Author Topic: spacebar Keyboard Roof  (Read 1898 times)
Offline SCTony
« on: Thu, 21 January 2010, 06:00:10 »
I stumbled over this while searching for a good USB hub - it is not yet in production but looks good. Looks as if they would go into production once they get 590 commitments to purchase (they currently have 207).  BTW, I think I am going to try a Belkin USB hub- any suggestions? I tried a Cables-To-Go hub and it was a fail. Thanks.
IBM PC-AT Model F ;  Model M-
    1391401 Aug 89, 92G7453 Nov 95, 42H1292 Jul 97
Compaq KB-9963 (rubber dome);
Cherry MX-SPOS:typing:
Offline itlnstln
« Reply #1 on: Thu, 21 January 2010, 08:04:42 »
Hah!  Beat you to it.  (Different source, though.)
I don't think this will fit over most of the keyboards we use around here.  The Engadget article I read showed it over an Apple Aluminum keyboard, and there wasn't a whole helluva lot of room over it.
Offline AndrewZorn
« Reply #2 on: Thu, 21 January 2010, 10:23:56 »
looks neat, but i am interested, disappointed, and confused at the whole business model.
Offline elservo
« Reply #3 on: Thu, 21 January 2010, 12:42:39 »
That's a very interesting way to do it.  Getting all those people on board before starting production is like business without the whole "risk factor."  We should have thought of that, people!
Majestouch Tactile Click (Work)
AEKII(Home)
Offline SCTony
« Reply #4 on: Thu, 21 January 2010, 16:35:30 »
Yes, I was disappointed in the Cables To Go hub.
This Hub-
would not write to this reader-
It would read a card ok, but not write to it. I was not using the AC adapter but it is supposed to work on bus power or AC adapter. Once or twice I got it to write, but mostly no. Seems like a power problem? I need a bus-powered hub currently. I like the layout and metal constuction of that hub. I found this comment on Terry White website :
"  Any 7 port USB 2.0 hub using the Philips chip ISP1521BE is a nightmare..
There’s a design falw that Philips will not admit (atleast not in public)
They are sensitive to staics and will drop several time per day when used in 2.0
The Cable-To-Go 7 port is using this IC  ".
  I can't vouch for or against that comment but there are several negative reviews on the Cables To Go website.
  :clap2: Kudos to B&H Photo!! Great prices and picked up the return shipping. Plus, their free shipping has been regular 3-day UPS delivery, not the economy 7 day UPS.
 That little card reader works great- I get like 19 MB/second read transfers off a Kingston Class 4 (4 GB) card.
« Last Edit: Thu, 21 January 2010, 19:10:11 by SCTony »
Offline elservo
« Reply #5 on: Thu, 21 January 2010, 16:43:52 »
I love how monitors these days almost always come with 4 USB ports on them in one place or another.  Keeps most of my cables off the floor, which is good.
AEKII(Home)
Offline ricercar
  • mostly abides
« Reply #6 on: Thu, 21 January 2010, 18:12:01 »
Might be non-obvious:
A 7-port hub should be purchased with a power supply. There's no way a single USB connector can power 7 USB peripherals.
Offline SCTony
« Reply #7 on: Fri, 22 January 2010, 04:55:18 »
The hub came with a power supply, but I wasn't using it. The only thing I had connected to the hub was the card reader. Per the manufacturer, "This hub can be self-powered from the USB port, or utilize the included AC power supply adapter."  I am not sure what the reason was for the write failure. I didn't think it would be so difficult  to find a good hub.:ranger:
« Last Edit: Fri, 22 January 2010, 11:16:49 by SCTony »
Offline SCTony
« Reply #8 on: Sat, 23 January 2010, 14:48:12 »
Belkin hub showed up today- and this is more what I was expecting. To test it without using the AC adapter, I am able to write to a SDHC card, power a CCFL light, operate a Powermate, and power an 8GB Rally thumbdrive.
« Last Edit: Sat, 23 January 2010, 16:05:14 by SCTony »
