Author Topic: lift the keyboard feet , no?  (Read 7973 times)
Offline devilcm3
« on: Fri, 22 January 2010, 04:22:22 »
i was wondering whether i should lift my keyboard or not?
read in some article that keyboard should not be lifted because it makes RSI worse...but doubt the credibility of the source....
so i just want to know your opinion...does it feels better / type faster when the keyboard is lifted...or not?
now im using my keyboard without the feet
Black Cherry MX , once you bought it , it is yours , it is permanently yours , it is permanently yours till you meet your maker
1.FILCO Cherry Blue FKBN104MC/EB
2.FILCO Cherry Brown FKBN84M/EB
Offline whininggit
« Reply #1 on: Fri, 22 January 2010, 04:24:47 »
On almost every keyboard I've tried, it makes it more uncomfortable to type with the feet raised.
Cherry G80-3000LSCGB-2 (modded to Cherry MX Browns) (main) | Cherry G84-4100 (Cherry ML) | Compaq MX-11800 (modded to Cherry MX Blue) | Dell AT101W (Alps Black) | IBM Model M 1391406 (Buckling Spring) | Matias Tactile Pro (1.0) (Alps) | SGI AT-101 (Alps w/Dampers) | Black Alpsulator (XM Alps-type)
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2 on: Fri, 22 January 2010, 04:58:20 »
I can't type at all (typos galore, speed gone, often pressing wrong keys) if the feet are NOT extended.
I'm an exception to the norm in that way, however.
kishy.ca
Offline cmr
« Reply #3 on: Fri, 22 January 2010, 05:01:36 »
i always use the feet at the highest setting, and if they break, i fashion new ones
Offline devilcm3
« Reply #4 on: Fri, 22 January 2010, 05:15:40 »
Quote from: whininggit;152921
is it the wrist which caused any discomfort to you?
i can actually type both lifted and without , but i feel that i type faster although i feel sometimes my pinky have a hard time reaching the P without being lifted.
is it true that lifting the keyboard decreases the distance from key to finger? (especially pinkies)
Offline ch_123
« Reply #5 on: Fri, 22 January 2010, 05:27:19 »
I'm convinced that IBM put feet on the Model F to emulate this -
And everyone else blindly followed.
I still prefer it when the feet are raised, even though it's supposedly unergonomic.
Offline devilcm3
« Reply #6 on: Fri, 22 January 2010, 05:36:07 »
Quote from: ch_123;152926
so it is true that lifting the feet is ergonomic eh?
i wonder if you have any typing difficulties especially pinkie when typing with the feet off?
Offline Mental Hobbit
« Reply #7 on: Fri, 22 January 2010, 05:48:53 »
I believe whatever feels better to you, probably is better for you.
Typing on blues.
Offline mmgoose
« Reply #8 on: Fri, 22 January 2010, 05:55:10 »
i always go for what feels comfortable and i also try and take cues from those who've been doing it for a very long time.
http://www.youtube.com/watch?v=XhnRIuGZ_dc&fmt=
Customizer Ultimate
Offline patrickgeekhack
« Reply #9 on: Fri, 22 January 2010, 07:27:41 »
For me it depends on the situation. If I'm using a keyboard tray, I don't use the feet. But if I'm using the keyboard directly on the desk, then yes.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline itlnstln
« Reply #10 on: Fri, 22 January 2010, 07:41:09 »
I never use the feet; I like my 'boards as flat as possible.  That said, it's a personal preference.  Do what ever feels more natural to you.
Offline Rajagra
« Reply #11 on: Fri, 22 January 2010, 07:41:36 »
Note that her wrists are straight, and her elbows are below the height of the keyboard. Hence the slope of the keyboard is acceptable.
For most people these conditions will not be the same, so raising the back of the keyboard is not appropriate.
I think the real reason for raising the back of the keyboard is to make it easier for non touch typists to read the keys. It's that silly.
This is what will happen to your hands if you use the keyboard feet:
« Last Edit: Fri, 22 January 2010, 07:56:27 by Rajagra »
« Reply #12 on: Fri, 22 January 2010, 08:03:18 »
A frozen grin on the face must be quite important too. I see that in all pictures on ergonomic typing.
Typing on blues.
Offline Rajagra
« Reply #13 on: Fri, 22 January 2010, 08:19:40 »
She's happy because her toast is nearly done.
Offline snerd
« Reply #14 on: Fri, 22 January 2010, 08:28:33 »
I keep the feet raised, which probably means you should not. I type like Frankenstein's monster with my arms extended slouched way down in the chair, and my eyes aligned to the bottom of my huge monitor.
This position with the feet raised aligns perfectly to keep my wrists straight with no strain, and the edge of me desk is like a wrist rest.
(do not do this)
I intend to get a steelcase leap to try to improve my posture. I'm just not comfortable unless all of my body parts including my feet are propped up.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #15 on: Fri, 22 January 2010, 08:45:25 »
Quote from: Rajagra;152969
LOL.
Why is there a toaster to the right of her terminal anyways?
Toast crumbs are EVIL, and should not be within a 2 meter radius of any keyboard.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline hyperlinked
« Reply #16 on: Fri, 22 January 2010, 08:49:27 »
[Echoes of what Rajagra said about posture...]
Elevating the feet bring the back row keys you have to reach for just a little closer so that you don't have to reach as far, but how your body is situated in front of your keyboard is more important.
Most people probably have their keyboard on top of their desks and so in that case unless you're at least 6'2", then the keyboard is probably too high already.
Also, if you're slouching forward at your keyboard, the angle of your upper body makes it as if you're "typing uphill." That's something most people don't take into account. It doesn't matter if you have your workstation finely tuned to the perfect heights and distances only to negate everything with very bad posture once you get down to work.
If anyone has only one key to ergonomic success, don't listen to them. They don't know what they're talking about. It's how everything is put together that matters. Ergonomics is a very soft word and a controversial science... but you wouldn't ever know that from all the products that are getting marketed as "ergonomic."
« Last Edit: Fri, 22 January 2010, 10:22:45 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline hyperlinked
« Reply #17 on: Fri, 22 January 2010, 08:51:18 »
Quote from: HaaTa;152973
Those are probably 8" floppy drives... ancient stuff.
« Last Edit: Fri, 22 January 2010, 09:53:18 by hyperlinked »
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #18 on: Fri, 22 January 2010, 09:49:10 »
And here I thought they put the feet on to emulate that -
Offline Mercen_505
« Reply #19 on: Fri, 22 January 2010, 10:20:52 »
I always keep my keyboards slightly inclined. The only time I ever used a keyboard totally flat was with my IBM M4, which is absurdly steep when you put the feet into position. I keep my boards on top of my desk, rather than using a slide tray underneath. In such a position, I can totally understand why one would not want to use the legs.
Offline meltie
« Reply #20 on: Fri, 22 January 2010, 11:10:29 »
The first keyboard I regularly used was a Model M at work (i didn't use the feet), and for I long time after, I had to use the feet on any other keyboard to tilt them as much as the Model M. But now, I prefer to not use the feet and like my keyboards as flat as possible. I use a wrist rest, though.
Offline hyperlinked
« Reply #21 on: Fri, 22 January 2010, 11:17:18 »
Quote from: ripster;153003
As long as you're not doing this it's all personal preference.
One of the reasons why you don't do that is because every joint in your body has a "neutral" position that is roughly in the middle between the two end ranges of motion. It's in this middle angle that you make the most efficient use of your muscles. The farther away you are from that middle range, the greater amount of stress each keystroke or motion causes on your muscles and tendons.
Offline devilcm3
« Reply #22 on: Fri, 22 January 2010, 11:27:07 »
But I do recommend keyboard trays for a lot of reasons.
thanks..this is what i need:D
