice I have to make.
Offline norbauer
  • Plz email shop@norbauer.com; I miss PMs sometimes
    • Ryan Norbauer's personal site
« Reply #53 on: Mon, 07 November 2016, 22:11:35 »
Trying to figure out what custom color I want - do you think Pantone 295C will result in a nice midnight/navy blue? https://www.pantone.com/color-finder/295-C
295C is very dark navy (almost black), but it sounds like that is what you're going for. The metallic aluminum showing through from below will lighten that a tad, so yes, I would say that's a good choice if very dark blue is what you're seeking. :)
Perfect, thanks! Probably placing an order tonight. :D
Cool. Please just make sure to add the Pantone color you want in the order notes when checking out. Thanks!
Offline axtran
« Reply #54 on: Mon, 07 November 2016, 23:29:50 »
Putting in an order tomorrow. Want to see this thing through to success!
MX Silent > MX Vintage Black > Everything Else
Offline atlas3686
  • HHKB Elite
« Reply #55 on: Tue, 08 November 2016, 00:33:12 »
Damn kinda wish I had a novatouch now! Thought of making Realforce ones? There aren't many digilog ones around and they not the best design anyway.  Best of luck with this project.
I was actually just about to PM you about this, but I totally agree with that and may very well tackle RealForce cases next if this group buy turns out not to have been too much work. ;)
Great news, I am sure there will be tons of interest if you decide to do it although I get the feeling GBs take it out of you so you might be less keen after completing this one :)
Offline thel
« Reply #56 on: Tue, 08 November 2016, 06:17:34 »
I am also on the verge between white and grey.
Maybe some additional pictures can resolve this ;). I am too especially interested in the corners and the non-visible area of the white case.
Also: Is someone in Germany interested in splitting the shipping cost? - Max 1 person (pref. Frankfurt or Munich area) so we will not get over the 150€ "Zoll" fees.
Thanks the ton of effort you put in that project Norbauer!
Cheers
Offline Phenix
« Reply #57 on: Tue, 08 November 2016, 06:42:31 »
Whats about the phantom pcb? IIRC it does not work, or?
Winter is coming.
Offline pschoen
« Reply #58 on: Tue, 08 November 2016, 09:29:20 »
hi,
i'm am interested as well, but i don't know if there is enough space underneath the keyboard.
I also have a "rapid I" but I added a diy track-point to get rid of my mouse :D
I drilled through the pcb and added a teensy+Trackpoint from an old T40 Leptop keyboard.
In order to fit i would need at least 5mm space for the teensy 2.0 + isolation
Offline Phenix
« Reply #59 on: Tue, 08 November 2016, 10:20:31 »
hi,
Please share a pic!
(I thought about try out an trackpoint, but I think I cant navigate with it properly)
Winter is coming.
Offline pschoen
« Reply #60 on: Tue, 08 November 2016, 11:18:43 »
hi,
pics or it did not happen :D here are the pics https://imgur.com/a/YiOoB
the track point is 1 mm off to the right but enough for me currently.
Mouse buttons are currently blues but i will put them into the space-bar and make a
space / left mouse / middle mouse / right mouse / space.
So in other words this is not finished but its my current work setup for 2 months now because I could not resist to just use it right away.
I will continue with the setup when my gateron brown switches will arrive in 2 weeks. :)
@norbauer could you measure the distance from the egde within the case where the PCB is fixed on to the actual maximum inner bottom like
the profile below?
 _
| |_
|    |  <- this depth
|    |______
« Last Edit: Wed, 09 November 2016, 02:00:22 by pschoen »
Offline norbauer
« Reply #61 on: Tue, 08 November 2016, 13:29:24 »
I'm happy to report that we hit our MOQ last night.
Offline johntron25
« Reply #62 on: Tue, 08 November 2016, 14:12:54 »
Mother of god, that white case is beautiful. Gathering funds now.
Offline JDragon
« Reply #63 on: Tue, 08 November 2016, 14:53:05 »
Ordered my midnight blue case. Hype. :D
Offline poolside
« Reply #64 on: Tue, 08 November 2016, 17:20:55 »
Has the feet height been reduced from what is shown in the CAD picture in the IC's OP?
Offline norbauer
« Reply #65 on: Wed, 09 November 2016, 14:52:32 »
A couple of friendly reminders:
-Please double-check your email address for typos when checking out. If you give the wrong address, I have no way to update you on the status of your order or to send tracking details when it ships.
-If you order a custom color, make sure to put color or finish you want in the checkout field.
Thanks everyone for your continued support!
Offline norbauer
« Reply #66 on: Wed, 09 November 2016, 15:35:14 »
The height and placement of the feet bring the angle of the face to roughly the same angle of the Cooler Master cases (when those cases don't have their own flip-down feet deployed). They're approximately 15.4mm in height, but that isn't particularly informative because their placement also matters in the ultimate resulting angle.
Offline geekzombie
« Reply #67 on: Wed, 09 November 2016, 18:27:47 »
Just to confirm; does this support the Quickfire Rapid, or only the Rapid-i?
I assume the latter, but dont want to miss out if that's not the case.
Offline Ashlyn
« Reply #68 on: Wed, 09 November 2016, 18:31:41 »
Looks great
Offline fine_italian_leather
« Reply #69 on: Wed, 09 November 2016, 19:06:34 »
Thinking about going 276C or 7540C for custom color, scared 276C will end up looking black.
Offline norbauer
« Reply #70 on: Wed, 09 November 2016, 22:30:53 »
Sadly, the QuickFire rapid uses a different plate and thus doesn't fit in this case. The Rapid-i does, however, fit.
Offline Dee1
« Reply #71 on: Thu, 10 November 2016, 12:02:09 »
Wow, the gb is finally here! :D Now to decide on a color...
Offline mrkevint
  • OK.
« Reply #72 on: Thu, 10 November 2016, 12:12:02 »
Thanks for your efforts norbauer!
I've been following this project since the beginning and it's nice to see it come to fruition. I like how receptive you were of everyone's feedback in the final design.
I'll be ordering a case in the next couple of days. :thumb:
Offline breitling
« Reply #73 on: Thu, 10 November 2016, 12:22:25 »
I really wanted this a while back but moved away from my Novatouch in recent months.. but still want it its so sweet! might have to join anyway!
Offline Data
« Reply #74 on: Thu, 10 November 2016, 12:32:12 »
That gold anodizing is super tempting.
Offline mrkevint
  • OK.
« Reply #75 on: Thu, 10 November 2016, 12:37:52 »
I like this group buy because it's one of the only ways to get a Topre switch inside an aluminum case. I know that there was the Digilog for Realforce TKLs but they're pretty rare now.
I think that a lubed and silenced Novatouch in an aluminum case would be amazing. It's a shame that the Novatouch had to be discontinued.
Offline norbauer
« Reply #76 on: Thu, 10 November 2016, 14:17:49 »
the profile below?
 _
| |_
|    |  <- this depth
|    |______
That dimension is 8.6mm. Hope this helps. :)
Offline pschoen
Re: [GB] Custom CNC Aluminum Cases for Cooler Master TKL boards (TAKING ORDERS)
« Reply #77 on: Thu, 10 November 2016, 14:29:39 »
Yes!
This will definitely fit!
so I just placed my order few seconds ago :D
I man i can wait for it :D This will be so delicious :P
CNC alu + Trackpoint + Gateron brown + Zealencio Clips
Thats nearly endgame :D only nice SA's are missing
« Last Edit: Thu, 10 November 2016, 14:38:17 by pschoen »
Offline norbauer
« Reply #78 on: Thu, 10 November 2016, 14:30:08 »
Awesome. Thanks so much for your kind words and encouragement! :)
Though it was a long slog, I'm glad we took our time. The poll in particular was very helpful in guiding me along people's actual preferences. I don't know why I didn't think of that earlier.
Offline complex
« Reply #79 on: Thu, 10 November 2016, 15:48:19 »
I have to say that that warm gray anodized colour really grew on me, didn't really like it when I saw it for the first time.
Also props for the way you handled this GB and the time leading up to it. You took your time to do it properly,
which is really appreciated.  :)
Can't wait to get my case.
« Last Edit: Thu, 10 November 2016, 15:50:07 by complex »
Offline odd
« Reply #80 on: Thu, 10 November 2016, 16:40:45 »
Oh god yes, FINALLY!!!!!!
ordered  :thumb:
Offline norbauer
« Reply #81 on: Thu, 10 November 2016, 20:22:29 »
Just a quick update everyone. mrkevint helped me identify a bug in the shipping costs to Canada. They were previously showing as higher than they should have, but the problem should now be fixed. Thanks, mrkevint!
Offline stillzman
« Reply #82 on: Fri, 11 November 2016, 08:18:49 »
please make this happen!
Offline mrkevint
  • OK.
« Reply #83 on: Fri, 11 November 2016, 12:19:24 »
Thanks for quickly fixing the issue. I just placed an order!
Offline norbauer
« Reply #84 on: Fri, 11 November 2016, 15:28:25 »
Let me get through this group buy, but I'll happily turn my attention to that in the new year. I've actually already had some thoughts on how to approach the design to improve on some of the others out there and will perhaps start and IC thread soon. For now, though, my focus is Cooler Master cases. ;)
Offline axtran
« Reply #85 on: Sun, 13 November 2016, 10:16:56 »
Exciting! I'll surely get one of those too
Offline complex
« Reply #86 on: Sun, 13 November 2016, 13:13:04 »
How thight is the fit of the micro usb cable? Will a custom cable with a connector like this http://i.imgur.com/7rj7y0d.jpg fit?
Offline fax668
  • Shaken, not stirred
« Reply #87 on: Sun, 13 November 2016, 15:49:02 »
I actually no longer have the white sample case, but I can shoot the two gray and black cases on a white background if that would be helpful.
Are you still planning to make those shots or did I overlook them in the Dropbox folder?
Offline norbauer
« Reply #88 on: Mon, 14 November 2016, 01:49:49 »
I designed the USB pocket size (on the outside of the case) according to the USB spec and not according to the size of just the Cooler Master cables, so any connector that conforms to the spec should fit.
Offline norbauer
« Reply #89 on: Mon, 14 November 2016, 01:51:36 »
I am still planning on doing it but just haven't had the chance yet. I'm traveling right now in Seattle but will be back next week and hope to post pics by mid-week, but don't hesitate to ping me if I forget. ;)
Offline eGamersvic
« Reply #90 on: Mon, 14 November 2016, 07:50:42 »
Hi Norbauer:
I am a KB PM working at Cooler Master now.
Much appreciated it, and all CNC cases are looks awesome.
Wish you can make more cases.
Sincerely.
« Last Edit: Tue, 15 November 2016, 05:46:05 by eGamersvic »
Offline bubbedi
« Reply #91 on: Mon, 14 November 2016, 11:11:20 »
Thank you norbauer for making this happen. Case arrived and looking gorgeous!!
152823-0
152825-1
Offline norbauer
« Reply #92 on: Tue, 15 November 2016, 03:26:26 »
Just got back from Seattle and am catching up on backlog, as I will do tomorrow.
Here is a photo of the gray keyboard on a black background. I didn't have a black anodized case handy, so I just set my black Montblanc pen next to it.
Note that this is with pretty high exposure and a bright studio light, so it's going to look less light and less warm/brown in standard indoor lighting conditions. But I think this image gives a decent sense of the color, on my monitor at least.
Here is with the exposure not turned up quite so much, as it might look in a more normally lit room
« Last Edit: Tue, 15 November 2016, 03:53:38 by norbauer »
Offline fax668
« Reply #93 on: Tue, 15 November 2016, 03:55:55 »
Very cool, thanks!
Offline norbauer
« Reply #94 on: Tue, 15 November 2016, 04:02:39 »
Wow. That was fast. I'm so happy you're pleased. :)
In case anyone is curious, btw, that is an early prototype case that bubbedi purchased from me.
Offline norbauer
« Reply #95 on: Tue, 15 November 2016, 04:03:24 »
Hi Norbauer:
With you can make more cases.
Sincerely.
Cool. Thanks very much. Feel free to send me a PM if you'd like to collaborate on anything.
Offline FSund
« Reply #96 on: Tue, 15 November 2016, 04:46:08 »
What's the distribution between black/warm grey/other colors in the orders until now?
I've ordered the black one, but I'm considering switching to the warm gray (if possible, and if I can decide before the cutoff!).
Join the Mechanical Keyboards Norway Discord server
Offline norbauer
« Reply #97 on: Tue, 15 November 2016, 14:31:01 »
Last time I looked a day or so ago, it was around 40% black and 60% gray, if you're just comparing those two options.
Offline norbauer
« Reply #98 on: Tue, 15 November 2016, 21:39:11 »
Say, is anybody here a member of Deskthority or any of the Korean sites? If so and you could post a link to the group buy there, that would be awesome.
Best links would be to this thread and/or the group buy purchase page.
Offline balancebox
« Reply #99 on: Tue, 15 November 2016, 21:40:04 »
damn doesn't fit QuickFire rapid =(
Filco MJ2 104 w/ Cherry Black | Filco MJ2 104 w/ Cherry Brown | KBT Pure w/ Cherry Blue | CMStorm QFR w/ Cherry Ghetto Green | Ducky One w/ Gateron Green |
