Author Topic: Can i make HHKB Type-s more silence  (Read 2126 times)
Offline breaker9691
« on: Sun, 06 November 2016, 12:47:45 »
I'm really enjoy the "thock thock" sound of hhkb , but then the long key always getting so loud, can i reduce that sound and even other key too ?
the shift, enter and spacebar always make so much noisy...
Offline ajx
Re: Can i make HHKB Type-s more silence
« Reply #1 on: Sun, 06 November 2016, 17:24:02 »
You can lube stabilizers, yes it will reduce noise especially from the spacebar
I use Krytox as lube
Offline breaker9691
« Reply #2 on: Mon, 07 November 2016, 09:15:02 »
lube not help me much, i just want it to get the damn silence so i put something on the pad of the spacebar, all sound is gone. but the problem still there with enter and Lshift.
Offline hurst
« Reply #3 on: Mon, 07 November 2016, 09:29:17 »
try pads there too
« Reply #4 on: Mon, 07 November 2016, 17:21:19 »
Also look into desk mat modding it.
